[BETA] NATIVE Broadlink RM/RM Pro/RM Mini/SP driver
Broadlink RM/RM Pro/RM Mini/SP driver (BETA)
Features:
  • Supports sending Broadlink IR Codes (on RM/RM Pro/ RM Mini devices)
    • (HEX string encoded and Base64 encoded)
  • Supports sending Broadlink RF Codes (on RM Pro devices)
  • Supports sending Pronto IR Codes (on RM/RM Pro/ RM Mini devices)
  • Learn IR Codes (on RM/RM Pro/ RM Mini devices)
  • Learn RF Codes (on RM Pro devices)
  • Relay/Switch on/off (on SP devices)
  • Temperature (on devices with embedded temperature sensors)
Before you begin:
  1. Make sure you hubitat is upgraded to Hubitat platform v2.1.7 or greater
  2. Make sure that your Broadlink device is on the same local network as the Hubitat. This is done by installing the device with the eControl or IHC app. This driver will co-exist with these apps.
  3. The IP Address of your Broadlink device. As there is not connection app (yet), you will need to determine the IP address of the device from your router. As with all WiFi smart home devices, it is recommended that you assign an static IP to the device (using DHCP reservation on your router).
NOTE: The driver does NOT connect to the broadlink cloud server, and only connects to the Broadlink directly at the IP address that you specify in the configuration.
Installing:
  1. On the web interface, go to "drivers code", then click on "New driver"
  2. Copy/Paste the driver code into the editor, then click "Save". This will create a user driver named "Broadlink (BETA)"
  3. Click on "Devices", then click "Add Virtual Device". On the device creation page, set "Device Name" to a unique name, and set "Type" to "Broadlink (BETA)", then click "Save Device".
  4. On the Device edit page, Enter the devices IP Address in "IP" under preferences and click "Save Preferences"
  5. Once the device edit page reloads, click on the "initialize" control, to configure the driver to the device. If all works, the driver will populate a deviceConfig attribute under current state.
At this point, the driver is functional. If your device has a temperature sensor or a relay/switch, the driver will poll the device every 5 minutes for status updates (This will be configurable in subsequent versions)
Learning IR Codes:
  1. Click on the LearnIR button.
  2. Within 30 seconds, point your remote at the device and press the button you wish to learn.
  3. If successful, the read code will be displayed in the "CODEDATA" attribute under "Current States" . You can copy the code for use in the "Send Code" control or in Rule Machine.
    NOTE: The "IR_Status" attribute displays instructions/status during the learn process
Learning RF Codes:
  1. Click on the "Learn RF control.
  2. Within 30 seconds, Press and hold the button you wish to learn.
  3. When Prompted (by the RF_Status attribute), release the button, then start pressing and releasing the button repeatedly.
  4. If successful, the read code will be displayed in the "CODEDATA" attribute under "Current States" . You can copy the code for use in the "Send Code" control or in Rule Machine.
    NOTE: The "RF_Status" attribute displays instructions/status during the learn process
  5. To test the code, click on the "SendLastCode" control. This control will send the last code that was learned from or sent to the device.
Sending IR/RF codes:
  1. Paste a previously learned or found IR or RF code into the "Send Code" control and click on it. This control will accept a code that is a HEX STRING or a Base64 encoded byte array (As used by Home Assistant and other platforms
    -OR-
  2. Paste a Pronto format code into the "Send Pronto Code" control and click.
    -OR-
  3. Create an action in Rule Machine to send a code. Select action type "Set Mode or Variables, Run Custom Action", then "Run Custom Action", then select "Actuator" under "Select capability of action device". Select your device in the list, choose "SendCode" or "SendProntoCode" as the action, select "string" as the parameter type, then paste the code into the "string value" field, then click "done with this action. You can also choose "SendStoredCode" ad specify the name of the stored code in the "string value" field.
Saving IR/RF Codes:
  1. Learn a code with the "learnIR" or "learnRF" control
    -or-
  2. paste a code into the "SendCode" or "SendProntoCode" control and click on the control.
  3. Enter a name for the code into the "StoreCode" control, and click on the control
Sending Stored IR/RF Codes:
  1. Enter the name of a stored code into the "SendStoredCode" control, and click on the control
    -OR-
  2. Create a Dashboard tile. Select the device that should send the code. Select the "Button" template. Enter the NAME of the stored code in the "Button Number" field.
Version History:
  • v0.17 : Initial public beta
  • v0.18: Fixed IR/RF learn data parsing when device response does not respond with a payload
  • v0.19: Fixed error in parseAuthData, added code management functions - StoreCode(), SendStoredCode(), SendLastCode
  • v0.20: Fix for unexpected IR Learn behaviour on RM Mini devices
  • v0.21: Verified fix for unexpected IR Learn behaviour on RM Mini devices
  • v0.22: Added support for sending code from a Dashboard
  • v0.23: fixed issue when driver crashes when used with RM3 Pro Plus
 *  Broadlink RM/RM Pro/RM Mini/SP driver for Hubitat
 *      by CybrMage
def version() {return "v0.23"}
import groovy.transform.Field
import groovy.json.JsonSlurper
import javax.crypto.Cipher
import javax.crypto.spec.SecretKeySpec
import javax.crypto.spec.IvParameterSpec
import java.util.Date
@Field static volatile byte[] AES_KEY = []
@Field static volatile byte[] INIT_VECTOR = []
@Field static volatile long LEARN = 0
preferences {
	input("destIp", "text", title: "IP", description: "The IP Address of the Broadlink device",required:true)
	input ("logDebug", "bool", title: "Enable debug logging", defaultValue: true)
	input ("verboseDebug", "bool", title: "Enable verbose debug logging", defaultValue: true)
metadata {
	definition (name: "Broadlink (BETA)", namespace: "cybr", author: "CybrMage") {
		capability "Actuator"
		capability "Initialize"
		capability "Switch"
		capability "TemperatureMeasurement"
		attribute "deviceConfig", "object"
		attribute "IR_Status", "string"
		attribute "RF_Status", "string"
		command "getStatus"
		command "reset"
		command "SendCode", [[name: "Code*", type:"STRING", description: "Enter Broadlink Code Data"]]
		command "SendProntoCode", [[name: "Code*", type:"STRING", description: "Enter Pronto Code Data"]]
		command "learnIR"
		command "learnRF"
		command "StoreCode", [[name: "Name*", type:"STRING", description: "Enter Name for stored code data"]]
		command "SendStoredCode", [[name: "Name*", type:"STRING", description: "Enter Name for stored code data to send"]]
		command "SendLastCode"
		command "push", [[name: "Name*", type:"STRING", description: "Enter Name for stored code button"]]
// AES CBC methods
def AES_setKey(String newKey) {
	// convert hex encoded string to string
	if ((newKey == null) || (newKey == "")) {newKey = "097628343fe99e23765c1513accf8b02"}
	AES_KEY = hubitat.helper.HexUtils.hexStringToByteArray(newKey)
def AES_setIV(String newIV) {
	if ((newIV == null) || (newIV == "")) { newIV = "562e17996d093d28ddb3ba695a2e6f58" }
	INIT_VECTOR = hubitat.helper.HexUtils.hexStringToByteArray(newIV)
def AES_getKey() {
	// convert byte array to hex encoded string
	return hubitat.helper.HexUtils.byteArrayToHexString(AES_KEY)
def AES_getIV() {
	// convert string to hex encoded string
	return hubitat.helper.HexUtils.byteArrayToHexString(INIT_VECTOR)
def byte [] AES_Encrypt(value) {
    try {
        IvParameterSpec iv = new IvParameterSpec(INIT_VECTOR)
        SecretKeySpec skeySpec = new SecretKeySpec(AES_KEY, "AES")
		Cipher cipher = Cipher.getInstance("AES/CBC/NoPadding")
        cipher.init(Cipher.ENCRYPT_MODE, skeySpec, iv)
		if (value instanceof List) { value = arrayListToByteArray(value) }
		if (value instanceof String) { value = value.getBytes() }
		log_debug("AES_Encrypt(\"${hubitat.helper.HexUtils.byteArrayToHexString(value)}\")")
        byte[] encrypted = cipher.doFinal(value)
		log_debug("  ENCRYPTED(\"${hubitat.helper.HexUtils.byteArrayToHexString(encrypted)}\")")
        return encrypted
//        return encrypted.encodeBase64()
    } catch (e) {
		log_debug("AES_Encrypt: Caught Execption [${e}]")
    return null;
def byte [] AES_Decrypt(encrypted) {
    try {
        cipher.init(Cipher.DECRYPT_MODE, skeySpec, iv)
		if (encrypted instanceof List) { encrypted = arrayListToByteArray(encrypted) }
		if (encrypted instanceof String) { encrypted = encrypted.getBytes() }
		log_debug("AES_Decrypt(\"${hubitat.helper.HexUtils.byteArrayToHexString(encrypted)}\")")
        byte[] original = cipher.doFinal(encrypted)
		log_debug("  DECRYPTED(\"${hubitat.helper.HexUtils.byteArrayToHexString(original)}\")")
        return original
    } catch (e) {
		log_debug("AES_Decrypt: Caught Execption [${e}]")
    return null
// driver framework functions
def initialize() {
	unschedule()
	if (logDebug == null) {
		logDebug =  true
		device.updateSetting("logDebug",logDebug)
	if (verboseDebug == null) {
		verboseDebug = true
		device.updateSetting("verboseDebug",verboseDebug)
	// set the initial Broadlink key and IV
	AES_setKey("097628343fe99e23765c1513accf8b02")
	AES_setIV("562e17996d093d28ddb3ba695a2e6f58")
	log.debug("initialize - DEBUG [${logDebug}]  VERBOSE [${verboseDebug}]  KEY [${hubitat.helper.HexUtils.byteArrayToHexString(AES_KEY)}]  IV [${hubitat.helper.HexUtils.byteArrayToHexString(INIT_VECTOR)}]")
	// If the IP address is not set, there is nothing to do...
