One other thing... when you say not updating is this on the dashboard display or on the device itself ? Can you look at the device attribute directly via 'Devices' in HE. Some people have reported dashboard tiles not updating after a while but the underlying devices are updating fine (not related to this app)
Thank you Kevin...I'll have to wait and see in a few days when it stops working and look through the logs again. Yes, I'm running your latest beta 3c and haven't had the hub slowdowns that I have seen others having. Everything else seems to work just fine. Not using really using dashboards just Hubigraphs to graph pool temperature and that is how I started noticing it. I have able to verify under the virtual MQTT temperature device that it does stop updating changes.
The strange thing is that it still says present as I took a screenshot of the MQTT device this morning before opening the MQTT app and clicking done.
Thanks for all the help. I'll do a little more digging when it stops reporting again.
It shows a sequence of 0 though... that is not right, it has just connected
Please check you have no other MQTT driver devices and also do a reboot, did you upgrade from beta 2 ?
Oops, maybe I took the screenshot right after hitting done in the app, sorry. I'll be sure to document everything I can next time it happens.
I was never on beta 2 and I didn't install until you released Beta 3.
Thanks again for all the help. I really appreciate it.
Heya fella's, I want to make sure I'm in the right thread and not cluttering things up.
I'm trying to get HE to talk with HA via MQTT and I'm clearly making a mess of things. I'll be happy to show my configs and whatnot to help troubleshoot, and point out where I went full on stupid. I'm pretty sure that I have the HA end of things set up correctly. I'm having issues following the readme instructions for the HE App/Driver. So, I'm pretty sure I'm doing something dumb.
Add that, to the fact that MQTT is brand new to me, and you have a recipe for disaster.
If I should create a thread some place else, or continue here is good with me, either way. I just don't know how this is usually done.
Hi Mark,
I can help get you going - the best place for HA discussion is here
The release notes for beta 3c are a bit of out of date and so please read the first few posts of this thread, inparticular do not install the driver manually. The app will now do that for you.
MQTT Explorer is an app you will find invaluable for seeing what is going on inside your MQTT broker.
Post in the above thread and we'll take it from there.
Okay so it happened again today. Seems to happen every 3 days. Looks like it stops subscribing from the topics. Here are the screenshots from before and after hitting done in the MQTT app. I did notice an error without any description in the device app events list about the time they stop subscribing.
Just busy for a couple of hours Tim but those didn’t look right, and an error message. I’ll send a longer reply later.
Was there anything in the logs ?
Which MQTT broker are you running and on what ?
Can you check in your devices that there is only one MQTT driver listed and have you restarted your hub recently too ? Worth doing that. You are getting disconnects happening a lot it seems.. the previous sequence number only reached 44 which was 14 minutes.... before losing the connection.
Thank you Kevin...you have been great and have created an amazing app for this community. I really appreciate all your help on this. Take as much time as you need.
Unfortunately by the time I realized it had stopped updating again the logs didn't go back far enough. I only get about 5 hours of past logs saved on my Hub.
I'm using mosquitto mqtt on a Raspberry Pi 3b to integrate with my pool controller via this setup:
I've confirmed that there is only one MQTT driver listed. I also restarted the hub last time it lost the subscriptions. I also pulled up MQTT Explorer and everything seems to be updating just fine on the server side.
Strange that it takes almost exactly 3 days to stop updating. I'm guessing it must be something with my MQTT pi setup or aqualinkd that is causing this as doesn't seem to be others having this issue, so its very possible it has nothing to do with your great app.
I would be interested in you reviewing the driver logs during this 3 day time , and seeing if disconnects are happening and how high the sequence number is getting each time.
In that device event log the sequence only ever reached 1 after 10 hours of being connected !
Here are the complete driver logs for the last week or so. Doesn't look like it is disconnecting during the 3 day period. It seems like when it does disconnect after the 3 days then reconnects it is no longer subscribed to all the device topics? Sorry, I'm very new to MQTT so not quite sure what to look for.
