I noticed a small interface inconsistency in RM today, specifically using the offsets on 'Between Two Times' conditions.
The offset fields correctly interpret -120 as 120 minutes before the selected condition (e.g. Sunset), but though the field test indicates +/- for the field, +120 isn't accepted, with the error checking text indicating I need a Number in the field.
It seems to me that if it process the negative sign then it should process the + sign as well, even if it just discards it. It's a silly thing, as 120 is implicitly a positive number, but the visual clues (help text) in the interface imply that a + sign is needed, yet chokes on it if you input it.
Clearly a trivial thing, and if it's been reported before, I apologize, I didn't see it anywhere....
Scott