	if ((destIp == null)||(destIp == "")) {
		log_error("initialize - ERROR - Device IP Address not set")
		return
	// set the deviceNetworkIdentifier. Ideally, this should be the MAC address of the device
	// If the MAC can not be determined, use the IP address
	def deviceMAC = null
	def macTries = 0
	while ((macTries < 5) && (deviceMAC == null)) {
		macTries++
		deviceMAC = getMACFromIP(destIp)
		if (deviceMAC == null) {
			log_info("initialize - Device MAC address not yet available. Retry in 1 second.")
			pauseExecution(1000)
	if (deviceMAC != null) {
		device.deviceNetworkId = "$deviceMAC"
	} else {
		device.deviceNetworkId = convertIPtoHex(destIp)
	log_info("initialize - Set DNI = [${device.deviceNetworkId}]")
	state.packetCount = 0
	state.deviceConfig = null
	def cData = device.latestValue("deviceConfig")
	if ((cData == null) ||(cData == "") ||(cData == "[]")) {} else {state.deviceConfig = new JsonSlurper().parseText(cData)}
	if (state.deviceConfig == null) {
		// the device has not been "discovered" (has been manually added)
		log_error("initialize - ERROR - Device has not been configured")
		getDeviceConfig()
	} else {
		log.debug("initialize - CONFIGURED - deviceConfig [${state.deviceConfig}]")
		sendEvent(name: "IR_Status", value: "IDLE", displayed:false, isStateChange: true)
		sendEvent(name: "RF_Status", value: "IDLE", displayed:false, isStateChange: true)
		getStatus()
		if (state.deviceConfig.hasAuth && ((state.deviceConfig.hasTemp == true) || (state.deviceConfig.relayCount != 0))) {
			runEvery5Minutes("getStatus")
	return null
def updated() {
	log_debug("updated - DEBUG [${logDebug}]  VERBOSE [${verboseDebug}]")
	initialize()
def installed() {
	log_debug("installed")
def reset() {
	log_debug("reset - DEBUG [${logDebug}]  VERBOSE [${verboseDebug}] - Reseting device configuration")
	sendEvent(name: "deviceConfig", value: [], displayed:false, isStateChange: true)
def log_debug(debugData) {
	if (logDebug) log.debug("${device.name} - " + debugData)
def log_warn(debugData) {
	if (logDebug) log.warn("${device.name} - " + debugData)
def log_info(debugData) {
	if (verboseDebug) log_debug(debugData)
private log_error(debugData) {
	log.error("${device.name} - " + debugData)
private String convertIPtoHex(ipAddress) {
	String hex = ipAddress.tokenize( '.' ).collect {  String.format( '%02X', it.toInteger() ) }.join()
	return hex
private String convertPortToHex(port) {
	String hexport = port.toString().format( '%04X', port.toInteger() )
	return hexport
// Broadlink specific functions
def on() {
	setTarget(state.deviceConfig, true)
def off() {
	setTarget(state.deviceConfig, false)
def getStatus() {
	log_debug("getStatus:  deviceConfig [${state.deviceConfig}]  AUTH [${state.deviceConfig.hasAuth}]")
//		state.deviceConfig = getDeviceConfig()
	if ((state.deviceConfig.relayCount == 0) && (state.deviceConfig.hasTemp == false)) { return null }
	if (state.deviceConfig.hasTemp) {
		check_sensors()
	if (state.deviceConfig.relayCount == 0) {
		return null
	byte [] payload = [0x00, 0x00, 0x00, 0x00,0x00, 0x00, 0x00, 0x00,0x00, 0x00, 0x00, 0x00,0x00, 0x00, 0x00, 0x00]
	if (state.deviceConfig.relayCount == 4) {
		payload[0] = (byte) 0x0a
		payload[2] = (byte) 0xa5
		payload[3] = (byte) 0xa5
		payload[4] = (byte) 0x5a
		payload[5] = (byte) 0x5a
		payload[6] = (byte) 0xae
		payload[7] = (byte) 0xc0
		payload[8] = (byte) 0x01
	} else {
		payload[0] = (byte) 0x01
	def err = send_packet(state.deviceConfig, 0x6a, payload, "parseStatusData")
	return null
def check_sensors() {
	log_debug("check_sensors:  deviceConfig [${state.deviceConfig}]  AUTH [${state.deviceConfig.hasAuth}]")
	if (state.deviceConfig.hasTemp == false) { return true }
	byte [] payload = [0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
	def err = send_packet(state.deviceConfig, 0x6a, payload, "parseSensorData")
def getDeviceConfig() {
	state.deviceConfig = []
	getDiscoveryData(destIp)
def getString(str) {
	def rStr = ""
	def gotNull = false
	str.eachWithIndex { it, i ->
		if ((it < 1) || (it > 0x7F)) { gotNull = true }
		if (gotNull == false) { rStr = rStr + new String(it) }
//	log_debug("getString() = \"${rStr}\"")
	return rStr
private byte [] arrayListToByteArray(aList) {
	String hex = aList.collect {  String.format( '%02X', (it.toInteger() < 0) ? (it.toInteger() + 256) : it.toInteger()) }.join()
	byte [] bArray = hubitat.helper.HexUtils.hexStringToByteArray(hex)
	return bArray
private String arrayListToHexString(aList) {
	return hex
private String decodeHexIP(IP) {
	def dotted = hubitat.helper.HexUtils.hexStringToByteArray(IP).collect {  String.format( '%s', (it.toInteger() < 0) ? (it.toInteger() + 256) : it.toInteger()) }.join(".")
