Bond Bridge, can I expose non-standard commands?
So I grabbed a Bond bridge to control my Fanimation fan and it works great for speed, direction and on/off but none of the non-standard commands setup in the Bond app appear in my fan device in Hubitat, i.e. the breeze mode that automatically varies the fan speed to simulate a breeze. Not a deal killer, but it'd be nice to be able to program a Pico button to activate it.
My Leviosa shades have a open next, close next command that is not included in the HE standard shade drive for the BOND hub. I asked in the official thread if it could be added but I never could get them to answer me one way or the other.
I had already added the commands to the user app found here, so for my shades I just keep them on there.
Do you have any examples of how you added the commands? I'm assuming it required editing the drivers a bit? The default Bond integration commands work flawlessly otherwise.
I had to modify the app and the shade driver.
It's been a couple years ago since I did it. My shade cannot do a 0 to 100% setting. You define setpoints and you can raise and lower the shade to the next setpoint. The Bond app has a Open Next and Close Next option but the HE bond app does not. For whatever reason HE did not seem inclined to add it. The changes I made are shown below, should be a similar thing for you.
I have pasted all the code below instead of just the things I added. In case I missed something, as I said this was a couple years ago. You can do a compare of this against the original code listed on GITHUB if you need to.
This is the app code, I added a HandleCloseNext and HandleOpenNext. Didn't really document anything, and it may not be done correctly but it works.
 *  https://raw.githubusercontent.com/dcmeglio/hubitat-bond/master/apps/BOND_Home_Integration.groovy
 *  BOND Home Integration
 *  Copyright 2019-2020 Dominick Meglio
 * Revision History
 * 2020.01.18 - Added setPosition support for motorized shades, mapping a special value of 50 to the Preset command
 * 2019.12.01 - Fixed an issue where dimmers wouldn't work with fans that support direction controls, fixed an issue setting flame height
 * 2019.11.24 - Added support for timer based fan light dimmers and flame height adjustment for fireplaces
 * 2019.12.14 - Added support for Switch capability to the motorized shades for compatibility
 * 2020.01.02 - Fixed an issue where fan speed wouldn't be set properly (thanks jchurch for the troubleshooting!)
 * 2020.02.01 - Fixed an issue where looking for devices was incorrect which broke Smart By BOND devices (thanks mcneillk for the fix!)
 * 2020.03.23 - Added the ability to fix device state when it's out of sync (thanks stephen_nutt for the suggestion)
 * 2020.04.13 - Added a stop command to motorized shades to stop an open/close at the current position (suggested by jchurch)
 * 2020.04.21 - Added better logging for connection issues to the hub
 * 2020.05.04 - Error logging improvements
 * 2020.06.28 - Added toggle command to all devices (suggested by jchurch) and support for having multiple Smart by BOND devices (discovered by jhciotti)
definition(
    name: "BOND Home Integration",
    namespace: "dcm.bond",
    author: "Dominick Meglio",
    description: "Connects to BOND Home hub",
    category: "My Apps",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
    iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
	documentationLink: "https://github.com/dcmeglio/hubitat-bond/blob/master/README.md")
preferences {
	page(name: "prefHub", title: "BOND")
	page(name: "prefListDevices", title: "BOND")
	page(name: "prefPowerSensors", title: "BOND")
def prefHub() {
	return dynamicPage(name: "prefHub", title: "Connect to BOND", nextPage:"prefListDevices", uninstall:false, install: false) {
		section("Hub Information"){
			input("hubIp", "text", title: "BOND Hub IP", description: "BOND Hub IP Address", required: true)
			input("hubToken", "text", title: "BOND Hub Token", description: "BOND Hub Token", required: true)
			input("refreshInterval", "number", title: "Poll BOND Home every N seconds", required: true, defaultValue: 30)
            input("debugOutput", "bool", title: "Enable debug logging?", defaultValue: true, displayDuringSetup: false, required: false)
		displayFooter()
def prefListDevices() {
	if (!getDevices())