Summary
Name | Value | Unit | Description Text | Source | Type | Date |
Subscribes | 6 | DEVICE | 2020-06-22 01:02:12.754 PM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-22 01:02:12.715 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-22 01:02:12.679 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-22 01:02:12.658 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-22 01:02:12.641 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-22 01:02:12.609 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-22 01:02:12.556 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-22 01:02:12.528 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-22 01:02:12.508 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-22 01:02:12.481 PM PDT | |||
Subscribes | 11 | DEVICE | 2020-06-22 01:02:12.352 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-22 01:02:12.307 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-22 01:02:12.190 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-22 01:02:12.172 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-22 01:02:12.121 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-22 01:02:12.102 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-22 01:02:12.049 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-22 01:02:12.032 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-22 01:02:11.986 PM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-22 01:02:11.972 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-22 01:02:11.924 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-22 01:02:11.892 PM PDT | |||
Sequence | 4 | DEVICE | 2020-06-22 01:02:11.254 PM PDT | |||
Sequence | 3 | DEVICE | 2020-06-22 01:02:11.237 PM PDT | |||
Sequence | 2 | DEVICE | 2020-06-22 01:02:11.224 PM PDT | |||
Sequence | 1 | DEVICE | 2020-06-22 01:02:11.179 PM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-22 01:02:11.163 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-22 01:02:11.136 PM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-22 01:02:01.004 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-22 01:02:01.004 PM PDT | |||
presence | present | DEVICE | 2020-06-22 01:02:00.994 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-22 01:01:59.663 PM PDT | |||
presence | not present | DEVICE | 2020-06-22 01:01:59.652 PM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-22 12:55:01.679 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-22 12:55:01.679 PM PDT | |||
presence | present | DEVICE | 2020-06-22 12:55:01.664 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-22 12:54:25.174 PM PDT | |||
Sequence | 0 | DEVICE | 2020-06-22 12:54:25.173 PM PDT | |||
presence | not present | DEVICE | 2020-06-22 12:54:25.173 PM PDT | |||
MQTTStatus | Error: | DEVICE | 2020-06-22 12:54:24.122 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-21 07:34:00.721 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-21 07:34:00.692 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-21 07:34:00.676 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-21 07:34:00.636 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-21 07:34:00.603 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-21 07:34:00.568 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-21 07:34:00.517 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-21 07:34:00.465 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-21 07:34:00.251 PM PDT | |||
Subscribes | 11 | DEVICE | 2020-06-21 07:33:59.190 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-21 07:33:59.143 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-21 07:33:59.129 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-21 07:33:59.040 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-21 07:33:58.988 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-21 07:33:58.969 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-21 07:33:58.924 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-21 07:33:58.909 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-21 07:33:58.864 PM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-21 07:33:58.839 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-21 07:33:58.786 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-21 07:33:58.769 PM PDT | |||
Sequence | 4 | DEVICE | 2020-06-21 07:33:58.007 PM PDT | |||
