Anyone else having issues with the Hubitat web interface after upgrading to Big Sur/Safari 14.0.1? I've had to use Chorme or Firefox since upgrading because of buttons (like the the done button on apps) and drop downs (like the type drop down under device info) not working.
I did a clean install and manually moved my files back. A big break in tradition for me. My old MBA 2013 is running better than it ever has before. True multi-tasking, with all the memory hogs open and the fan isn't even running. No beach balls. It's fast. Wasn't expecting to like it as much as I do.
Yes, but that controls the transparency of the dock as well as the menu bar. I like the dock transparency. It would be much better to have them independent.
Another menu bar tip: if you have a lot of menu bar icons the utility called Bartender works great and is even more useful with the new extra space between icons.
If you select Accessibility > Display > Color Filters > Filter Type: Color Tint, then you can click on the color swatch and choose how you want to adjust it. Might get it to something you like better.