	return dotted
def getDeviceTypeInfo(devtype) {
	log_debug("getDeviceTypeInfo(${devtype})")
	def isPro = false
	def hasTemp = false
	def hasIR = false
	def relayCount = 0
	def devTypeName = "unknown (0x"+String.format("%04x",devtype)+")"
	if (devtype == 0) { devTypeName = "SP1"; hasIR = false; isPro = false; hasTemp = false; relayCount = -1 }
	else if (devtype == 0x13b) { devTypeName = "RM315"; hasIR = false; isPro = true;  hasTemp = false}
	else if (devtype == 0x1b1) { devTypeName = "RM433"; hasIR = false; isPro = true;  hasTemp = false}
	else if (devtype == 0x26) { devTypeName = "RMIR"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x2710) { devTypeName = "RM1"; hasIR = true; isPro = false; hasTemp = true}
	else if (devtype == 0x2711) { devTypeName = "SP2"; hasIR = false; isPro = false; hasTemp = false}
	else if (devtype == 0x2712) { devTypeName = "RM2"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x2714) { devTypeName = "A1"; hasIR = false; isPro = false; hasTemp = false}
	else if ((devtype == 0x2719) || (devtype == 0x271a)) { devTypeName = "Honeywell SP2"; hasIR =false; isPro = false; hasTemp = false; relayCount = 1}
	else if (devtype == 0x271f) { devTypeName = "RM2 Home Plus"; hasIR = true; isPro = false; hasTemp = true}
	else if (devtype == 0x2720) { devTypeName = "SPMini"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if (devtype == 0x2728) { devTypeName = "SPMini2"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if (devtype == 0x272a) { devTypeName = "RM2 Pro Plus"; hasIR = true; isPro = true; hasTemp = true}
	else if ((devtype == 0x2733) || (devtype == 0x273e)) { devTypeName = "OEM branded SPMini"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if (devtype == 0x2736) { devTypeName = "SPMiniPlus"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if (devtype == 0x2737) { devTypeName = "RM Mini"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x273d) { devTypeName = "RM Pro Phicomm"; hasIR = true; isPro = true; hasTemp = true}
	else if (devtype == 0x277c) { devTypeName = "RM2 Home Plus GDT"; hasIR = true; isPro = false; hasTemp = true}
	else if (devtype == 0x2783) { devTypeName = "RM2 Home Plus"; hasIR = true; isPro = false; hasTemp = true}
	else if (devtype == 0x2787) { devTypeName = "RM2 Pro Plus2"; hasIR = true; isPro = true; hasTemp = true}
	else if (devtype == 0x278b) { devTypeName = "RM2 Pro Plus BL"; hasIR = true; isPro = true; hasTemp = true}
	else if (devtype == 0x278f) { devTypeName = "RM Mini Shate"; hasIR = true; isPro = false;  hasTemp = false}
	else if (devtype == 0x2797) { devTypeName = "RM2 Pro Plus HYC"; hasIR = true; isPro = true; hasTemp = true}
	else if (devtype == 0x279d) { devTypeName = "RM3 Pro Plus"; hasIR = true; isPro = true; hasTemp = false}
	else if (devtype == 0x27a1) { devTypeName = "RM2 Pro Plus R1"; hasIR = true; isPro = true; hasTemp = false}
	else if (devtype == 0x27a2) { devTypeName = "RM Mini R2"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x27a6) { devTypeName = "RM2 Pro PP"; hasIR = true; isPro = true; hasTemp = true}
	else if (devtype == 0x27a9) { devTypeName = "RM2 Pro Plus 300 / RM3 Pro Plus v2 model 3422"; hasIR = true; isPro = true; hasTemp = false}
	else if (devtype == 0x27c2) { devTypeName = "RM Mini 3 B"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x27c7) { devTypeName = "RM Mini 3 A"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x27de) { devTypeName = "RM Mini 3 C"; hasIR = true; isPro = false; hasTemp = false}
	else if (devtype == 0x4EB5) { devTypeName = "MP1"; hasIR = false; isPro = false; hasTemp = false; relayCount = 4}
	else if (devtype == 0x5f36) { devTypeName = "RM Mini 3 D"; hasIR = true; isPro = false; hasTemp = false}
	else if ((devtype == 0x7530) || (devtype == 0x7918)) { devTypeName = "OEM branded SPMini2"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if (devtype == 0x753e) { devTypeName = "SP3"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if ((devtype > 0x752F) && (devtype < 0x7919)) { devTypeName = "OEM branded SPMini2"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	else if ((devtype == 0x7919) || (devtype == 0x791a)) { devTypeName = "Honeywell SP2"; hasIR = false; isPro = false; hasTemp = false; relayCount = 1}
	log_debug("return [devTypeName: ${devTypeName}, isPro: ${isPro}, hasIr: ${hasIR}, hasTemp: ${hasTemp}, relayCount: ${relayCount}]")
	return [devTypeName: devTypeName, isPro: isPro, hasIR: hasIR, hasTemp: hasTemp, relayCount: relayCount]
def getAuth(deviceConfig) {
	log_debug("getAuth: ip [${deviceConfig.IP}]")
	byte [] payload = [0x00, 0x00, 0x00, 0x00, 0x31, 0x31, 0x31, 0x31,
					   0x31, 0x31, 0x31, 0x31, 0x31, 0x31, 0x31, 0x31,
					   0x31, 0x31, 0x31, 0x00, 0x00, 0x00, 0x00, 0x00,
	payload[0x1e] = 0x01;
	payload[0x2d] = 0x01;
	payload[0x30] = (byte) 'T';
	payload[0x31] = (byte) 'e';
	payload[0x32] = (byte) 's';
	payload[0x33] = (byte) 't';
	payload[0x34] = (byte) ' ';
	payload[0x35] = (byte) ' ';
	payload[0x36] = (byte) '1';
	err = send_packet(deviceConfig, 0x65, payload, "parseAuthData")
	if (err) {
		return [true, "No response"]
def setTarget(deviceConfig, on) {
	log_debug("setTarget: ip [${deviceConfig.IP}]")
	if ((deviceConfig.relayCount == null) || (deviceConfig.hasIR == null) || (deviceConfig.isPro == null)) {
		def tInfo = getDeviceTypeInfo(deviceConfig.devType)
		deviceConfig.isPro = tInfo.isPro
		deviceConfig.hasIR = tInfo.hasIR
		deviceConfig.hasTemp = tInfo.hasTemp
		deviceConfig.relayCount = tInfo.relayCount
	TargetCMD = 0x6a
	if ((deviceConfig.relayCount == 0) || (deviceConfig.isPro == true) || (deviceConfig.hasIR == true)) {
		log_debug("setTarget: Device does not support this function")
		return nil
	byte [] payload = []
	if (deviceConfig.relayCount == -1) {
		TargetCMD = 0x66
		payload = [0x00, 0x00, 0x00, 0x00]
		payload[0] = on ? 1 : 0
	} else if (deviceConfig.relayCount == 1) {
		TargetCMD = 0x6a
		payload = [0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
		payload[0] = 2
		payload[4] = on ? 1 : 0
	send_packet(deviceConfig, TargetCMD, payload,"parseTargetResponse")
	return null
def getChecksum(packet) {
	def checksum = 0xbeaf
	for (i = 0; i < packet.size(); i++) {
		checksum = checksum + Byte.toUnsignedInt(packet[i])
		checksum = checksum  & 0xFFFF
	return checksum
def send_packet(deviceConfig, COMMAND, payload, callback = "parse") {
	log_debug("(send_packet) Called send_packet( 0x${deviceConfig.IP}, 0x${String.format("%02X",COMMAND)})")
	state.packetCount = (state.packetCount + 1) & 0xffff
	byte [] packet = [ 0x5a, 0xa5, 0xaa, 0x55, 0x5a, 0xa5, 0xaa, 0x55,
					   0x00, 0x00, 0x00, 0x00, 0x2a, 0x27, 0x00, 0x00,
	packet[0x26] = (byte) COMMAND
	packet[0x28] = (byte) (state.packetCount & 0xff)