Sequence | 3 | DEVICE | 2020-06-21 07:33:57.988 PM PDT | |||
Sequence | 2 | DEVICE | 2020-06-21 07:33:57.968 PM PDT | |||
Sequence | 1 | DEVICE | 2020-06-21 07:33:57.913 PM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-21 07:33:57.871 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-21 07:33:57.856 PM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-21 07:33:47.761 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-21 07:33:47.761 PM PDT | |||
presence | present | DEVICE | 2020-06-21 07:33:47.732 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-21 07:33:46.306 PM PDT | |||
Sequence | 0 | DEVICE | 2020-06-21 07:33:46.303 PM PDT | |||
presence | not present | DEVICE | 2020-06-21 07:33:46.302 PM PDT | |||
Sequence | 5 | DEVICE | 2020-06-21 04:04:51.893 PM PDT | |||
Sequence | 4 | DEVICE | 2020-06-21 04:04:38.236 PM PDT | |||
Sequence | 3 | DEVICE | 2020-06-21 03:58:46.527 PM PDT | |||
Sequence | 2 | DEVICE | 2020-06-21 03:58:30.824 PM PDT | |||
Sequence | 1 | DEVICE | 2020-06-21 01:59:31.189 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-21 03:03:27.725 AM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-21 03:03:27.725 AM PDT | |||
presence | present | DEVICE | 2020-06-21 03:03:27.708 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-21 03:02:05.254 AM PDT | |||
presence | not present | DEVICE | 2020-06-21 03:02:05.247 AM PDT | |||
Sequence | 0 | DEVICE | 2020-06-21 03:02:05.247 AM PDT | |||
MQTTStatus | Error: | DEVICE | 2020-06-21 03:02:04.190 AM PDT | |||
Sequence | 44 | DEVICE | 2020-06-20 07:07:16.535 PM PDT | |||
Sequence | 43 | DEVICE | 2020-06-20 06:57:40.545 PM PDT | |||
Sequence | 42 | DEVICE | 2020-06-20 06:24:22.701 PM PDT | |||
Sequence | 41 | DEVICE | 2020-06-20 06:08:47.042 PM PDT | |||
Sequence | 40 | DEVICE | 2020-06-20 05:44:38.093 PM PDT | |||
Sequence | 39 | DEVICE | 2020-06-20 05:44:35.403 PM PDT | |||
Sequence | 38 | DEVICE | 2020-06-20 05:44:34.536 PM PDT | |||
Sequence | 37 | DEVICE | 2020-06-19 10:29:46.083 PM PDT | |||
Sequence | 36 | DEVICE | 2020-06-19 10:28:56.179 PM PDT | |||
Sequence | 35 | DEVICE | 2020-06-19 10:23:49.015 PM PDT | |||
Sequence | 34 | DEVICE | 2020-06-19 10:23:47.646 PM PDT | |||
Sequence | 33 | DEVICE | 2020-06-19 10:21:54.296 PM PDT | |||
Sequence | 32 | DEVICE | 2020-06-19 10:21:54.253 PM PDT | |||
Sequence | 31 | DEVICE | 2020-06-19 10:20:23.631 PM PDT | |||
Sequence | 30 | DEVICE | 2020-06-19 10:00:32.294 PM PDT | |||
Sequence | 29 | DEVICE | 2020-06-19 09:59:15.879 PM PDT | |||
Sequence | 28 | DEVICE | 2020-06-19 09:59:14.050 PM PDT | |||
Sequence | 27 | DEVICE | 2020-06-19 09:07:12.861 PM PDT | |||
Sequence | 26 | DEVICE | 2020-06-19 09:07:12.839 PM PDT | |||
Sequence | 25 | DEVICE | 2020-06-19 09:05:16.584 PM PDT | |||
Sequence | 24 | DEVICE | 2020-06-19 09:05:11.002 PM PDT | |||
Sequence | 23 | DEVICE | 2020-06-19 04:59:48.587 PM PDT | |||
Sequence | 22 | DEVICE | 2020-06-19 04:59:27.982 PM PDT | |||
Sequence | 21 | DEVICE | 2020-06-19 04:59:27.845 PM PDT | |||
Sequence | 20 | DEVICE | 2020-06-19 04:12:56.710 PM PDT | |||
Sequence | 19 | DEVICE | 2020-06-19 04:11:47.665 PM PDT | |||
Sequence | 18 | DEVICE | 2020-06-19 03:59:34.506 PM PDT | |||
Sequence | 17 | DEVICE | 2020-06-18 02:52:18.062 PM PDT | |||
Sequence | 16 | DEVICE | 2020-06-18 02:52:18.019 PM PDT | |||
Sequence | 15 | DEVICE | 2020-06-18 02:52:17.965 PM PDT | |||
Sequence | 14 | DEVICE | 2020-06-18 10:01:45.991 AM PDT | |||
Sequence | 13 | DEVICE | 2020-06-18 10:01:45.950 AM PDT | |||
Sequence | 12 | DEVICE | 2020-06-18 10:01:45.898 AM PDT | |||
Sequence | 11 | DEVICE | 2020-06-18 10:01:45.801 AM PDT | |||
Sequence | 10 | DEVICE | 2020-06-18 10:01:45.747 AM PDT | |||
Sequence | 9 | DEVICE | 2020-06-18 10:01:45.711 AM PDT | |||
Sequence | 8 | DEVICE | 2020-06-18 10:01:45.671 AM PDT | |||
Sequence | 7 | DEVICE | 2020-06-18 10:01:45.623 AM PDT | |||
Sequence | 6 | DEVICE | 2020-06-18 10:01:45.584 AM PDT | |||
