I'm troubleshooting an issue with one of six Somfy RTS motorized shades controlled by a Bond Bridge BD-1000 and integrated with Hubitat.
My setup
- Hubitat platform: 2.5.2.139 (updated from 2.5.1.183 during troubleshooting)
- Bond Bridge: BD-1000
- Bond integration appears under Hubitat's Integrations menu as Bond Integration
- Parent device driver: Bond Bridge 2
- All six shades use the same Bond Bridge and Somfy RTS system.
- The shades use the
RMS12template.
The problem
Five shades work correctly through Hubitat. Shade 3 does not respond to either Open or Close commands issued directly from its Hubitat device page.
Shade 3 continues to operate normally through the Bond app.
When I try to open Shade 3 from Hubitat, Live Logs reports:
1be6939f endpoint does not support Open command
The Shade 3 device ID is 1be6939f.
What I've checked
- Shade 2 works correctly through Hubitat.
- Shade 4 (named Shade Number 4 in my setup), Shade 5, and Shade 6 also work through Hubitat.
- Shade 3 and the other shades use the
RMS12template and typeMS. - The Bond state variables list
OpenandCloseamong Shade 3's actions. - Shade 3's Bond app configuration shows Open, Close, and Intermittent commands.
- The Bond app's Set Position option is OFF for both Shade 2 and Shade 3.
- I updated Hubitat to 2.5.2.139, but the error persists.
- I inspected the original
BOND_Motorized_Shade.groovydriver andBOND_Home_Integration.groovysource. The shade driver'sopen()command callsparent.handleOpen(device). The parent function obtains the Bond ID and callsexecuteAction(bondId, "Open"). - I have not removed or reinstalled the integration.
My questions
- What generates the error
endpoint does not support Open command? Is it coming from the Bond API, Hubitat's integration, or another driver? - Why would the integration reject Open for Shade 3 when its advertised action list includes Open, while the other five shades work?
- Could Shade 3's endpoint or device definition be inconsistent even though it uses the same
RMS12template? - Would Reload Defaults in the Bond app's Edit Commands screen be a reasonable troubleshooting step? Specifically, what does it reset, and could it affect the device's pairing or other settings?
- Is there a safe way to refresh or repair the individual shade's registration in Hubitat without removing the entire Bond integration or disrupting the other devices?
I'd appreciate any suggestions, particularly from anyone familiar with the Bond Bridge 2 driver or this integration's endpoint handling.
Thank you!