	packet[0x29] = (byte) (state.packetCount >> 8)
	packet[0x2a] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.MAC[10,11])
	packet[0x2b] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.MAC[8..9])
	packet[0x2c] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.MAC[6..7])
	packet[0x2d] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.MAC[4..5])
	packet[0x2e] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.MAC[2..3])
	packet[0x2f] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.MAC[0..1])
	packet[0x30] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.internalID[0..1])
	packet[0x31] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.internalID[2..3])
	packet[0x32] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.internalID[4..5])
	packet[0x33] = (byte) hubitat.helper.HexUtils.hexStringToInt(deviceConfig.internalID[6..7])
	//pad the payload for AES encryption
	if (payload.size() > 0) {
		startIdx = payload.size()
		numpad = 16 - (payload.size() % 16)
		log_info("(send_packet) Called send_packet - Payload size = ${payload.size()} - ${numpad} bytes padding")
		def padding = "00" * numpad
		payload = hubitat.helper.HexUtils.hexStringToByteArray(hubitat.helper.HexUtils.byteArrayToHexString(payload) + padding)
		log_info("(send_packet) Called send_packet - Padded Payload size = ${payload.size()}")
		log_info("(send_packet) PADDED PAYLOAD [${hubitat.helper.HexUtils.byteArrayToHexString(payload)}]")
	def checksum = getChecksum(payload)
	packet[0x34] = (byte)(checksum & 0xff)
	packet[0x35] = (byte)(checksum >> 8)
	log_info("(send_packet) PACKET CHECKSUM ${String.format("0x%04X",checksum)}")
	byte [] ePayload = encryptPacket(deviceConfig, payload)
	log_info("(send_packet) payload ENCRYPTED")
	log_info("(send_packet) PACKET [${hubitat.helper.HexUtils.byteArrayToHexString(packet)}]")
	log_info("(send_packet) ENCRYPTED PAYLOAD [${hubitat.helper.HexUtils.byteArrayToHexString(ePayload)}]")
	packet = hubitat.helper.HexUtils.hexStringToByteArray(hubitat.helper.HexUtils.byteArrayToHexString(packet) + hubitat.helper.HexUtils.byteArrayToHexString(ePayload))
	log_info("(send_packet) PAYLOAD ADDED")
	checksum = getChecksum(packet)
	packet[0x20] = (byte)(checksum & 0xff)
	packet[0x21] = (byte)(checksum >> 8)
	log_info("(send_packet) PACKET + PAYLOAD CHECKSUM ${String.format("0x%04X",checksum)}")
	log_info("(send_packet) FULL [${hubitat.helper.HexUtils.byteArrayToHexString(packet)}]")
	def sendError = sendMessage(deviceConfig, packet, callback)
	if (sendError) {return true}
	return false
def sendMessage(deviceConfig, packet, callback = "parse") {
	log_debug("(sendMessage) Called sendMessage(${deviceConfig.IP})")
	def packetData = hubitat.helper.HexUtils.byteArrayToHexString(packet)
	def Action = new hubitat.device.HubAction(
		packetData,
		hubitat.device.Protocol.LAN,
			callback: callback,
			destinationAddress: deviceConfig.IP,
			type: hubitat.device.HubAction.Type.LAN_TYPE_UDPCLIENT,
			encoding: hubitat.device.HubAction.Encoding.HEX_STRING
	try {
		log_debug("sendMessage - sending packet to ${deviceConfig.IP}")
		log_info("sendMessage - sending packet [${packetData}]")
		sendHubCommand(Action)
		return false
	} catch(e) {
		log_error("sendMessage - ERROR - Caught exception '${e}'")
		return true
// this function MUST be passed a byte array
def sendCodeData(data) {
	log_debug("sendCodeData: ip [${state.deviceConfig.IP}]")
	log_info("sendCodeData: code [${data}]")
	byte [] packet = [0x02, 0x00, 0x00, 0x00]
	packet = hubitat.helper.HexUtils.hexStringToByteArray(hubitat.helper.HexUtils.byteArrayToHexString(packet) + hubitat.helper.HexUtils.byteArrayToHexString(data))
	if (packet[0x04] == 0x26) {
		if (state.deviceConfig.hasIR == false) {
			log_debug("(sendCodeData) Error: Device (${state.deviceConfig.IP} - [${state.deviceConfig.devTypeName}]) can not send IR data")
			return true
	} else {
		// trying to send RF data
		if (state.deviceConfig.isPro == false) {
			log_debug("(sendCodeData) Error: Device (${state.deviceConfig.IP} - [${state.deviceConfig.devTypeName}]) can not send RF data")
			return true
	state.CODEDATA = hubitat.helper.HexUtils.byteArrayToHexString(data)
	return send_packet(state.deviceConfig, 0x6a, packet, "parseCommandData")
def encryptPacket(deviceConfig, data){
	AES_setKey(deviceConfig.KEY)
	AES_setIV(deviceConfig.IV)
	def encData = AES_Encrypt(data)
	if (encData) { return encData }
	return null
def decryptPacket(deviceConfig, data) {
	def decData = AES_Decrypt(data)
	if (decData) { return decData }
	return null
def getDiscoveryData(targetIP) {
	log_debug("getDiscoveryData - discovering configuration for ${targetIP}")
	log_debug("createDiscoveryPacket - creating discovery packet")
	def hub = location.hubs[0]
	def localIP = hub.getDataValue("localIP")
	def hIP = localIP.tokenize( '.' )
	log_debug("createDiscoveryPacket - HUB IP ${hIP}")
	def ts = now()
	def DATE = new Date()
	log_debug("createDiscoveryPacket - DATE ${DATE.format("YYYY L d H m s u")}")
	//													DATE 2020 1 53 41 3 5 7
	def YEAR = DATE.format("YYYY") as int
	def YEAR1 = (byte)(YEAR & 0xff)
	def YEAR2 = (byte)(YEAR >> 8)
	def MONTH = DATE.format("L") as int
	def DAY = DATE.format("d") as int
	def HOURS = DATE.format("H") as int
	def MINS = DATE.format("m") as int
	def SECS = DATE.format("s") as int
	def WDAY = DATE.format("u") as int; if (WDAY == 7) { WDAY = 0 }
	def tzOffset = 0
	def (tz1, tz2, tz3, tz4) = [tzOffset, 0, 0, 0]
	if (tzOffset < 0) {
			(tz1, tz2, tz3, tz4) = [0xff + tzOffset + 1, 0xff, 0xff, 0xff]
	tz1 = tz1%0xff
	byte [] dPacket = [ 0x5a, 0xa5, 0xaa, 0x55, 0x5a, 0xa5, 0xaa, 0x55,
				    tz1, tz2, tz3, tz4, YEAR1, YEAR2, SECS, MINS,
				    HOURS, DAY, WDAY, MONTH, 0x00, 0x00, 0x00, 0x00,
				    hIP[0] as int, hIP[1] as int, hIP[2]as int, hIP[3] as int, 0x80, 0x0d, 0x00, 0x00,
				    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00,
	def checksum = getChecksum(dPacket)
	dPacket[0x20] = (byte)(checksum & 0xff)
	dPacket[0x21] = (byte)(checksum >> 8)
	def packetData = hubitat.helper.HexUtils.byteArrayToHexString(dPacket)
	log_debug("getDiscoveryData - 1 sending packet [${packetData}] to ${targetIP}")
		packetData,
			callback: "parseDiscoveryPacket",
			destinationAddress: targetIP,
			destinationPort: 80,
	log_info("getDiscoveryData - 2 sending PACKET")
	try {
		log_debug("getDiscoveryData - SENDING packet to ${targetIP}")
		log_info("getDiscoveryData - SENDING packet [${packetData}]")
	} catch(e) {
		log_error("getDiscoveryData - ERROR - Caught exception '${e}'")
def learnIR() {
		log_debug("(learnIR) Error: Device (${state.deviceConfig.IP}) - [${state.deviceConfig.devTypeName}] can not Learn IR data")
		return true
	log_debug("(learnIR) Attempting to enter IR learn mode...")
