I have a Bond Bridge - and have been using the in-built HomeKit integration for awhile now. i've started to have some reliability issues with that - so i'm trying to see if the built-in Hubitat Bond Integration might work better.
I just added my Bond Bridge to Hubitat without issue - and it imported all of my devices (shades, fans and awnings) into Hubitat as children under the Bridge.
I went ahead and configured all of those devices to be exposed to HomeKit - and they show up there properly.
thanks very much!
One issue i'm having (and it's just an annoyance) is that for all of my shades and awnings - i'm seeing some of my shades (like this one) that are AC connected - displaying an issue with the battery:
hubitat shows battery mentioned in the cababilities, for all of the shades and awnings:
ideally it would be wonderful if hubitat and HomeKit would show me actual / good battery info for the devices with batteries, and not indicate a battery issue for the AC connected devices.
in the event that's not achievable - i would prefer to just disable the battery indication altogether.
i had that option ticked - but i likely never would have looked for those little plusses and minuses under the devices.
now that i've removed it from AC powered devices - for the battery operated ones, it's still showing battery low. is there a way to get it to show actual battery info?
That I don't know. Does the battery information come across into the device in Hubitat? If not, HomeKit won't be able to get it either (since it can only know what the device/driver does), which may be either a problem with the integration or just a limitation of the possibilities on the Bond side. If it's right on Hubitat and just the HomeKit bridge integration messing up the data, that could probably be fixed.
