I've put together a combined driver that I use for a small list of these devices:
- Xiaomi Aqara Temperature Sensor : WSDCGQ11LM
- Xiaomi Aqara Vibration Sensor : DJT11LM
- Xiaomi Mijia Light Sensor : GZCGQ01LM
- Xiaomi Aqara Contact Sensor : MCCGQ11LM
- Xiaomi Aqara Wireless Single Remote Switch : WXKG03LM
- Xiaomi Aqara Motion Sensor : RTCGQ11LM
- Xiaomi Mijia Human Body Sensor : RTCGQ01LM
The driver may well work for other device hardware versions.
I know there are other drivers available but I put this together because I wanted to reduce the plethora of drivers for these devices and to simplify the code since the functionality of these devices are generally hard-coded in the firmware without the possibility of further configuration.
I've been running this driver for a couple of months now without any major issues. YMMV
You can either install the driver from the github repository below or use HPM.
Note: Some of the devices are not supported in depth. For example, the vibration sensor support is fairly basic and does not break down all of the available functionality of the device.