	byte [] packet = [0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
	return send_packet(state.deviceConfig, 0x6a, packet, "parseDataIR")
def checkDataIR() {
	log_debug("(checkDataIR) Checking for IR code data")
	byte [] packet = [0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
def checkDataRF() {
	log_debug("(checkDataRF) Checking for RF code data")
	return send_packet(state.deviceConfig, 0x6a, packet, "parseDataRF")
def learnRF() {
		log_debug("(learnRF) Error: Device (${deviceConfig.IP}) - [${deviceConfig.devTypeName}] can not Learn IR data")
		return true
	log_debug("(learnRF) Attempting to enter RF learn mode")
	byte [] packet = [0x19, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
def checkFrequencyRF() {
	log_debug("(checkDataRF) Checking for RF data")
	byte [] packet = [0x1a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
def findPacketRF() {
	log_debug("(checkDataRF2) Checking for RF data..")
	byte [] packet = [0x1b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
def cancelRF() {
	log_debug("(cancelRF) Cancelling RF sweep")
	byte [] packet = [0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
// parse functions
def parse(description) {
	def resp = parseLanMessage(description)
	if (resp == null) {log_debug("parse: Could not parse packet."); return }
	byte [] parseData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	def dErr = parseData[0x22] | (parseData[0x23] << 8)
	if (parseData.size() > 0x38) {payload = decryptPacket(state.deviceConfig,parseData[0x38..-1])}
	log_debug("parse - received description: ${description}")
	if (payload) {log_debug("parse - received payload: [${hubitat.helper.HexUtils.byteArrayToHexString(payload)}]")}
	if (dErr != 0) {log_debug("parse: ERROR - Device indicated error code ${String.format("%02X",dErr)}")}
def parseStatusData(description) {
	log_debug("parseStatusData - received description: ${description}")
	if (resp == null) {log_debug("parseStatusData: Could not parse packet."); return }
	byte [] statusData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseStatusData: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	def dErr = statusData[0x22] + (statusData[0x23] * 256)
	if (dErr == 0) {
		if (statusData.size() == 0x38) {
			log_debug("parseStatusData: Device did not return a status payload.")
			return null
		def payload = decryptPacket(state.deviceConfig,statusData[0x38..-1])
		if (payload) {
				local powerState = payload[0x0e]
				def S1 = (powerState && 0x01) ? true : false
				def S2 = (powerState && 0x02) ? true : false
				def S3 = (powerState && 0x04) ? true : false
				def S4 = (powerState && 0x08) ? true : false
				def powerAll = S1 || S2 || S3 || S4
				log_debug("parseStatusData: return [powered: ${powerAll}, poweredS1: ${S1}, poweredS2: ${S2}, poweredS3: ${S3}, poweredS4: ${S4}]")
				return [powered: powerAll, poweredS1: S1, poweredS2: S2, poweredS3: S3, poweredS4: S4]
			} else {
				def powerState = (payload[0x05] > 0) ? true : false
				log_debug("parseStatusData: return [powered: ${powerState}]")
				return {powered: powerState}
		} else {log_debug("parseStatusData: Could not decrypt packet ${statusData[0x38..-1]}")}
	} else {
		log_debug("parseStatusData: ERROR - Device indicated error code ${String.format("%02X",dErr)}")
def parseTargetResponse(description) {
	log_debug("parseTargetData - received description: ${description}")
	if (resp == null) {log_debug("parseTargetData: Could not parse packet."); return }
	byte [] targetData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseTargetData: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	def dErr = targetData[0x22] + (targetData[0x23] * 256)
	if (dErr == 0) {
		if (targetData.size() == 0x38) {
			log_debug("parseTargetData: Device did not return a status payload.")
			return null
		def payload = decryptPacket(state.deviceConfig,targetData[0x38..-1])
		if (payload) {
				def powerState = payload[0x0f]
				log_debug("parseTargetData: return [powered: ${powerAll}, poweredS1: ${S1}, poweredS2: ${S2}, poweredS3: ${S3}, poweredS4: ${S4}]")
			} else {
				log_debug("parseTargetData: return [powered: ${powerState}]")
				return [powered: powerState]
		} else {log_debug("parseTargetData: Could not decrypt packet ${statusData[0x38..-1]}")}
	} else {
		log_debug("parseTargetData: ERROR - Device indicated error code ${String.format("%02X",dErr)}")
def parseAuthData(description) {
	log_debug("parseAuthData - received description: ${description}")
	if (resp == null) {log_debug("parseAuthData: Could not parse packet."); return }
	byte [] authData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseAuthData: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	if (authData.size() == 0x38) {log_debug("parseAuthData: packet does not contain an Auth payload."); return }
	byte [] payload = authData[0x38..-1]
	if ((payload == null) || (payload == "")) { log_debug("parseAuthData: Could not decrypt packet ${authData[0x38..-1]}"); return }
	byte [] dPayload = decryptPacket(state.deviceConfig,payload)
	log_debug("parseAuthData: packet ${hubitat.helper.HexUtils.byteArrayToHexString(dPayload)}")
	def internalID = ""
	try { internalID = arrayListToHexString(dPayload[0x00..0x03]) } catch(e) {}
	def KEY =  ""
	try { KEY = arrayListToHexString(dPayload[0x04..0x13]) } catch(e) {log_debug(e)}
	if (internalID != "") { state.deviceConfig.internalID = internalID }
	if (KEY != "") { state.deviceConfig.KEY = KEY; state.deviceConfig.hasAuth = true }
	if (state.deviceConfig.hasAuth) {
		def configJson = new groovy.json.JsonOutput().toJson(state.deviceConfig)
		sendEvent(name: "deviceConfig", value: configJson, displayed:false, isStateChange: true)
	if ((state.deviceConfig.hasAuth)&&(state.deviceConfig.hasTemp)) {
		check_sensors()
	} else {
		sendEvent(name: "temperature", value: -100, displayed:false, isStateChange: true)
	if ((state.deviceConfig.hasAuth) && ((state.deviceConfig.hasTemp) || (state.deviceConfig.relayCount != 0))) {
		unschedule()
	log_debug("parseAuthData: Parsed response packet.  ID [${state.deviceConfig.internalID}]  KEY [${state.deviceConfig.KEY}]  AUTH [${state.deviceConfig.hasAuth}]")
	return null
def parseSensorData(description) {
	log_debug("parseSensorData - received description: ${description}")
	if (resp == null) {log_debug("parseSensorData: Could not parse packet."); return }
	byte [] sensorData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseSensorData: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	def dErr = sensorData[0x22].toInteger() + (sensorData[0x23].toInteger() * 256)
	if (dErr == 0) {
		byte [] payload = decryptPacket(state.deviceConfig,sensorData[0x38..-1])
		//print("check_sensors: decrypted payload ["..hex_dump(payload).."]")
		def temp = ((payload[0x04].toInteger() * 10) + payload[0x05].toInteger()) / 10
		log_debug("parseSensorData: return temperature = ${temp} C")
		if (location.temperatureScale == "F") {
			temp = celsiusToFahrenheit(temp)
			log_debug("parseSensorData: converted temperature = ${temp} F")
		sendEvent(name: "temperature", value: temp, displayed:false, isStateChange: true)
		return false
	log_debug("parseSensorData: FAILED to retreive sensor data")
	return true
def parseDiscoveryPacket(description) {
	log_debug("parseDiscoveryData - received description: ${description}")
	if (resp == null) {log_debug("parseDiscoveryPacket: Could not parse packet."); return }
	byte [] payload = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseDiscoveryPacket: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	def blDevice = [
		Name: (getString(payload[0x40..-1]) == "")?"[UNNAMED]":getString(payload[0x40..-1]),
		MAC: arrayListToHexString(payload[0x3a..0x3f].reverse()),
		IP: decodeHexIP(resp.ip),
		devType: hubitat.helper.HexUtils.hexStringToInt("0x"+arrayListToHexString(payload[0x35]) + arrayListToHexString(payload[0x34])),
		devTypeName: "",
		internalID: "00000000",
		hasAuth: false,
		isPro: false,
		hasIR: false,
		hasTemp: false,
		relayCount: -1
	def tInfo = getDeviceTypeInfo(blDevice.devType)
	blDevice.devTypeName = tInfo.devTypeName
	blDevice.isPro = tInfo.isPro
	blDevice.hasIR = tInfo.hasIR
	blDevice.hasTemp = tInfo.hasTemp
	blDevice.relayCount = tInfo.relayCount
	log_debug("parseDiscoveryData - Discovered device: ${blDevice}")
	state.deviceConfig = blDevice
	getAuth(blDevice)
def parseCommandData(description) {
	log_debug("parseCommandData - received description: ${description}")
	if (resp == null) {log_debug("parseCommandData: Could not parse packet."); return }
	byte [] commandData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseCommandData: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	def dErr = commandData[0x22].toInteger() + (commandData[0x23].toInteger() * 256)
	if (dErr == 0) {
		byte [] payload = decryptPacket(state.deviceConfig,commandData[0x38..-1])
		log_debug("parseCommandData: return [${payload}]")
		return false
	log_debug("parseCommandData: FAILED to retreive command response data")
	return true
def parseDataIR(description) {
	log_debug("parseDataIR - received description: ${description}")
	if (resp == null) {log_debug("parseDataIR: Could not parse packet."); return }
	byte [] learnData = hubitat.helper.HexUtils.hexStringToByteArray(resp.payload)
	log_info("parseDataIR: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	def dErr = learnData[0x22].toInteger() + (learnData[0x23].toInteger() * 256)
	if (learnData.size() > 0x38) {
		payload = decryptPacket(state.deviceConfig,learnData[0x38..-1])
	if (dErr == 0) {
		if ((payload == null) || (payload.size() == 0)) {
			log_debug("parseDataIR: ERROR - Response packet does not contain a payload.")