		return dynamicPage(name: "prefListDevices", title: "Connection Error", install: false, uninstall: false) {
			section("Error") {
				paragraph "Unable to retrieve devices. Please verify your BOND Hub ID and Token"
			displayFooter()
	else
		return dynamicPage(name: "prefListDevices", title: "Devices", nextPage: "prefPowerSensors", install: false, uninstall: false) {
			section("Devices") {
				if (state.fireplaceList.size() > 0)
					input(name: "fireplaces", type: "enum", title: "Fireplaces", required:false, multiple:true, options:state.fireplaceList, hideWhenEmpty: true)
				if (state.fanList.size() > 0)
					input(name: "fans", type: "enum", title: "Fans", required:false, multiple:true, options:state.fanList, hideWhenEmpty: true)
				if (state.shadeList.size() > 0)
					input(name: "shades", type: "enum", title: "Shades", required:false, multiple:true, options:state.shadeList, hideWhenEmpty: true)
				if (state.genericList.size() > 0)
					input(name: "genericDevices", type: "enum", title: "Generic Devices", required:false, multiple:true, options:state.genericList, hideWhenEmpty: true)
			displayFooter()
def prefPowerSensors() {
	return dynamicPage(name: "prefPowerSensors", title: "Fireplace Power Meters", install: true, uninstall: true, hideWhenEmpty: true) {
		section("Fireplace Power Meters") {
			paragraph "For each fireplace device you can associate a power meter to more accurately tell when it is powered on"
			if (fireplaces != null) {
				for (def i = 0; i < fireplaces.size(); i++) {
					input(name: "fireplaceSensor${i}", type: "capability.powerMeter", title: "Sensor for ${state.fireplaceList[fireplaces[i]]}", required: false, submitOnChange: true)
					if (this.getProperty("fireplaceSensor${i}") != null)
					input(name: "fireplaceSensorThreshold${i}", type: "number", title: "Sensor threshold for ${state.fireplaceList[fireplaces[i]]}", required: false)
		displayFooter()
def installed() {
	logDebug "Installed with settings: ${settings}"
	initialize()
def updated() {
	logDebug "Updated with settings: ${settings}"
    unschedule()
	unsubscribe()
	initialize()
def uninstalled() {
	logDebug "Uninstalled app"
	for (device in getChildDevices())
		deleteChildDevice(device.deviceNetworkId)
def initialize() {
	logDebug "initializing"
	cleanupChildDevices()
	createChildDevices()
	subscribeSensorEvents()
	def refreshEvery = refreshInterval ?: 30
    schedule("0/${refreshEvery} * * * * ? *", updateDevices)
def getHubId() {
	if (state.hubId)
		return state.hubId
	def params = [
		uri: "http://${hubIp}",
		path: "/v2/sys/version",
		contentType: "application/json",
		headers: [ 'BOND-Token': hubToken ]
	try
		httpGet(params) { resp ->
			if (checkHttpResponse("getHubId", resp))
				state.hubId = resp.data.bondid
		return state.hubId
	catch (e)
		checkHttpResponse("getHubId", e.getResponse())
		return null
def getDevices() {
	state.fireplaceList = [:]
    state.fireplaceDetails = [:]
	state.fireplaceProperties = [:]
	state.fanList = [:]
    state.fanDetails = [:]
	state.fanProperties = [:]
	state.shadeList = [:]
	state.shadeDetails = [:]
	state.shadeProperties = [:]
	state.genericList = [:]
	state.genericDetails = [:]
	state.deviceList = [:]
	def params = [
		path: "/v2/devices",
	try
		def result = false
			if (checkHttpResponse("getDevices", resp))
				for (deviceid in resp.data) {
					if (deviceid.key == "_")
						continue
					getDeviceById(deviceid);
				result = true
		return result
	catch (e)
		checkHttpResponse("getDevices", e.getResponse())
		return false
def getDeviceById(id) {
	def params = [
		path: "/v2/devices/${id.key}",
	try
			if (checkHttpResponse("getDeviceById", resp))
				if (resp.data.type == "FP")
					state.fireplaceList[id.key] = resp.data.name
					state.fireplaceDetails[id.key] = resp.data.actions
					state.fireplaceProperties[id.key] = getDeviceProperties(id)
				else if (resp.data.type == "CF")
					state.fanList[id.key] = resp.data.name
					state.fanDetails[id.key] = resp.data.actions
					state.fanProperties[id.key] = getDeviceProperties(id)
				else if (resp.data.type == "MS")
					state.shadeList[id.key] = resp.data.name
					state.shadeDetails[id.key] = resp.data.actions
					state.shadeProperties[id.key] = getDeviceProperties(id)
				else if (resp.data.type == "GX")
					state.genericList[id.key] = resp.data.name
