Was looking at something else and noticed this. It’s still controlling fans but I’m getting that error. There is one odd thing happening though I have a rule that turns on my master bedroom ceiling fan and while it works it’s also turning on my guest bedroom ceiling fan at the same time?
Can I get a PM with the hub id? .. Looks like the controller is stuck..
I've seen this behavior with the built in integration for a couple of years now whenever I have tried it. It didn't present itself immediately after install. Sometimes it would take a few days, other times as long as a couple of months.
I have had to stay on the community integration because of the log flooding so am curious if you find anything that might rectify the issue.
The repeated "Queue full" errors fit with a stuck controller, so it is worth checking whether anything is firing commands in a loop, such as the master bedroom rule retriggering, before assuming the Bond hub itself is at fault. For the guest fan coming on at the same time, check the rule's device list and the Bond app to make sure the guest fan is not in the same group or sharing a device entry with the master fan. If the log flooding continues, sending Bryan the hub ID as he asked is the fastest route, since that pattern has already been seen with the built-in integration.
Ya dunno what he did but after he said it should be okay after a reboot and it was.
