I'm a new user (of course) and somehow I've managed to brick a zigbee led controller, Miboxer FUT036Z. After adding the device I've tested it selecting different built-in drivers like "Advanced Zigbee Bulb" and while playing with the settings the device stopped to respond so I ended removing it from the devices. In the attempt to pair it again I've noticed that the physical button doesn't respond anymore so there is no way to reconnect. Already tried to power cycle and there is no reset button.
So it's probably going in the trash can, but I would like to know how did happen. Maybe clicking on device settings likes "configure", "flash" or "firmware update", even if doing that didn't output nothing in the UI?
I’m not aware of any command that the hub could send and that would result in a bricked device. Typically, if anything happens, the device can be reset.
My recommendation would be to check the device manual for a reset procedure, and maybe even follow-up with the manufacturer to see if they could send you a replacement under warranty.
Unfortunately there is no way to reset the device since the physical button (needed for the reset procedure) doesn't respond. The device briked during configuration via HE for sure and was previously used on others hubs without problems. Unfortunately, I don't remember exactly what I did during the setup but somehow I messed up.
These were the last lines from the device log
dev:102023-03-07 00:51:35.055 debug finished options testing...
dev:102023-03-07 00:51:34.482 debug starting options testing...
dev:102023-03-07 00:51:31.430 warn configure...
dev:102023-03-07 00:51:24.883 info Libreria was turned on
dev:102023-03-07 00:50:17.748 warn description logging is: true
dev:102023-03-07 00:50:17.747 warn debug logging is: false
dev:102023-03-07 00:50:17.747 info updated...
dev:102023-03-07 00:50:00.325 warn description logging is: true
dev:102023-03-07 00:50:00.324 warn debug logging is: false
dev:102023-03-07 00:50:00.323 info updated...
dev:102023-03-07 00:49:49.218 info Libreria was turned off
dev:102023-03-07 00:49:49.215 info Libreria was turned off
dev:102023-03-07 00:49:41.026 debug finished options testing...
dev:102023-03-07 00:49:40.456 debug starting options testing...
dev:102023-03-07 00:49:37.403 warn configure...
dev:102023-03-07 00:48:21.007 error java.lang.NumberFormatException: For input string: "úB+ûB+ûB+ùE+" on line 72 (method parse)
dev:102023-03-07 00:47:33.517 info
dev:102023-03-07 00:47:33.463 info Libreria was turned off
dev:102023-03-07 00:47:33.404 info
dev:102023-03-07 00:47:33.364 info
dev:102023-03-07 00:47:31.402 info
dev:102023-03-07 00:47:31.362 info