					state.genericDetails[id.key] = resp.data.actions
	catch (e)
		checkHttpResponse("getDeviceById", e.getResponse())
def getDeviceProperties(id) {
	def params = [
		path: "/v2/devices/${id.key}/properties",
	def result = null
	try
			if (checkHttpResponse("getDeviceProperties", resp))
				result = resp.data
	catch (e)
		checkHttpResponse("getDeviceProperties", e.getResponse())
	return result
def findChildDevice(deviceId) {
	def hubId = getHubId()
	def dev = getChildDevice("bond:" + deviceId)
	if (dev != null)
		return dev
	return getChildDevice(hubId + ":bond:" + deviceId)
def findComponentDevice(dev, deviceId) {
	def component = dev.getChildDevice("bond:" + deviceId)
	if (component != null)
		return component
	return component?.getChildDevice(hubId + ":bond:" + deviceId) ?: null
def getBondIdFromDevice(device) {
	if (device?.deviceNetworkId.startsWith("bond:"))
		return device?.deviceNetworkId.split(":")[1]
	else
		return device?.deviceNetworkId.split(":")[2]
def deleteComponentDevice(dev, deviceId) {
	if (dev.getChildDevice("bond:" + deviceId + ":fan"))
		dev.deleteChildDevice("bond:" + deviceId + ":fan")
	if (dev.getChildDevice(hubId + ":bond:" + deviceId + ":fan"))
		dev.deleteChildDevice(hubId + ":bond:" + deviceId + ":fan")
def createChildDevices() {
		for (fireplace in fireplaces)
			def fpDevice = findChildDevice(fireplace)
			if (!fpDevice)
				fpDevice = addChildDevice("bond", "BOND Fireplace", hubId + ":bond:" + fireplace, 1234, ["name": state.fireplaceList[fireplace], isComponent: false])\
			if (state.fireplaceDetails[fireplace].contains("TurnFpFanOn"))
				if (!findComponentDevice(fpDevice, fireplace + ":fan"))
					fpDevice.addChildDevice("bond", "BOND Fireplace Fan", hubId + ":bond:" + fireplace + ":fan", ["name": state.fireplaceList[fireplace] + " Fan", isComponent: true])
			if (state.fireplaceDetails[fireplace].contains("TurnLightOn"))
				if (!findComponentDevice(fpDevice, fireplace + ":light"))
					fpDevice.addChildDevice("bond", "BOND Fireplace Light", hubId + ":bond:" + fireplace + ":light", ["name": state.fireplaceList[fireplace] + " Light", isComponent: true])
	if (fans != null)
		for (fan in fans)
			def fanDevice = findChildDevice(fan)
			if (!fanDevice)
				if (state.fanDetails[fan].contains("SetDirection"))
					fanDevice = addChildDevice("bond", "BOND Fan With Direction", hubId + ":bond:" + fan, 1234, ["name": state.fanList[fan], isComponent: false])
				else
					fanDevice = addChildDevice("bond", "BOND Fan", hubId + ":bond:" + fan, 1234, ["name": state.fanList[fan], isComponent: false])
			if (state.fanDetails[fan].contains("TurnUpLightOn") && state.fanDetails[fan].contains("TurnDownLightOn"))
				if (state.fanDetails[fan].contains("SetUpLightBrightness") && state.fanDetails[fan].contains("SetDownLightBrightness"))
					if (!findComponentDevice(fanDevice, fan + ":uplight"))
						fanDevice.addChildDevice("bond", "BOND Fan Dimmable Light", hubId + ":bond:" + fan + ":uplight", ["name": state.fanList[fan] + " Up Light", isComponent: true])
					if (!findComponentDevice(fanDevice, fan + ":downlight"))
						fanDevice.addChildDevice("bond", "BOND Fan Dimmable Light", hubId + ":bond:" + fan + ":downlight", ["name": state.fanList[fan] + " Down Light", isComponent: true])
				else if (state.fanDetails[fan].contains("StartUpLightDimmer") && state.fanDetails[fan].contains("StartDownLightDimmer"))
						fanDevice.addChildDevice("bond", "BOND Fan Timer Light", hubId + ":bond:" + fan + ":uplight", ["name": state.fanList[fan] + " Up Light", isComponent: true])
						fanDevice.addChildDevice("bond", "BOND Fan Timer Light", hubId + ":bond:" + fan + ":downlight", ["name": state.fanList[fan] + " Down Light", isComponent: true])
				else
						fanDevice.addChildDevice("bond", "BOND Fan Light", hubId + ":bond:" + fan + ":uplight", ["name": state.fanList[fan] + " Up Light", isComponent: true])
						fanDevice.addChildDevice("bond", "BOND Fan Light", hubId + ":bond:" + fan + ":downlight", ["name": state.fanList[fan] + " Down Light", isComponent: true])
			else if (state.fanDetails[fan].contains("TurnLightOn"))
				if (!findComponentDevice(fanDevice, fan + ":light"))
					if (state.fanDetails[fan].contains("SetBrightness"))
						fanDevice.addChildDevice("bond", "BOND Fan Dimmable Light", hubId + ":bond:" + fan + ":light", ["name": state.fanList[fan] + " Light", isComponent: true])
