@djgutheinz
Dave - not sure what might be happening but I am now having issues with my M3. Every once in a while (like 1 out of 5 times) I have the TTS announce through either Message Central or BigTalker2 I hear the Samsung M3 "The connection was successfully paired" right after an announcement. My thought is this could be the "resumeplay" feature. Thoughts on this? Logs below with the latest log having this phantom voice.
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:50.900 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:50.736 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:45.776 pm [info](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo: Track Description is .
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:45.774 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:45.683 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:43.449 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:43.440 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:43.337 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetFunc%3C/name%3E%3Cp%20type=%22str%22%20name=%22function%22%20val=%22wifi%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:43.321 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:43.318 pm [info](http://10.0.2.38/device/edit/346)restorePlayer: Restoring play to [level:80, inputsource:wifi]
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:35.601 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PausePlaybackEvent
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:35.589 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PausePlaybackEvent
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:35.587 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PausePlaybackEvent
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:31.513 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C![CDATA[http://10.0.2.38:8080/tts/28d26da56f9ab0ec00f4f2d12dde068d.mp3]]%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:31.507 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:31.294 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:31.293 pm [info](http://10.0.2.38/device/edit/346)playTrackAndResume: Resume = 0, Track = [uri:http://10.0.2.38:8080/tts/28d26da56f9ab0ec00f4f2d12dde068d.mp3, duration:6], Volume = 80
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:12.319 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:12.317 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:12.185 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetFunc%3C/name%3E%3Cp%20type=%22str%22%20name=%22function%22%20val=%22wifi%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:12.174 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:12.172 pm [info](http://10.0.2.38/device/edit/346)restorePlayer: Restoring play to [level:80, inputsource:wifi]
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:06.710 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:06.591 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:01.689 pm [info](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo: Track Description is .
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:01.686 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:01.535 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.559 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.555 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.400 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C![CDATA[http://10.0.2.38:8080/tts/40524ec7b14c9ed37804864fe61ebdeb.mp3]]%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.393 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.333 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlaybackStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.179 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:23:00.178 pm [info](http://10.0.2.38/device/edit/346)playTrackAndResume: Resume = 0, Track = [uri:http://10.0.2.38:8080/tts/40524ec7b14c9ed37804864fe61ebdeb.mp3, duration:6], Volume = 80
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.499 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PausePlaybackEvent
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.496 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.340 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C![CDATA[http://10.0.2.38:8080/tts/40524ec7b14c9ed37804864fe61ebdeb.mp3]]%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.330 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.277 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlaybackStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.112 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:22:51.108 pm [info](http://10.0.2.38/device/edit/346)playTrackAndResume: Resume = 0, Track = [uri:http://10.0.2.38:8080/tts/40524ec7b14c9ed37804864fe61ebdeb.mp3, duration:6], Volume = 80
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:12.319 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:12.200 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:10.726 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:10.002 pm [info](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo: Track Description is .
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:09.997 pm [info](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo: Track Description is .
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:09.996 pm [info](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo: Track Description is .
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:09.975 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:09.971 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:09.968 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:07.173 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:05.147 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:04.640 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:04.084 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:21:03.551 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:12.315 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:12.134 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:07.190 pm [info](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo: Track Description is .
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:07.187 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_RadioInfo
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:07.101 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:05.173 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_AcmMode
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:05.081 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:04.670 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:04.569 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:04.129 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:04.061 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:03.734 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:16:03.538 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:12.334 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlayStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:12.136 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetPlayStatus%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:09.524 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:09.510 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:09.499 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:07.107 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:05.081 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetAcmMode%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:04.570 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetVolume%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:04.063 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetFunc%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:11:03.542 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cname%3EGetMute%3C/name%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:08:07.544 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:08:07.540 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_CurrentFunc
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:08:00.356 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetFunc%3C/name%3E%3Cp%20type=%22str%22%20name=%22function%22%20val=%22wifi%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:08:00.345 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:08:00.343 pm [info](http://10.0.2.38/device/edit/346)restorePlayer: Restoring play to [level:80, inputsource:wifi]
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.760 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.755 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.556 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C![CDATA[http://10.0.2.38:8080/tts/9a15271d4d94dd8f6851bf10813cad53.mp3]]%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.550 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.416 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlaybackStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.334 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:48.333 pm [info](http://10.0.2.38/device/edit/346)playTrackAndResume: Resume = 0, Track = [uri:http://10.0.2.38:8080/tts/9a15271d4d94dd8f6851bf10813cad53.mp3, duration:6], Volume = 80
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:47.570 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:47.568 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:44.901 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetFunc%3C/name%3E%3Cp%20type=%22str%22%20name=%22function%22%20val=%22wifi%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:44.880 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:44.876 pm [info](http://10.0.2.38/device/edit/346)restorePlayer: Restoring play to [level:80, inputsource:wifi]
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:33.231 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_MuteStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:33.231 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:33.119 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C![CDATA[http://10.0.2.38:8080/tts/9a15271d4d94dd8f6851bf10813cad53.mp3]]%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:33.112 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:33.016 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlaybackStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.896 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.891 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_VolumeLevel
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.888 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.887 pm [info](http://10.0.2.38/device/edit/346)playTrackAndResume: Resume = 0, Track = [uri:http://10.0.2.38:8080/tts/9a15271d4d94dd8f6851bf10813cad53.mp3, duration:6], Volume = 80
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.762 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C![CDATA[http://10.0.2.38:8080/tts/9a15271d4d94dd8f6851bf10813cad53.mp3]]%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.749 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%2224%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.665 pm [debug](http://10.0.2.38/device/edit/346)generalResponse_PlaybackStatus
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.533 pm [debug](http://10.0.2.38/device/edit/346)sendCmd: Command= /CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E, Action = generalResponse
[dev:346](http://10.0.2.38/logs/past#dev346)2018-11-30 04:07:32.532 pm [info](http://10.0.2.38/device/edit/346)playTrackAndResume: Resume = 0, Track = [uri:http://10.0.2.38:8080/tts/9a15271d4d94dd8f6851bf10813cad53.mp3, duration:6], Volume = 80
