Hello all, thank you for the code. I tried searching the thread before posting my issue.
I'm able to open and close my garage in the device section, but I can not control in a Dashboard. I've selected the Garage (Control) template and still nothing. I saw a few screenshots of other dashboards but nothing on how they operate. I would think 1 tile is all you need to control open and close, but I can't get the tile to do either action.
Thanks in advance, can't wait to hear the solution.
let me see if I can find any logs for the dashboard.
Found them: Same for closer tile and opener tile
dev:1322020-07-16 07:13:18.935 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_brbeaird_Momentary_Button_Tile_432.getMyQDeviceId() is applicable for argument types: () values: [] (getMyQDeviceId)
dev:1322020-07-16 07:12:39.234 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_brbeaird_Momentary_Button_Tile_432.getMyQDeviceId() is applicable for argument types: () values: [] (getMyQDeviceId)
dev:1322020-07-16 07:04:52.677 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_brbeaird_Momentary_Button_Tile_432.getMyQDeviceId() is applicable for argument types: () values: [] (getMyQDeviceId)
This is just for the normal garage device: dev:1302020-07-16 07:08:50.735 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_brbeaird_MyQ_Garage_Door_Opener_434.closePrep() is applicable for argument types: () values: [] Possible solutions: close() (closePrep)
dev:1302020-07-16 07:08:24.114 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_brbeaird_MyQ_Garage_Door_Opener_434.openPrep() is applicable for argument types: () values: [] Possible solutions: open(), grep() (openPrep)
Only in the Dashboard, opening or closing is not working. In the Devices > Garage device, I can click on the commands and it'll open/close. Just can't get that transferred over to a dashboard.
I can't remember the details exactly, but I seem to remember that you have to check an additional setting in the MyQ (Hubitat) app to use this without a tilt sensor. I think that made open and close buttons from what I recall? I also seem to remember that you cannot use the Garage (Control) without a tilt sensor.
Most people seem to use the Samsung door tilt sensor (multi-sensor) with this app.
a new issue has come up, it seems if I open or close the door with the garage door button, or opener in my car, it seems to think the door is still open. I have to go into the MyQ door device, and click Poll. The sensor always reads correct, but the app is not checking like it should. ideas?
no, i am using the sensor, and it worked fine, the fix that fixed the login because of some capital letter somewhere. I have a Zigbee tilt sensor, and if I hit "Poll" on the MyQ garage device, it shows as closed like it should. just weird.
Not sure what to suggest. Since it doesn't seem to have cleared itself, I would create a virtual placeholder for your rules, and then reinstall the app.
I have this same issue. It will open and close and show the right state through the app but if I open using the door switch or remote it will show as open but then not update the status to be closed after the door is closed. A manual "poll" in the device page will fix the status update issue. A reinstall of the application has not yielded any new results.
Is this a new occurrence on an old install, or a new install? How did you install these packages, and what options did you use (tilt sensor OR non-sensor version)
Do you have a door tilt sensor (NOT the one that came with the door)?