					else if (state.fanDetails[fan].contains("StartDimmer"))
						fanDevice.addChildDevice("bond", "BOND Fan Timer Light", hubId + ":bond:" + fan + ":light", ["name": state.fanList[fan] + " Light", isComponent: true])
					else
						fanDevice.addChildDevice("bond", "BOND Fan Light", hubId + ":bond:" + fan + ":light", ["name": state.fanList[fan] + " Light", isComponent: true])
	if (shades != null)
		for (shade in shades)
			def shadeDevice = findChildDevice(shade)
			if (!shadeDevice)
				shadeDevice = addChildDevice("bond", "BOND Motorized Shade", hubId + ":bond:" + shade, 1234, ["name": state.shadeList[shade], isComponent: false])
	if (genericDevices != null)
		for (generic in genericDevices)
			def genericDevice = findChildDevice(generic)
			if (!genericDevice)
				genericDevice = addChildDevice("bond", "BOND Generic Device", hubId + ":bond:" + generic, 1234, ["name": state.genericList[generic], isComponent: false])
def cleanupChildDevices()
		def deviceId = device.deviceNetworkId.replace("bond:","")
		if (deviceId.contains(":"))
			deviceId = deviceId.split(":")[1]
		def deviceFound = false
			if (fireplace == deviceId)
				deviceFound = true
				cleanupFPComponents(device, fireplace)
				break
		if (deviceFound == true)
			continue
		for (fan in fans)
			if (fan == deviceId)
				deviceFound = true
				cleanupFanComponents(device, fan)
				break
			continue
			if (shade == deviceId)
				deviceFound = true
				break
			continue
			if (generic == deviceId)
				deviceFound = true
				break
			continue
def cleanupFPComponents(device, fireplace)
	if (!state.fireplaceDetails[fireplace].contains("TurnFpFanOn"))
		deleteComponentDevice(device, fireplace + ":fan")
	if (!state.fireplaceDetails[fireplace].contains("TurnLightOn"))
		deleteComponentDevice(device, fireplace + ":light")
def cleanupFanComponents(device, fan)
	if (!state.fanDetails[fan].contains("TurnUpLightOn") || !state.fanDetails[fan].contains("TurnDownLightOn"))
		deleteComponentDevice(device, fan + ":uplight")
		deleteComponentDevice(device, fan + ":downlight")
	if (!state.fanDetails[fan].contains("TurnLightOn") || (state.fanDetails[fan].contains("TurnUpLightOn") && state.fanDetails[fan].contains("TurnDownLightOn")))
		deleteComponentDevice(device, fan + ":light")
def subscribeSensorEvents() {
			def sensorDevice = this.getProperty("fireplaceSensor${i}")
			if (sensorDevice != null)
				logDebug "subscribing to power event for ${sensorDevice}"
				subscribe(sensorDevice, "power", powerMeterEventHandler)
def powerMeterEventHandler(evt) {
	logDebug "Received power meter event ${evt}"
		if (evt.device.id == sensorDevice.id)
			def fireplace = fireplaces[i];
			def fireplaceDevice = getChildDevice("bond:" + fireplace)
			def threshold = 10
			def value = "on"
			if (evt.integerValue < threshold)
				value = "off"
			if (value != fireplaceDevice.currentValue("switch"))
				logDebug "current state ${fireplaceDevice.currentValue("switch")} changing to ${value}"
				fireplaceDevice.sendEvent(name: "switch", value: value)
            if (value == "off")
                def fanDevice = fireplaceDevice.getChildDevice("bond:" + fireplace + ":fan")
                if (fanDevice)
                    fanDevice.sendEvent(name: "speed", value: "off")
			break;
def updateDevices() {
    for (fan in fans) {
        def deviceState = getState(fan)
		if (deviceState == null)
			continue
		def device = findChildDevice(fan)
        def deviceLight = findComponentDevice(device, fan + ":light")
		def deviceUpLight = findComponentDevice(device, fan + ":uplight")
		def deviceDownLight = findComponentDevice(device, fan + ":downlight")
        if (deviceState.power > 0)
            device.sendEvent(name: "switch", value: "on")
			device.sendEvent(name: "speed", value: translateBondFanSpeedToHE(fan, state.fanProperties[fan].max_speed ?: 3, deviceState.speed))
        else
            device.sendEvent(name: "switch", value: "off")
			device.sendEvent(name: "speed", value: "off")
        if (deviceLight)
			if (deviceState.brightness != null)
				if (deviceState.light == 0)
					deviceLight.sendEvent(name: "level", value: 0)
				else
					deviceLight.sendEvent(name: "level", value: deviceState.brightness)
			else
				if (deviceState.light > 0)
					deviceLight.sendEvent(name: "switch", value: "on")
				else