Sequence | 5 | DEVICE | 2020-06-18 10:01:45.531 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 10:00:53.891 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 10:00:53.838 AM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-18 10:00:53.813 AM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-18 10:00:53.777 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 10:00:53.731 AM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-18 10:00:53.691 AM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-18 10:00:53.658 AM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-18 10:00:53.602 AM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-18 10:00:53.547 AM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-18 10:00:53.503 AM PDT | |||
Subscribes | 11 | DEVICE | 2020-06-18 10:00:53.245 AM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-18 10:00:53.200 AM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-18 10:00:53.184 AM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-18 10:00:53.131 AM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-18 10:00:53.094 AM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-18 10:00:53.047 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 10:00:53.007 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 10:00:52.957 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 10:00:52.935 AM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-18 10:00:52.874 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 10:00:52.844 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 10:00:52.764 AM PDT | |||
Sequence | 4 | DEVICE | 2020-06-18 10:00:52.195 AM PDT | |||
Sequence | 3 | DEVICE | 2020-06-18 10:00:52.169 AM PDT | |||
Sequence | 2 | DEVICE | 2020-06-18 10:00:52.148 AM PDT | |||
Sequence | 1 | DEVICE | 2020-06-18 10:00:52.097 AM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-18 10:00:52.076 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 10:00:52.061 AM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-18 10:00:41.955 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 10:00:41.954 AM PDT | |||
presence | present | DEVICE | 2020-06-18 10:00:41.903 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 10:00:40.501 AM PDT | |||
presence | not present | DEVICE | 2020-06-18 10:00:40.498 AM PDT | |||
Sequence | 0 | DEVICE | 2020-06-18 10:00:40.498 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:45:47.803 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:45:47.750 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:45:47.689 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:45:47.647 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 09:45:47.603 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:45:47.551 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:45:47.521 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 09:45:47.486 AM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-18 09:45:47.438 AM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-18 09:45:47.199 AM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-18 09:45:47.167 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 09:45:47.104 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:45:47.073 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:45:47.024 AM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-18 09:45:46.919 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 09:45:46.893 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:45:46.844 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:45:46.813 AM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-18 09:45:46.765 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 09:45:46.734 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:45:46.653 AM PDT | |||
Sequence | 9 | DEVICE | 2020-06-18 09:45:45.976 AM PDT | |||
Sequence | 8 | DEVICE | 2020-06-18 09:45:45.954 AM PDT | |||
Sequence | 7 | DEVICE | 2020-06-18 09:45:45.931 AM PDT | |||
Sequence | 6 | DEVICE | 2020-06-18 09:45:45.899 AM PDT | |||
Sequence | 5 | DEVICE | 2020-06-18 09:45:45.876 AM PDT | |||
Sequence | 4 | DEVICE | 2020-06-18 09:45:45.859 AM PDT | |||
Sequence | 3 | DEVICE | 2020-06-18 09:45:45.834 AM PDT | |||
Sequence | 2 | DEVICE | 2020-06-18 09:45:45.813 AM PDT | |||
Sequence | 1 | DEVICE | 2020-06-18 09:45:45.782 AM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-18 09:45:45.751 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:45:45.732 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 09:45:35.544 AM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-18 09:45:35.544 AM PDT | |||
presence | present | DEVICE | 2020-06-18 09:45:35.515 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:45:34.100 AM PDT | |||
