Hi @dpasirst
I've added line 119:
def now = new Date()
you're using "now" in next line and it fails as it's not defined.
I did some more debug with the temperature and the "val" is "inside", as it's taken from the wrong field, I did some more digging and worked around it by modifying child driver as follows:
} else if (listener.definition_id == SensorTypes.TEMPERATURE) {
val = listener?.status_localized?.state
see listeners output below, it's different from what you have in child driver
[listeners: [
[configuration: [lower: 14.56, offset: 0.0, upper: 29.44], created_at: 2023 - 09 - 20 T03: 48: 13.824 Z, definition_id: 3, id: d6fb8514 - 9 a27 - 4963 - b3b5 - cdcdf751a700, insights: [freeze: [data_received_at: 2023 - 09 - 20 T03: 48: 13.824 Z, origin: [: ], value: ], mold_risk: [data_received_at: 2023 - 09 - 23 T02: 55: 20.516 Z, origin: [id: 4 c92adee - ca69 - 4819 - b36b - b9552700fad7, type: Sensor], value: low], primary: [data_received_at: 2023 - 12 - 11 T13: 23: 32.424 Z, origin: [id: 08 f80d96 - 5925 - 4403 - 87 ae - 7742489 dfc43, type: Sensor], value: inside]], model_version: 3.1, pro_monitoring_status: eligible, sensor_id: 799 ef575 - 4 c55 - 4 a9c - b992 - 21e898909 f6d, status_localized: [description: 9: 04 am, state: 26°], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 39: 12.367 Z, definition_id: 0, id: 3897 f985 - e2e9 - 4287 - 8 d35 - c9be199c1732, insights: [decay: [data_received_at: 2023 - 09 - 20 T03: 39: 12.367 Z, origin: [: ], value: ], primary: [data_received_at: 2023 - 09 - 20 T03: 39: 12.367 Z, origin: [: ], value: high]], model_version: 4.2, pro_monitoring_status: ineligible, sensor_id: 799 ef575 - 4 c55 - 4 a9c - b992 - 21e898909 f6d, status_localized: [description: Sep 20 at 11: 39 am, state: High], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 39: 12.390 Z, definition_id: 10, id: 83 c90e6a - 4 d0c - 4e43 - 9 d60 - 2681 a69d433f, insights: [primary: [data_received_at: 2023 - 12 - 08 T05: 06: 12.775 Z, origin: [id: 0454 ffaa - 724 a - 4683 - 832 c - b90c3ae2b9d1, type: Sensor], value: not_missing]], model_version: 2.1, pro_monitoring_status: ineligible, sensor_id: 799 ef575 - 4 c55 - 4 a9c - b992 - 21e898909 f6d, status_localized: [description: Dec 8 at 1: 06 pm, state: Connected], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 39: 12.417 Z, definition_id: 24, id: 3 a5cdfa0 - f2ac - 4070 - b164 - 55e66 ab0d2dd, insights: [primary: [data_received_at: 2023 - 09 - 20 T03: 39: 12.417 Z, origin: [: ], value: idle]], model_version: 1.0, pro_monitoring_status: ineligible, sensor_id: 799 ef575 - 4 c55 - 4 a9c - b992 - 21e898909 f6d, status_localized: [description: Sep 20 at 11: 39 am, state: Idle], type: sensor],
[configuration: [lifecycle_state: [calibrated_at: 2023 - 09 - 20 T03: 45: 43.413 Z], orientation: horizontal], created_at: 2023 - 09 - 20 T03: 44: 12.798 Z, definition_id: 13, id: 02 ec9e78 - 79 b4 - 406 a - be48 - 1 b617bd4df3c, insights: [primary: [data_received_at: 2023 - 12 - 12 T01: 01: 52.716 Z, origin: [id: 66 c1fe77 - a800 - 43 b0 - 8 a7c - ee7cc346c052, type: Sensor], value: closed]], model_version: 3.3, pro_monitoring_status: eligible, sensor_id: 799 ef575 - 4 c55 - 4 a9c - b992 - 21e898909 f6d, status_localized: [description: 9: 01 am, state: Closed], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T02: 48: 00.867 Z, definition_id: 10, id: ff54e544 - 0b 33 - 43 d5 - a9a8 - 03 a5ea30b088, insights: [primary: [data_received_at: 2023 - 12 - 08 T05: 06: 37.374 Z, origin: [id: 550 afbb3 - 2 b17 - 424 a - 90 f9 - 17 bc1fe8114c, type: Sensor], value: not_missing]], model_version: 2.1, pro_monitoring_status: ineligible, sensor_id: 7 dfeaca1 - 4544 - 46 a5 - a40c - 954 b331615ef, status_localized: [description: Dec 8 at 1: 06 pm, state: Connected], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T02: 48: 00.891 Z, definition_id: 24, id: c223852f - 23 c6 - 41 d1 - 8 d33 - dae05a72f91e, insights: [primary: [data_received_at: 2023 - 09 - 20 T02: 48: 00.891 Z, origin: [: ], value: idle]], model_version: 1.0, pro_monitoring_status: ineligible, sensor_id: 7 dfeaca1 - 4544 - 46 a5 - a40c - 954 b331615ef, status_localized: [description: Sep 20 at 10: 48 am, state: Idle], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T02: 48: 00.839 Z, definition_id: 0, id: 2 a3a0522 - df54 - 4612 - b6bd - 621 f21178993, insights: [decay: [data_received_at: 2023 - 09 - 20 T02: 48: 00.839 Z, origin: [: ], value: ], primary: [data_received_at: 2023 - 11 - 21 T02: 07: 53.802 Z, origin: [id: a3450dd5 - d0cc - 4e2 d - 826 c - 1 aa0980727fa, type: Sensor], value: medium]], model_version: 4.2, pro_monitoring_status: ineligible, sensor_id: 7 dfeaca1 - 4544 - 46 a5 - a40c - 954 b331615ef, status_localized: [description: Nov 21 at 10: 07 am, state: Medium], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T02: 48: 46.939 Z, definition_id: 7, id: 9349740 a - 6987 - 49 ec - a9a4 - 18 ee1e4900a6, insights: [primary: [data_received_at: 2023 - 09 - 20 T02: 50: 29.237 Z, origin: [id: 09 aaca68 - a76f - 4059 - a3e2 - 8335 b94b59af, type: Chronal], value: no_alarm]], model_version: 3.1, pro_monitoring_status: eligible, sensor_id: 7 dfeaca1 - 4544 - 46 a5 - a40c - 954 b331615ef, status_localized: [description: Sep 20 at 10: 50 am, state: No Sound], type: sensor],
[configuration: [lower: 15.56, offset: 0.0, upper: 29.44], created_at: 2023 - 09 - 20 T03: 32: 29.536 Z, definition_id: 3, id: e9b5f265 - 2 ba5 - 4633 - 8625 - a801544cb88e, insights: [freeze: [data_received_at: 2023 - 09 - 20 T03: 32: 29.536 Z, origin: [: ], value: ], mold_risk: [data_received_at: 2023 - 09 - 23 T03: 11: 44.892 Z, origin: [id: 4 da4060e - 26 d8 - 4649 - a62f - e9144917c2d4, type: Sensor], value: low], primary: [data_received_at: 2023 - 09 - 20 T03: 32: 29.536 Z, origin: [: ], value: upper]], model_version: 3.1, pro_monitoring_status: eligible, sensor_id: 7 dfeaca1 - 4544 - 46 a5 - a40c - 954 b331615ef, status_localized: [description: 9: 03 am, state: 24°], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 02: 16.582 Z, definition_id: 0, id: eaafabe7 - 0 fcc - 4351 - 9 b8f - cdf973596902, insights: [decay: [data_received_at: 2023 - 09 - 20 T03: 02: 16.582 Z, origin: [: ], value: ], primary: [data_received_at: 2023 - 09 - 20 T03: 02: 16.582 Z, origin: [: ], value: high]], model_version: 4.2, pro_monitoring_status: ineligible, sensor_id: fee95a15 - eaad - 4270 - b10e - 6327 cdff6d30, status_localized: [description: Sep 20 at 11: 02 am, state: High], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 02: 16.615 Z, definition_id: 10, id: 106 b5b9d - 0 f48 - 4 eca - ac20 - 5695 f9f9c8ed, insights: [primary: [data_received_at: 2023 - 12 - 08 T05: 07: 18.387 Z, origin: [id: 6 d50d3bc - c01d - 4947 - 9 b18 - 4 f47e7fd0710, type: Sensor], value: not_missing]], model_version: 2.1, pro_monitoring_status: ineligible, sensor_id: fee95a15 - eaad - 4270 - b10e - 6327 cdff6d30, status_localized: [description: Dec 8 at 1: 07 pm, state: Connected], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 02: 16.636 Z, definition_id: 24, id: df860493 - 9695 - 4213 - b135 - 19 f3ac1775c7, insights: [primary: [data_received_at: 2023 - 09 - 20 T03: 02: 16.636 Z, origin: [: ], value: idle]], model_version: 1.0, pro_monitoring_status: ineligible, sensor_id: fee95a15 - eaad - 4270 - b10e - 6327 cdff6d30, status_localized: [description: Sep 20 at 11: 02 am, state: Idle], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 03: 11.391 Z, definition_id: 4, id: 1 c85ec70 - 4 afd - 4462 - 84 d7 - 98038672e25 e, insights: [primary: [data_received_at: 2023 - 09 - 20 T03: 14: 41.654 Z, origin: [id: e4606511 - dcc1 - 4 d1d - ab02 - bf136f251a12, type: Sensor], value: no_leak]], model_version: 2.3, pro_monitoring_status: eligible, sensor_id: fee95a15 - eaad - 4270 - b10e - 6327 cdff6d30, status_localized: [description: Sep 20 at 11: 14 am, state: No Leak], type: sensor],
[configuration: [: ], created_at: 2023 - 09 - 20 T03: 30: 58.775 Z, definition_id: 2, id: f6421106 - 1 eac - 412 b - 88e5 - 3885e1 d509b8, insights: [primary: [data_received_at: 2023 - 09 - 23 T04: 35: 30.980 Z, origin: [id: 0 f2afc61 - 033e-4 fe4 - baf3 - 4 c76dc062410, type: Sensor], value: low]], model_version: 1.1, pro_monitoring_status: ineligible, sensor_id: fee95a15 - eaad - 4270 - b10e - 6327 cdff6d30, status_localized: [description: 8: 06 am, state: Low], type: sensor]