					deviceLight.sendEvent(name: "switch", value: "off")
		if (deviceUpLight)
			if (deviceState.up_light_brightness != null)
				if (deviceState.up_light == 0)
					deviceUpLight.sendEvent(name: "level", value: 0)
				else
					deviceUpLight.sendEvent(name: "level", value: deviceState.up_light_brightness)
			else
				if (deviceState.light > 0 && deviceState.up_light > 0)
					deviceUpLight.sendEvent(name: "switch", value: "on")
				else
					deviceUpLight.sendEvent(name: "switch", value: "off")
		if (deviceDownLight)
			if (deviceState.down_light_brightness != null)
				if (deviceState.down_light == 0)
					deviceDownLight.sendEvent(name: "level", value: 0)
				else
					deviceDownLight.sendEvent(name: "level", value: deviceState.down_light_brightness)
			else
				if (deviceState.light > 0 && deviceState.down_light > 0)
					deviceDownLight.sendEvent(name: "switch", value: "on")
				else
					deviceDownLight.sendEvent(name: "switch", value: "off")
		if (device.hasAttribute("direction"))
			if (deviceState.direction == 1)
				device.sendEvent(name: "direction", value: "forward")
			else if (deviceState.direction == -1)
				device.sendEvent(name: "direction", value: "reverse")
			def deviceState = getState(fireplaces[i])
				continue
			def device = findChildDevice(fireplaces[i])
			def deviceFan = findComponentDevice(device, fireplaces[i] + ":fan")
			def deviceLight = findComponentDevice(device, fireplaces[i] + ":light")
			if (deviceState.flame > 0 && deviceState.power > 0)
				if (deviceState.flame <= 25)
					device.sendEvent(name: "flame", value: "low")
				else if (deviceState.flame <= 50)
					device.sendEvent(name: "flame", value: "medium")
				else
					device.sendEvent(name: "flame", value: "high")
			else
				device.sendEvent(name: "flame", value: "off")
				if (this.getProperty("fireplaceSensor${i}") == null)
				if (deviceFan)
					deviceFan.sendEvent(name: "speed", value: translateBondFanSpeedToHE(fireplaces[i], state.fireplaceProperties?.getAt(fireplaces[i])?.max_speed ?: 3, deviceState.fpfan_speed))
				if (deviceLight)
					if (deviceState.light == 1)
					else
			else
				if (deviceFan)
					deviceFan.sendEvent(name: "speed", value: "off")
				if (deviceLight)
	if (shades != null)
			def deviceState = getState(shade)
				continue
			def device = findChildDevice(shade)
			if (deviceState.open == 1)
				device.sendEvent(name: "windowShade", value: "open")
			else
				device.sendEvent(name: "windowShade", value: "close")
			def deviceState = getState(generic)
				continue
			def device = findChildDevice(generic)
			else
def handleOn(device) {
	def bondId = getBondIdFromDevice(device)
	logDebug "Handling On event for ${bondId}"
    if (executeAction(bondId, "TurnOn") && shouldSendEvent(bondId))
def handleLightOn(device) {
    logDebug "Handling Light On event for ${bondId}"
	if (device.deviceNetworkId.contains("uplight"))
		if (executeAction(bondId, "TurnUpLightOn"))
	else if (device.deviceNetworkId.contains("downlight"))
		if (executeAction(bondId, "TurnDownLightOn"))
    else
        if (executeAction(bondId, "TurnLightOn"))
def handleLightOff(device) {
    logDebug "Handling Light Off event for ${bondId}"
		if (executeAction(bondId, "TurnUpLightOff"))
		if (executeAction(bondId, "TurnDownLightOff"))
    else
        if (executeAction(bondId, "TurnLightOff"))
def handleDim(device, duration)
		dimUsingTimer(device, bondId, duration, "StartUpLightDimmer")
		dimUsingTimer(device, bondId, duration, "StartDownLightDimmer")
	else
		dimUsingTimer(device, bondId, duration, "StartDimmer")
def dimUsingTimer(device, duration, command)
	if (executeAction(bondId, command))
		runInMillis((duration*1000).toInteger(), stopDimmer, [data: [device: device, bondId: bondId]])
def stopDimmer(data)
	executeAction(data.bondId, "Stop")
def handleStartDimming(device)
		executeAction(bondId, "StartUpLightDimmer")
		executeAction(bondId, "StartDownLightDimmer")
	else
		executeAction(bondId, "StartDimmer")
def handleStopDimming(device)
	executeAction(bondId, "Stop")
def handleLightLevel(device, level) {
	logDebug "Handling Light Level event for ${bondId}"
		if (executeAction(bondId, "SetUpLightBrightness", level))
			device.sendEvent(name: "level", value: level)
		if (executeAction(bondId, "SetDownLightBrightness", level))
    else
		if (executeAction(bondId, "SetBrightness", level))