Sequence | 0 | DEVICE | 2020-06-18 09:45:34.099 AM PDT | |||
presence | not present | DEVICE | 2020-06-18 09:45:34.098 AM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-18 09:08:12.053 AM PDT | |||
Subscribes | -4 | DEVICE | 2020-06-18 09:08:12.004 AM PDT | |||
Subscribes | -3 | DEVICE | 2020-06-18 09:08:11.942 AM PDT | |||
Subscribes | -2 | DEVICE | 2020-06-18 09:08:11.879 AM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-18 09:08:11.808 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:08:11.709 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 09:08:11.633 AM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-18 09:08:11.573 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:08:11.505 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:08:11.427 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 09:08:11.034 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:08:10.954 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:08:10.874 AM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-18 09:08:10.794 AM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-18 09:08:10.754 AM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-18 09:08:10.704 AM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-18 09:08:10.624 AM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-18 09:08:10.575 AM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-18 09:08:10.534 AM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-18 09:08:10.444 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 09:08:10.391 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:08:10.364 AM PDT | |||
Sequence | 9 | DEVICE | 2020-06-18 09:08:09.205 AM PDT | |||
Sequence | 8 | DEVICE | 2020-06-18 09:08:09.161 AM PDT | |||
Sequence | 7 | DEVICE | 2020-06-18 09:08:09.094 AM PDT | |||
Sequence | 6 | DEVICE | 2020-06-18 09:08:09.059 AM PDT | |||
Sequence | 5 | DEVICE | 2020-06-18 09:08:09.000 AM PDT | |||
Sequence | 4 | DEVICE | 2020-06-18 09:08:08.947 AM PDT | |||
Sequence | 3 | DEVICE | 2020-06-18 09:08:08.916 AM PDT | |||
Sequence | 2 | DEVICE | 2020-06-18 09:08:08.868 AM PDT | |||
Sequence | 1 | DEVICE | 2020-06-18 09:08:08.818 AM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-18 09:08:08.759 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:08:08.720 AM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-18 09:07:58.531 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-18 09:07:58.515 AM PDT | |||
presence | present | DEVICE | 2020-06-18 09:07:58.428 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-18 09:07:34.120 AM PDT | |||
presence | not present | DEVICE | 2020-06-18 09:07:34.110 AM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-14 03:03:28.591 AM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-14 03:03:28.590 AM PDT | |||
presence | present | DEVICE | 2020-06-14 03:03:28.556 AM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-14 03:02:05.304 AM PDT | |||
Sequence | 0 | DEVICE | 2020-06-14 03:02:05.303 AM PDT | |||
presence | not present | DEVICE | 2020-06-14 03:02:05.303 AM PDT | |||
MQTTStatus | Error: | DEVICE | 2020-06-14 03:02:04.215 AM PDT | |||
Sequence | 12 | DEVICE | 2020-06-09 07:31:01.483 PM PDT | |||
Sequence | 11 | DEVICE | 2020-06-09 07:29:27.114 PM PDT | |||
Sequence | 10 | DEVICE | 2020-06-09 05:01:23.266 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-09 01:43:39.158 PM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-09 01:43:39.085 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-09 01:43:39.017 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-09 01:43:38.923 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-09 01:43:38.819 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-09 01:43:38.705 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-09 01:43:38.557 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-09 01:43:38.487 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-09 01:43:38.371 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-09 01:43:38.283 PM PDT | |||
