Actually, forgot to mention HPM, but I'll come back to that....
I think the answer to your question is no... For apps like Bond that you typically install once, the process is essentially what you just did, load all the code and then install the app. For those apps (or drivers) where you may install multiple copies, you only need to load the code once and then install as many times as you like.
For that first part of the process, loading the code, there is a nother Community app that makes that much easier, it's called Hubitat Package Manager. I'd suggest installing that. It allows you to search for apps and drivers, install them in one click and manage automatic updates.
Hope this helps..
Simon
