Does anyone know if HE works with brilliant smart home control
Not to my knowledge. Last I knew, Brilliant was basically a closed system and no open API to allow for integration. And unless I am reading their chart wrong, nothing they work with is local control. About the best you could do is request integration on the link below.
Thanks alot, I will request the link and see if I get through.
The website states it works with IFTTT so you "could" use that although as @neonturbo says, it won't be local.
But you only get what 3 IFTTT flows unless you are on a paid plan. And unless IFTTT has improved, it was WAY too slow and intermittent to rely on for something like motion activated lighting.
Thanks, I will check it out.
