Hi, I've been using broadlink on Hubitat for a long time. But just this time I found the problem, in Apps-Broadlink Device Manager (BETA)-Device, I can't find my broadlink. It actually appears like this. Anyone know how to fix it?
Thank You
Best Regards
Donny
@putudhony88 did any of the ip's change?
Hi @thebearmay thank you for your reply
this what i got from logs
Thank you
Thank you for your reply @rlithgow1
I use static ip for the broadlink
Not familar with the code but someone who has it available should be able to look around line 485 and give you some alternatives.
I looked at the code, do you understand what this code means?
Iโm guessing you have multiple files in play for this app. The one weโre looking for will have a method that starts something like:
def DiscoveryPage() {
somewhere shortly before line 485, and line 485 will contain a variable name with .size() attached.