		} else if (payload[0] == 3) {
			log_debug("parseDataIR: Entered LEARN Mode.")
			LEARN = now()
			sendEvent(name: "IR_Status", value: "Learning: Press button on IR Remote.", displayed:false, isStateChange: true)
			pauseExecution(500)
			return checkDataIR()
		} else if (payload[0] == 4) {
			if (payload.size() > 0x20) {
				// received IR data
				def CODEDATA = arrayListToHexString(payload[4..-1])
				log_debug("parseDataIR: Received IR Data [${CODEDATA}].")
				LEARN = 0
				state.CODEDATA = CODEDATA
				sendEvent(name: "CODEDATA", value: CODEDATA, displayed:false, isStateChange: true)
				sendEvent(name: "IR_Status", value: "Learned Code", displayed:false, isStateChange: true)
				pauseExecution(1500)
				return null
			} else {
				log_info("parseDataIR: TIMER [${now() - LEARN}].")
				pauseExecution(500)
	} else {
			log_debug("parseDataIR: Device reported error [${String.format("%04X",dErr)}]")
			// do not exit despite the error - some devices report error unit data is available
			if ( (LEARN != 0) && ((now() - LEARN) < 30000) ) {
				pauseExecution(500)
			log_debug("parseDataIR: Failed to enter LEARN Mode.")
			LEARN = 0
			sendEvent(name: "IR_Status", value: "FAILED", displayed:false, isStateChange: true)
			log_info("parseDataIR: ERR  LEARN [${LEARN}]  NOW [${now()}]  TIMER [${now() - LEARN}].")
			if ( (LEARN == 0) || ((now() - LEARN) > 30000) ) {
				// learn mode has ended
				log_debug("parseDataIR: LEARN Mode timed out.")
				LEARN = 0
				state.CODEDATA = ""
				sendEvent(name: "CODEDATA", value: "", displayed:false, isStateChange: true)
				sendEvent(name: "IR_Status", value: "Timeout", displayed:false, isStateChange: true)
				return null
			pauseExecution(500)
	LEARN = 0
	state.CODEDATA = ""
	log_debug("parseDataIR: FAILED to retreive learn response data")
	sendEvent(name: "IR_Status", value: "ERROR", displayed:false, isStateChange: true)
	return true
def parseDataRF(description) {
	log_debug("parseDataRF - received description: ${description}")
	if (resp == null) {log_debug("parseDataRF: Could not parse packet."); return }
	log_info("parseDataRF: parsing response packet.  IP [${resp.ip}]\n${resp.payload}")
	if (dErr == 0) {
			log_debug("parseDataRF: ERROR - Response packet does not contain a payload.")
		} else if (payload[0] == 0x19) {
			log_debug("parseDataRF: Entered RF FREQUENCY SWEEP Mode.")
			LEARN = now()
			sendEvent(name: "RF_Status", value: "SWEEP: LED = RED : Press AND Hold button on RF Remote.", displayed:false, isStateChange: true)
			pauseExecution(500)
			return checkFrequencyRF()
		} else if (payload[0] == 0x1a) {
			// checkFrequencyRF response - wait until byte 4 is 1 (success) or 4 (failed)
			if (payload[4] == 0) {
				// continue waiting for frequency determination
				pauseExecution(500)
			} else if (payload[4] == 1) {
				log_debug("parseDataRF: Found RF FREQUENCY...")
				sendEvent(name: "RF_Status", value: "SWEEP : LED = OFF : Frequency Found. Release RF Remote button.", displayed:false, isStateChange: true)
				pauseExecution(500)
				// reset the timeout
				LEARN = now()
				return findPacketRF()
			} else {
				// the frequency scan failed... cancel the process
				log_debug("parseDataRF: ERROR - RF FREQUENCY SWEEP failed.")
				sendEvent(name: "RF_Status", value: "SWEEP : LED = OFF : FAILED. Release RF Remote button.", displayed:false, isStateChange: true)
				return cancelRF()
		} else if (payload[0] == 0x1b) {
			// findPacketRF response - this is an ack only - move to next step
			sendEvent(name: "RF_Status", value: "FIND : LED = AMBER : Press and Release RF Remote button repeatedly.", displayed:false, isStateChange: true)
			LEARN = now()
			pauseExecution(500)
			return checkDataRF()
		} else if (payload[0] == 0x1e) {
			// ack for cancelRF()
			log_debug("parseDataRF: RF FREQUENCY SWEEP Mode cancelled.")
			sendEvent(name: "RF_Status", value: "CANCELLED", displayed:false, isStateChange: true)
			LEARN = 0
			state.CODEDATA = ""
			return null
				// received RF data
				log_debug("parseDataRF: Received RF Data [${CODEDATA}].")
				sendEvent(name: "RF_Status", value: "LEARNED", displayed:false, isStateChange: true)
				LEARN = 0
				return null
			} else {
				log_info("parseDataRF: TIMER [${now() - LEARN}].")
				pauseExecution(500)
	} else {
			log_debug("parseDataRF: Device reported error [${String.format("%02X",dErr)}]")
			log_debug("parseDataRF: Failed to enter RF FREQUENCY SWEEP Mode.")
			sendEvent(name: "RF_Status", value: "SWEEP: FAILED.", displayed:false, isStateChange: true)
			state.CODEDATA = ""
			LEARN = 0
			return null
				pauseExecution(500)
				pauseExecution(500)
				LEARN = now()
			} else {
				return cancelRF()
			LEARN = now()
			pauseExecution(500)
			state.CODEDATA = ""
			LEARN = 0
			return null
			log_info("parseDataRF: ERR  LEARN [${LEARN}]  NOW [${now()}]  TIMER [${now() - LEARN}].")
				log_debug("parseDataRF: LEARN Mode timed out.")
				sendEvent(name: "RF_Status", value: "TIMEOUT", displayed:false, isStateChange: true)
				state.CODEDATA = ""
				LEARN = 0
				return null
			pauseExecution(500)
	log_debug("parseDataRF: FAILED to retreive RF response data")
	sendEvent(name: "RF_Status", value: "ERROR", displayed:false, isStateChange: true)
	return true
// IR/RF Code data functions
def StoreCode(codeName) {
	state.codeStore = (state.codeStore?state.codeStore:[:])
	codeName = codeName.tokenize(" ,!@#\$%^&()").join("_")
	log_debug("(StoreCode) Store code : [${codeName}] = [${state.CODEDATA}]")
	if ((codeName == null) || (codeName == "")) {
		log_debug("(StoreCode) ERROR: A name for the code must be provided.")
