Done, although I'm bumping into an unexpected mismatch between what I pasted into the HTML text file:
<style>p{font-size:30;padding:10;color:green;background-color:<%604:variable%>;border:10 solid <%605:variable%>;}</style><p>
<b><%606:variable%></b></p>
and what is showing up in the template Preview:
<b>%606:variable%</b></p>
(I hard-returned before the <b> tag so you can spot the difference in the 2nd line, namely the angle brackets around the merge_key 606 are being dropped somehow.) Which means the literal string %606:variable% appears in the finished β and otherwise looking-as-expected β HTML render, instead of that variables value.
This has the knock-on effect of Template Manager ignoring the need for Device #606 to be included or watched. It only demands Devices #604 and #605 now (though I included #606 already anyway).
Is HE maybe stripping something during the upload (to File Manager) process?
Going to need to study this, but File Manager doesn't look at what's uploaded.
I round-tripped a couple more edits to the HTML text file, and found the safest bet seems to be following these steps:
- On HE, Settings > File Manage > click HTML file to download to PC
- Edit downloaded file in Notepad (Open with... in Windows Explorer)
- Save edited file without an extension
- Return to HE File Manage and delete original HTML file
- Click [+CHOOSE], pick HTML file in WinExp, click [UPLOAD]
That seems to be the (my) ticket to success. Now, my edits match! And a "Refresh Slot 1" back on the HTML Device reveals expected HTML render. #winning
How do I find the CSS attibutes (styles?) that I need to change the tile appearance for the presence tiles? How do I find how HE references the present or active states for certain devices vs the not-present or inactive states?
present/not present, active/inactive should be reported in the attributes presence and motion respectively. As for CSS, any standard CSS will work; if you want to know what HE is using there isn't a listing but if you sniff the headers on the UI you see 10-15 different files pulled in.
Please don't take this as a complaint. I love what you've done.
Is it normal for the app to be so "busy"? I'm seeing that this accounts for over 50% of busy time for my hub.
What's the % of total number? When fully loaded it can get a little busy as it is tracking every attribute change for the devices that it is tracking.
So ~3% thatβs about right.
I'm a newbie here, so please forgive any faux pas.
I have this custom template:
Status |
<%jobState%> |
Time Remaining |
<%timeRemaining%> |
I would like my dashboard to report the time remaining in minutes, rather than seconds.
How do I change it to divide by 60?
App only reads the device attributes, doesn't provide any way to manipulate