def handleSetFlame(device, height)
	logDebug "Handling Flame event for ${bondId}"
	if (height == "off")
		if (handleOff(device))
	else
		def flameHeight = 0
		if (height == "low")
			flameHeight = 1
		else if (height == "medium")
			flameHeight = 50
		else if (height == "high")
			flameHeight = 100
		if (executeAction(bondId, "SetFlame", flameHeight))
			device.sendEvent(name: "flame", value: height)
def handleOpen(device)
	logDebug "Handling Open event for ${bondId}"
    if (executeAction(bondId, "Open"))
def handleOpenNext(device)
    if (executeAction(bondId, "OpenNext"))
def handleClose(device)
	logDebug "Handling Close event for ${bondId}"
    if (executeAction(bondId, "Close"))
        device.sendEvent(name: "windowShade", value: "closed")
def handleCloseNext(device)
    if (executeAction(bondId, "CloseNext"))
def handleStop(device)
	logDebug "Handling Stop event for ${bondId}"
    executeAction(bondId, "Hold")
def handlePreset(device)
	logDebug "Handling Preset event for ${bondId}"
    executeAction(bondId, "Preset")
def fixPowerState(device, state)
	logDebug "Setting power state for ${bondId} to ${state}"
	def power
	if (state == "on")
		power = 1
	else
		power = 0
	if (executeFixState(bondId, '{"power": ' + power + '}'))
		if (power == 1)
		else
			if (device.hasAttribute("speed"))
			if (device.hasAttribute("flame"))
def fixFlameState(device, state)
	logDebug "Setting flame state for ${bondId} to ${state}"
	def flameHeight = 0
		flameHeight = 1
		flameHeight = 50
		flameHeight = 100
	if (executeFixState(bondId, '{"flame": ' + flameHeight + '}'))
def fixFanSpeed(device, fanState)
	def speed = translateHEFanSpeedToBond(bondId, state.fanProperties?.getAt(bondId)?.max_speed ?: 3, fanState)
	logDebug "Setting fan speed for ${bondId} to ${fanState}"
	if (fanState == "off")
		if (executeFixState(bondId, '{"power": 0}'))
	else
		if (executeFixState(bondId, '{"speed": ' + speed + '}'))
			device.sendEvent(name: "speed", value: fanState)
def fixShadeState(device, state)
	logDebug "Setting shade state for ${bondId} to ${state}"
	def open
	if (state == "open")
		open = 1
	else
		open = 0
	if (executeFixState(bondId, '{"open": ' + open + '}'))
		if (open == 1)
		else
def fixDirection(device, state)
	logDebug "Setting direction state for ${bondId} to ${state}"
	def direction
	if (state == "forward")
		direction = 1
	else
		direction = -1
	if (executeFixState(bondId, '{"direction": ' + direction + '}'))
		if (direction == 1)
		else
def fixFPFanPower(device, state)
	logDebug "Setting FP fan power state for ${bondId} to ${state}"
	def fppower
	if (state == "on")
		fppower = 1
	else
		fppower = 0
	if (executeFixState(bondId, '{"fpfan_power": ' + fppower + '}'))
		if (fppower == 1)
			device.sendEvent(name: "speed", value: "on")
		else
def fixFPFanSpeed(device, fanState)
	logDebug "Setting FP fan speed state for ${bondId} to ${fanState}"
	def speed = translateHEFanSpeedToBond(bondId, state.fireplaceProperties?.getAt(bondId)?.max_speed ?: 3, fanState)
		if (executeFixState(bondId, '{"fpfan_power": 0}'))
	else
		if (executeFixState(bondId, '{"fpfan_speed": ' + speed + '}'))
def fixLightPower(device, state) {
    logDebug "Setting light state for ${bondId} to ${state}"
	def power
	if (state == "on")
		power = 1
	else
		power = 0
		if (executeFixState(bondId, '{"up_light": ' + power + '}'))
			device.sendEvent(name: "switch", value: state)
		if (executeFixState(bondId, '{"down_light": ' + power + '}'))
    else
        if (executeFixState(bondId, '{"light": ' + power + '}'))
def fixLightLevel(device, state) {
	logDebug "Setting light level for ${bondId} to ${state}"
		if (executeFixState(bondId, '{"up_light_brightness": ' + state + '}'))
			device.sendEvent(name: "level", value: state)
		if (state == 0)
			if (executeFixState(bondId, '{"up_light": 0}'))
		if (executeFixState(bondId, '{"down_light_brightness": ' + state + '}'))
		if (state == 0)
			if (executeFixState(bondId, '{"down_light": 0}'))
    else
		if (executeFixState(bondId, '{"brightness": ' + state + '}'))
		if (state == 0)
			if (executeFixState(bondId, '{"light": 0}'))
def translateBondFanSpeedToHE(id, max_speeds, speed)
	def speedTranslations =
		10: [10: "high", 9: "high", 8: "medium-high", 7: "medium-high", 6: "medium", 5: "medium", 4: "medium-low", 3: "medium-low", 2: 1, 1: "low"],