Subscribes | 11 | DEVICE | 2020-06-09 01:43:37.804 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-09 01:43:37.723 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-09 01:43:37.643 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-09 01:43:37.563 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-09 01:43:37.474 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-09 01:43:37.390 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-09 01:43:37.305 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-09 01:43:37.177 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-09 01:43:37.098 PM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-09 01:43:36.977 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-09 01:43:36.893 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-09 01:43:36.857 PM PDT | |||
Sequence | 9 | DEVICE | 2020-06-09 01:43:34.492 PM PDT | |||
Sequence | 8 | DEVICE | 2020-06-09 01:43:34.396 PM PDT | |||
Sequence | 7 | DEVICE | 2020-06-09 01:43:34.311 PM PDT | |||
Sequence | 6 | DEVICE | 2020-06-09 01:43:34.239 PM PDT | |||
Sequence | 5 | DEVICE | 2020-06-09 01:43:34.170 PM PDT | |||
Sequence | 4 | DEVICE | 2020-06-09 01:43:34.095 PM PDT | |||
Sequence | 3 | DEVICE | 2020-06-09 01:43:34.043 PM PDT | |||
Sequence | 2 | DEVICE | 2020-06-09 01:43:33.980 PM PDT | |||
Sequence | 1 | DEVICE | 2020-06-09 01:43:33.896 PM PDT | |||
Subscribes | -1 | DEVICE | 2020-06-09 01:43:33.837 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-09 01:43:33.772 PM PDT | |||
MQTTStatus | Connect | DEVICE | 2020-06-09 01:43:23.465 PM PDT | |||
Subscribes | 1 | DEVICE | 2020-06-09 01:43:23.455 PM PDT | |||
presence | present | DEVICE | 2020-06-09 01:43:23.415 PM PDT | |||
Subscribes | 0 | DEVICE | 2020-06-09 01:42:58.162 PM PDT | |||
Sequence | 0 | DEVICE | 2020-06-09 01:42:58.156 PM PDT | |||
presence | not present | DEVICE | 2020-06-09 01:42:58.128 PM PDT | |||
Sequence | 11 | DEVICE | 2020-06-08 07:16:14.295 AM PDT | |||
Sequence | 10 | DEVICE | 2020-06-08 07:08:28.395 AM PDT | |||
Subscribes | 2 | DEVICE | 2020-06-07 12:34:25.214 PM PDT | |||
Subscribes | 3 | DEVICE | 2020-06-07 12:34:25.169 PM PDT | |||
Subscribes | 4 | DEVICE | 2020-06-07 12:34:25.145 PM PDT | |||
Subscribes | 5 | DEVICE | 2020-06-07 12:34:25.125 PM PDT | |||
Subscribes | 6 | DEVICE | 2020-06-07 12:34:25.021 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-07 12:34:24.989 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-07 12:34:24.958 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-07 12:34:24.937 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-07 12:34:24.912 PM PDT | |||
Subscribes | 11 | DEVICE | 2020-06-07 12:34:24.713 PM PDT | |||
Subscribes | 10 | DEVICE | 2020-06-07 12:34:24.687 PM PDT | |||
Subscribes | 9 | DEVICE | 2020-06-07 12:34:24.645 PM PDT | |||
Subscribes | 8 | DEVICE | 2020-06-07 12:34:24.608 PM PDT | |||
Subscribes | 7 | DEVICE | 2020-06-07 12:34:24.558 PM PDT |
Please use this tip on formatting for long posts.
Was just about to post the same....
You can also highlight all the text - click the cog icon and select hide details
D'oh! I keep forgetting about the easier way
So what you're saying Tim, and have identified all along is that there is just the one disconnect after say 3 days and it reconnects fine but the subscriptions aren't being re-created so it goes deaf.
Unfortunately after a reconnect I have to effectively run the app again from the start because it could have missed other things - but it should do that itself. I'll check.
My MQTT connection is rock solid for maybe months so I don't experience these issues, but I did cater for them. Needs a review...
Fixed...Sorry about that fellas. I knew there had to be a way to make it more compact. Thanks for the tip.
Yes, I think that’s exactly what’s happening. That makes sense. I suppose I can do a scheduled reboot every 2 or 3 days to reestablish the connection as a temporary fix. Thanks again for all the help.
If it's an issue I will fix it , probably not in time for beta 3d which is almost here now though
I suspect, but can't be sure, that something on the Pi causes the broker to reset at 3 days - do the Mosquitto logs reveal anything ? Do any other clients have logs that would show if they got bumped off ? Of course my app should handle that anyway so I still will take a look.
Thanks for the tip...I'll look into the Mosquitto logs and see if there is anything in there.
Unfortunately I don't have any other clients using the broker but maybe I'll set something else up to see if it experiences the same issues.
Thanks again!
