Was thinking about implementing some sort of fan into my ecosystem, can the degrees be used? Instead of oscillate, can it be turned to X degrees then do X?
You can use Hubitat to change fan speeds based on temperature via Rule Machine. Most BAF fans have Auto functionality built in that does the same thing. I'd suggest trying the fan's built-in functionality before trying to do something in Hubitat.
This thread is about Big ■■■ Fans, you should start a new thread including more details of the fan and how the fan is meant to be controlled - API, Matter, Zigbee, Z-Wave, Bluetooth