		9: [9: "high", 8: "medium-high", 7: "medium-high", 6: "medium", 5: "medium", 4: "medium-low", 3: "medium-low", 2: "low", 1: "low"],
		8: [8: "high", 7: "medium-high", 6: "medium-high", 5: "medium", 4: "medium", 3: "medium-low", 2: "medium-low", 1: "low"],
		7: [7: "high", 6: "medium-high", 5: "medium", 4: "medium", 3: "medium-low", 2: "medium-low", 1: "low"],
		6: [6: "high", 5: "medium-high", 4: "medium", 3: "medium", 2: "medium-low", 1: "low"],
		5: [5: "high", 4: "medium-high", 3: "medium", 2: "medium-low", 1: "low"],
		4: [4: "high", 3: "medium", 2: "medium-low", 1: "low"],
		3: [3: "high", 2: "medium", 1: "low"],
		2: [2: "high", 1: "low" ]
	if (!speed.toString().isNumber())
		return speed
	if (max_speeds > 10 || speed > max_speeds)
		return 0
	logDebug "${id} -> Translating ${speed}:${max_speeds} to HE ${speedTranslations[max_speeds][speed]}"
	return speedTranslations[max_speeds][speed]
def translateHEFanSpeedToBond(id, max_speeds, speed)
	if (speed.isNumber())
		return speed.toInteger()
		10: ["high": 10, "medium-high": 8, "medium": 5, "medium-low": 3, "low": 1],
		9: ["high": 9, "medium-high": 7, ":medium": 5, "medium-low": 3, "low": 1],
		8: ["high": 8, "medium-high": 6, "medium": 4, "medium-low": 3, "low": 1],
		7: ["high": 7, "medium-high": 6, "medium": 4, "medium-low": 3, "low": 1 ],
		6: ["high": 6, "medium-high": 5, "medium": 3, "medium-low": 2, "low": 1],
		5: ["high": 5, "medium-high": 4, "medium": 3, "medium-low": 2, "low": 1],
		4: ["high": 4, "medium": 3, "medium-low": 2, "low": 1],
		3: ["high": 3, "medium": 2, "low": 1],
		2: ["high": 2, "low": 1]
	if (max_speeds > 10)
		return null
	logDebug "${id} -> Translating ${speed}:${max_speeds} to BOND ${speedTranslations[max_speeds][speed]}"
def handleFanSpeed(device, speed) {
    logDebug "Handling Fan Speed event for ${bondId}"
	if (speed == "off")
	else if (speed == "on")
		handleOn(device)
    else
        if (executeAction(bondId, "SetSpeed", translateHEFanSpeedToBond(bondId, state.fanProperties?.getAt(bondId)?.max_speed ?: 3, speed)))
			device.sendEvent(name: "speed", value: speed)
def handleFPFanSpeed(device, speed) {
    logDebug "Handling Fireplace Fan Speed event for ${bondId}"
	if (speed == "off")
		handleFPFanOff(device)
		handleFPFanOn(device)
    else
        if (executeAction(bondId, "SetSpeed", translateHEFanSpeedToBond(bondId, state.fireplaceProperties?.getAt(bondId)?.max_speed ?: 3, speed)))
def handleFPFanOn(device) {
	logDebug "Handling Fan On event for ${bondId}"
    if (executeAction(bondId, "TurnFpFanOn"))
        return true
	return false
def handleFPFanOff(device) {
	logDebug "Handling Fan Off event for ${bondId}"
    if (executeAction(bondId, "TurnFpFanOff"))
        return true
	return false
def handleOff(device) {
	logDebug "Handling Off event for ${bondId}"
    if (executeAction(bondId, "TurnOff") && shouldSendEvent(bondId))
        if (device.hasCapability("FanControl"))
        return true
	return false
def handleDirection(device, direction)
	logDebug "Handling Direction event for ${bondId}"
    def bondDirection = 1
    if (direction == "reverse")
    bondDirection = -1
    if (executeAction(bondId, "SetDirection", bondDirection))
        device.sendEvent(name: "direction", value: direction)
def getState(bondId) {
	def params = [
		path: "/v2/devices/${bondId}/state",
	def stateToReturn = null
	try
			if (checkHttpResponse("getState", resp))
				stateToReturn = resp.data
	catch (java.net.NoRouteToHostException e) {
		//log.error "getState: connection to BOND hub appears to be down. No Route,Check if the IP is correct."
	catch (org.apache.http.conn.ConnectTimeoutException e)
		//log.error "getState: connection to BOND hub appears to be down. Timeout, Check if the IP is correct."
	catch (Exception e)
		checkHttpResponse("getState", e.getResponse())
	return stateToReturn
def hasAction(bondId, commandType) {
	logDebug "searching for ${commandType} for ${bondId}"
	def params = [
		path: "/v2/devices/${bondId}/actions",
	def commandToReturn = false
	try
			if (checkHttpResponse("hasAction", resp))
				for (commandId in resp.data) {
					if (commandId.key == "_")
						continue
					if (commandId.key == commandType) {
						logDebug "found command ${commandId.key} for ${bondId}"
						commandToReturn = true
						break
		log.error "executeFixState: connection to BOND hub appears to be down. Check if the IP is correct."