		return null
	if (state.codeStore[(codeName)] != null) {
		log_debug("(StoreCode) ERROR: A code is already stored under this name.")
		return null
	if (state.CODEDATA == null) {
		log_debug("(StoreCode) ERROR: A code is available for storing..")
		return null
	state.codeStore[(codeName)] = state.CODEDATA
	log_debug("(StoreCode) Code Stored : Stored codes [${state.codeStore.size()}]")
def SendStoredCode(codeName) {
	log_debug("(SendStoredCode) Requested code : [${codeName}]")
	if (state.codeStore[(codeName)] == null) {
		log_debug("(SendStoredCode) ERROR: A code is not stored under this name.")
		return null
	def sCode = state.codeStore[(codeName)]
	log_debug("(SendStoredCode) Found code for [${codeName}]")
	byte [] codeData = hubitat.helper.HexUtils.hexStringToByteArray(sCode)
	if (codeData) {
		def sErr = sendCodeData(codeData)
		if (sErr == false) {
			log_debug("(SendStoredCode)  Sent code data.")
			return true
		} else {
			log_debug("(SendStoredCode) ERROR - Could not send code data.")
			return false
	} else {
		log_debug("(SendStoredCode) ERROR - Could not decode code data.")
		return false
def push(button) {
	log_debug("(push) Request to push button [${button}]")
	SendStoredCode(button)
def SendLastCode() {
		log_debug("(SendLastCode) ERROR: A code is not available for sending..")
		return null
	def sCode = state.CODEDATA
	log_debug("(SendLastCode) Sending last used code.")
	if (codeData) {
			log_debug("(SendLastCode) Sent code data.")
			return true
		} else {
			log_debug("(SendLastCode) ERROR - Could not send code data.")
			return false
	} else {
		log_debug("(SendLastCode) ERROR - Could not decode code data.")
		return false
def SendCode(data) {
	log_info("sendCode: code [${data}]")
	byte [] code = []
	// is the code a hex encoded string?
	if ((data[0] == "J") ||(data[-1] == "=") ||(data[-1] == "A")) {
		code = data.decodeBase64()
		log_info("(sendCode) INFO: Converted code from Base64 encoded to Hex Encoded [${hubitat.helper.HexUtils.byteArrayToHexString(code)}].")
	} else {
		code = hubitat.helper.HexUtils.hexStringToByteArray(data)
	if (code == []) {
		log_debug("(sendCode) ERROR: Provided IR/RF code is in a recognized format.")
		return null
	// remove any trailing zero bytes
	def tStr = hubitat.helper.HexUtils.byteArrayToHexString(code)
	while (tStr[-2..-1] == "00") { tStr = tStr[0..-3] }
	code = hubitat.helper.HexUtils.hexStringToByteArray(tStr)
	if (!validateCode(code)) {
			log_debug("(sendCode) ERROR: Provided IR/RF code is not valid.")
			return null
	def sErr = sendCodeData(code)
		log_debug("SendCode - Sent code data.")
		return true
	} else {
		log_debug("SendCode - ERROR - Could not send code data.")
		return false
def SendProntoCode(ProntoCode) {
	log_debug("SendProntoCode - Pronto Code: ${ProntoCode}")
	if ((ProntoCode == null) || (ProntoCode == "")) {
		log_debug("SendProntoCode - ERROR - No Pronto data provided.")
		return false
	def sCommand = convertProntoCode(ProntoCode)
	if (!sCommand) {
		// CodeData does not contain a convertable Pront IR code
		log_debug("SendProntoCode - ERROR - Could not convert Pronto data.")
		return false
	byte [] codeData = hubitat.helper.HexUtils.hexStringToByteArray(sCommand)
	if (codeData) {
		if (!validateCode(codeData)) {
			log_debug("SendProntoCode - ERROR - Code data did not convert to a valid broadlink code.")
			return false
			log_debug("SendProntoCode - Sent code data.")
			return true
		} else {
			log_debug("SendProntoCode - ERROR - Could not send code data.")
			return false
	} else {
		log_debug("SendProntoCode - ERROR - Could not decode code data.")
		return false
private convertProntoCode(pcode) {
	//               [[0000 006d 0000 0022 00ac 00ac 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0689]]
	// pronto format = 0000 FFFF xxxx yyyy O1O1 .. OXOX R1R1 .. RXRX TPTP
    //     where       0000 = 4 digit Pronto code header - always 0000
    //                 FFFF = 4 digit hex frequency divisor - ie 006D = 109 = math.floor(4146/109) = 38KHz
    //                 xxxx = size of once burst pairs
    //                 yyyy = size of repeat burst pairs
    //                 O1O1 .. OXOX = once code data to encode in hex words MSB -> LSB
    //                 R1R1 .. RXRX = repeat code data to encode in hex words MSB -> LSB
    //                 TPTP = 4 digit hex number trailing pulse
	log_debug("(convertProntoCode): Starting IR Code conversion.")
	log_info("(convertProntoCode):   Initial Pronto Code [${pcode}]")
	def xwords = pcode.tokenize(" ")
	def pwords = xwords.collect{ it ->
		return Integer.parseUnsignedInt(it,16)
	def bwords = []
	if ( (pwords == null) || (pwords[0] != 0) || (pwords[1] == 0) || ((pwords[2] == 0) && (pwords[3] == 0))) {
		log_debug("(convertProntoCode): ERROR -  IR Code conversion failed. Unrecognized format.")
		return nil
	def n = pwords[2]
	if (n == 0) { n = pwords[3] }
	if (((n * 2) + 4) > pwords.size()) {
		log_debug("(convertProntoCode): ERROR -  IR Code conversion failed.")
		return null
	int freq = Math.floor(4145 / pwords[1].toInteger())
	def ct = (1000/freq) * 269 / 8192
	log_debug("(convertProntoCode): ct [${ct}]")
	for ( i = 4; i < pwords.size(); i++) {
		def bVal = ((pwords[i] * ct) + 0.5).toInteger()
		if (bVal > 256) {
			bwords[i-4] = "00" + String.format("%02X",(bVal & 0xFF)) + String.format("%02X",(bVal >> 8))
		} else {
			bwords[i-4] = String.format("%02X",bVal)
	def codeData = bwords.join() + "0d05"
	int cSize = codeData.size() /2
	int L1 = (cSize & 0xff)
	int L2 = (cSize >> 8)
	def newcode = String.format("%02X",freq) + "00" + String.format("%02X",L1) + String.format("%02X",L2) + codeData //+ codePadding
	log_debug("(convertProntoCode):   Converted Broadlink Code [${newcode}]")
	log_debug("(convertProntoCode): IR Code conversion completed.")
	return newcode
def convertLircCode(lcode) {
	//               L 0026 027A 0633 027A 01EF 1217 1137 0020 E0E0 E01F 027B
	// lirc format = L FFFF 1111 1111 0000 0000 HPHP HSHS CSCS C1C1 .. CXCX TPTP
	//   where         FFFF = 4 digit hex frequency in KHz - ie 0026 = 38 = 38KHz
	//                 1111 1111 = burst pair for one bit
	//                 0000 0000 = burst pair for zero bit
	//                 HPHP HSHS = Header burst pair
	//                 CSCS = 4 digit hex number of bits of code data
	//                 C1C1 .. CXCX = code data to encode in hex words MSB -> LSB
	log_debug("(convertLircCode) Starting IR Code conversion.")