		log.error "hasAction: connection to BOND hub appears to be down. Check if the IP is correct."
	catch (Exception e)
		checkHttpResponse("hasAction", e.getResponse())
	return commandToReturn
def executeAction(bondId, action) {
	def params = [
		path: "/v2/devices/${bondId}/actions/${action}",
		headers: [ 'BOND-Token': hubToken ],
		body: "{}"
	def isSuccessful = false
	logDebug "${bondId} -> calling action ${action}"
	try
		httpPut(params) { resp ->
			isSuccessful = checkHttpResponse("executeAction", resp)
		log.error "executeAction: connection to BOND hub appears to be down. Check if the IP is correct."
	catch (Exception e)
		checkHttpResponse("executeAction", e.getResponse())
	return isSuccessful
def executeAction(bondId, action, argument) {
	def params = [
		body: '{"argument": ' + argument +'}'
	logDebug "calling action ${action} ${params.body}"
	try
	catch (Exception e)
	return isSuccessful
def executeFixState(bondId, body) {
	def params = [
		body: body
	logDebug "calling fix state ${params.body}"
	try
		httpPatch(params) { resp ->
			isSuccessful = checkHttpResponse("executeFixState", resp)
	catch (Exception e)
		checkHttpResponse("executeFixState", e.getResponse())
	return isSuccessful
def shouldSendEvent(bondId) {
	for (fan in fans)
		if (fan == bondId)
			return true;
			if (fireplaces[i] == bondId)
					return false;
				return true;
	return true;
def logDebug(msg) {
    if (settings?.debugOutput) {
		log.debug msg
def checkHttpResponse(action, resp) {
	if (resp.status == 200 || resp.status == 201 || resp.status == 204)
		return true
	else if (resp.status == 400 || resp.status == 401 || resp.status == 404 || resp.status == 409 || resp.status == 500)
		log.error "${action}: ${resp.status} - ${resp.getData()}"
		return false
	else
		log.error "${action}: unexpected HTTP response: ${resp.status}"
		return false
def displayFooter(){
	section() {
		paragraph getFormat("line")
		paragraph "<div style='color:#1A77C9;text-align:center'>BOND Home Integration<br><a href='https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7LBRPJRLJSDDN&source=url' target='_blank'><img src='https://www.paypalobjects.com/webstatic/mktg/logo/pp_cc_mark_37x23.jpg' border='0' alt='PayPal Logo'></a><br><br>Please consider donating. This app took a lot of work to make.<br>If you find it valuable, I'd certainly appreciate it!</div>"
def getFormat(type, myText=""){			// Modified from @Stephack Code
    if(type == "line") return "<hr style='background-color:#1A77C9; height: 1px; border: 0;'>"
    if(type == "title") return "<h2 style='color:#1A77C9;font-weight: bold'>${myText}</h2>"
I also had to modify the BOND Motorized Shade driver code, see below. I define two routines raise and lower and added corresponding controls. Raise takes the shade to the next up setpoint and lower takes it to the next down setpoint.
 *  BOND Motorized Shade
metadata {
    definition (
		name: "BOND Motorized Shade",
		namespace: "bond",
		author: "dmeglio@gmail.com",
		importUrl: "https://raw.githubusercontent.com/dcmeglio/hubitat-bond/master/drivers/BOND_Motorized_Shade.groovy"
        capability "WindowShade"
		capability "Switch"
        command "stop"
        command "fixShade", [[name:"Shade*", type: "ENUM", description: "Shade", constraints: ["open","close"] ] ]
	    command "toggle"
	    command "lower"
	    command "raise"
def open() {
	parent.handleOpen(device)
def raise() {
	parent.handleOpenNext(device)
def close() {
	parent.handleClose(device)
def lower() {
	parent.handleCloseNext(device)
def on() {
	open()
def off() {
	close()
def toggle() {
	if (device.currentValue("windowShade") == "open")
		close()
	else
		open()
def stop() {
	parent.handleStop(device)
def fixShade(shade) {
	parent.fixShadeState(device, shade)
def setPosition(Number position) {
    if (position == 0) {
        log.info "position special value 0 is set, trigger CLose command"
        close()
    } else if (position == 50) {
        log.info "position special value 50 is set, triggering Preset command"
        parent.handlePreset(device)
    } else if (position == 100) {
        log.info "position special value 100 is set, triggering Open command"
        open()
    } else {
        log.info "no-op for position value " + position + ", set position to 50 to trigger Preset command"
I miss Dominick Meglio. He contributed so much to the Hubitat platform and made it a better place.