	if (lcode[0] != "L") {
		log_debug("(convertLircCode) IR Code conversion failed. Invalid LIRC code")
		return null
	def bMask = [
		"0": "0000", "1": "0001", "2": "0010", "3": "0011", "4": "0100", "5": "0101", "6": "0110", "7": "0111", "8": "1000",
		"9": "1001", "A": "1010", "a": "1010", "B": "1011", "b": "1011", "C": "1100", "c": "1100", "D": "1101", "d": "1101",
		"E": "1110", "e": "1110", "F": "1111", "f": "1111"
	def pcode = lcode[2..-1]
	def pwords = []
	def kwords = []
	def px = 0
	for (i = 1; i < pcode.size(); i = i + 5) {
		px = px + 1
		pwords[px] = string.sub(pcode,i,i+3)
	def Freq = tonumber(pwords[0],16)
	def LIRC = [
		"1": pwords[1] + " " + pwords[2],
		"0": pwords[3] + " " + pwords[4]
	def bitcount = tonumber(pwords[8],16)
	def bString = String.format("%02X",Freq) + "00" + String.format("%04X",(bitcount + 2))[2..3] + string.format("%04X",(bitcount + 2))[2..3] + " " + pwords[5] + " " + pwords[6]
	def dataWords = math.ceil(bitcount/16)
	def tPulse = pwords[9 + dataWords] .. " 2000"
	def bitMask = ""
	for (idx = 1; idx < dataWords; i++) {
		def data = pwords[7 + idx]
		for (ndx = 1; ndx < 4; ndx++) {
			bitMask = bitMask + bMask[data[ndx]]
	bitMask = bitMask[(bitMask.size() - bitcount)+1..-1]
	for (idx = 1; idx < bitMask.size(); idx++) {
		kString = kString + " " + LIRC[bitMask[idx]]
	kString = kString + " " + tPulse
	log_debug("(convertLircCode) IR Code conversion completed.")
	return kString
// this function must be passed a byte array
def validateCode(codeData) {
	log_info("(validateCode) Validating IR/RF code [${codeData}]")
	if ((codeData[0] == 0x26) || (((codeData[0] < 0)?(codeData[0]+256):codeData[0]) == 0xb2) || (((codeData[0] < 0)?(codeData[0]+256):codeData[0]) == 0xd7)) {
		def cLength = codeData[2] + (codeData[3] * 256)
		if (codeData[0] == 0x26) {
			if (codeData[1] > 2)  {
				log_info("(validateCode) Valid code - WARNING:  Excessive IR repeat count ( repeat > 2 )")
				return true	// "Valid Code: WARNING - Excessive IR repeat count ( repeat > 2 )"
			if ((codeData[-2] != 0x0d) || (codeData[-1] != 0x05)) {
				log_info("(validateCode) Code ERROR:  invalid IR lead-out data")
				return false	// "Code ERROR: invalid IR lead-out data"
		if ( (codeData[0] == 0xb2) && (codeData[1] > 0x15) ) {
			log_info("(validateCode) Valid code - WARNING:  Excessive RF433 repeat count ( repeat > 21 )")
			return true	// "Valid Code: WARNING - Excessive RF433 repeat count ( repeat > 21 )"
		if ( (codeData[0] == 0xd7) && (codeData[1] > 0x16) ) {
			log_info("(validateCode) Valid code - WARNING:  Excessive RF315 repeat count ( repeat > 22 )")
			return true	// "Valid Code: WARNING - Excessive RF315 repeat count ( repeat > 22 )"
		log_info("(validateCode) Valid code:No code errors found")
		return true	// "Valid Code: No code errors found"
	} else {
		log_info("(validateCode) Code ERROR: Invalid code header")
		return false // "Code ERROR: Invalid code header"
Wow this is great, will try it when I get the chance!
I’ve had a brand new one in its box for over two years. Time to break it out I think :+1::+1:
Will this support multiple broadlink devices? (I want to put them in each room)
Yes. Install a virtual device for each physical device.
Perfect, i'm ordering some now on Amazon.
Thanks for sharing!
I get this error with learnIR. Any idea what could be going wrong?
I have an RM Mini 3, and I can see the LED on the device light up as it goes in to learning mode and then go off after I press the button on my IR remote. But it seems to break down when handling the reply.
Here's device state, in case it helps.
  • {"devType":10039,"hasAuth":true,"relayCount":0,"internalID":"01000000","hasIR":true,"hasTemp":false,"IP":"10.0.0.111","devTypeName":"RM Mini","MAC":"(redacted)","isPro":false,"KEY":"F114214C27FBDC10AEC508AC27154179","Name":"\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd"}
  • temperature : -100
ev:19022020-01-07 10:43:20.674 pm errorjava.lang.ArrayIndexOutOfBoundsException: 0 on line 963 (parseDataIR)
dev:19022020-01-07 10:43:20.647 pm debugBLTest - parseDataIR: parsing response packet. IP [0a00006f] 5AA5AA555AA5AA5500000000000000000000000000000000000000000000000093CBFBFF2A27EE030200EADD7442F7C801000000AFBE0000
dev:19022020-01-07 10:43:20.644 pm debugBLTest - parseDataIR - received description: index:00, mac:(redacted), ip:0a00006f, port:50, type:LAN_TYPE_UDPCLIENT, payload:5AA5AA555AA5AA5500000000000000000000000000000000000000000000000093CBFBFF2A27EE030200EADD7442F7C801000000AFBE0000
The latest version, available in the first post, should fix this.
I have posted a new version, v0.19, that adds some IR/RF code management functions, and some minor bugfixes... It is available in the first post.
Thanks for the quick update.
It works now, but it's pretty finicky. If I execute learnIR, it very quickly goes into IR_Status ERROR. If I start rapidly pushing the intended button and then execute learnIR, it usually goes to IR_Status Learned Code and then back to IDLE.
It seems like there is a timing issue in the communication, at least on my system. Maybe since learnIR is able to be re-attempted manually, you could just retry on ERROR (for a reasonable amount of time) when the learning process is initiated?
Sending commands from CODEDATA with Send Code works well. I also used it successfully with some of the stored codes I have from @rob121 's broadlinkgo implementation. Pretty cool!
EDIT: This was with v0.18, just so that is clear. I'll give it another shot with v0.19 later.
I am not seeing this on my system... I'm testing with a RM2 Pro Plus2...
The learnIR() function already uses a 30 second timeout, and the learnRF() function uses a 30 second timeout per step.
If the learnIR() function is giving you trouble, please post the log of the function being executed so I can figure out whats going wrong.
Very cool! Is this all local, or does it have to go out to a broad link cloud service?
Terrific! Many thanks for contributing this.
Yes.
I've got amazon.com open in another browser window...before I buy more Broadlink devices, do you have specs on which hardware is supported by the driver?
For example, I found that the Broadlink Mini Bean has a different device fingerprint from the Broadlink Mini 3 (as used by [broadlinkgo](broadlinkgo/knowndevices.go at master · rob121/broadlinkgo · GitHub and [homebridge-broadlink-rm(Broadlink RM mini 3 - unknown device 5f36 · Issue #515 · lprhodes/homebridge-broadlink-rm · GitHub)).
I updated to support that recently:
But I don't have the device so if somone test it let me know, either way @cybrmage feel free to crib from my code, if this works better, I'll be happy to stop using my own, less dependency is best!
rob121Owner
5m
(Where "that" is the Broadlink RM Mini Bean.)
Yes, absolutely...I didn't mean to suggest that you don't support it now, just to point out the difference between hardware models (and a source for device fingerprints).
In the RM line of products, there are basically just 3 devices: RM, RM Pro and RM Mini.
They all support the same communications methods and protocol, regardless of branding. The different device IDs differentiate between various different brandings and hardware revisions, BUT the protocol hides them, and the protocol is all the same... If you get a device with an ID that is not in the list... not to worry... A single line of code will resolve that...
I am confused by the device naming, but I have a device that I have used with both broadlinkgo and cybrmage's BETA driver.
I bought it from Amazon from this page: https://www.amazon.com/Broadlink-RM-Mini3-Universal-Controller-Compatible/dp/B01FK2SDOC
I don't recall it being named "Black Bean" at the time, but that is definitely the model I bought from Amazon in July, 2019. Maybe they have transitioned to new variants or changed the product ID in the meantime, so YMMV.
It shows up as ID 10039 (0x2737) in cybrmage's driver. broadlinkgo doesn't list the ID, but my devices work there (and worked prior to Rob's recent update).
Is this thread crashing chrome on Android for anyone else? It does for me.
