Let me double check. I may have accidentally used the first beta when I noticed the setup. Ill get back to you in about 5 minutes
This is a long and confusing thread .. when I release beta3 (shortly) I shall close this and get a new one started !
beta3 is a parent app with a child MQTT device driver and substantially reduces event usage. It also reworks virtual devices so don't invest time creating many of those currently. It adds json support too.
beta3 will at last I hope be feature complete with just extra devices to be added and a bit of work on homie device auto discovery to include later and any bug fixes, so going forward probably one more beta (4) and then a release version at last
Interesting! So I dont want to fill the thread with misleading information, but when the thermostat is set in the mqtt app, and is auto discovered in HA through the mosquitto mqtt plugin, a climate device through mqtt must be set in the configuration file or HA is automatically supposed to create climate device? Apologies for misleading info.
Yes - does it not ?
Is that climate discovery topic and config entry created on MQTT ?
No need for an entry in configuration.yaml
It may be in your 'unused devices' area .. or it may not be there at all
Unable to show a screenshot, perhaps because Im a new user, however, the thermostat does show up as an MQTT device. In the Device info page, it shows the list of entities
"coolingSetpoint"
"heatingSetpoint"
"FanMode"
"FanModes"
etc.
Perhaps I am missing something? (Not the other entities. They are there)
I will be requesting closure of this thread when I release beta3
The new thread is here but for beta3 related issues only please.
In the meantime beta1/2 issues continue here but I will only actively support the latest released version
excited to test this out. Thank you!
Firmware v2.2.0 has been released now for the hub.
IF you upgrade and IF you have a very busy MQTT setup with messages exchanged with your broker every few seconds and IF you experience any new slowdown after you have upgraded, then contact me re. early access to beta3.
Beta3, which is currently being tested with some users, changes from using events to a parent child setup which means that the backups that HE has to perform can complete quicker if there are lots of events. As 2.2.0 changes the way backups are prioritised, beta3 is recommended with this new firmware. Beta3 should be out for everyone this weekend anyway.
I'd love to try Beta 3 - some inconsistencies sinces moving to 2.2.x
@shane1. Dot you have a lot of updates from MQTT to HE - say more than one every 2 seconds ? Are your inconsistencies to do with speed?
If not I'd very much like details / bug reports as moving to 2.2.x should only really effect backup speeds under very heavy MQTT traffic.
An update on beta3...
Two of the pre testers identified a serious bug.
Beta 3 fixes enabling devices publishing to MQTT using ‘everything’ (all capabilities) which was broken in beta2. Consequentially devices enabled under a capability drop down like ‘dimmers’ now rigidly enforce only publishing that capability for the device, meaning in this example ‘onoff’ would not be published, you would need to enable the same device in ‘switch’ to enable that too.
Very useful but has been very awkward to implement and a couple of issues have been found. Spent a few 7am nights this week and still working on this, but I’ll get beta 3 out ASAP. This is the last remaining issue I think. It would have been very unpredictable for people upgrading.
OK I am posting beta 3 tonight at last !
It will shortly be in the MQTT beta 3 thread here.
I will leave this thread for a few days and then ask for it to be closed. If you continue to use a version prior to beta 3 or have a general question post here for the time being.
Beta 3 has a lot of changes and a whole new architecture as parent/child. It represents the last step in feature additions and is near release so I don't expect there to be a beta4.
Please read the first few posts in the new topic when upgrading or it will not work. If you are running latest 2.2.0 firmware on HE I do recommend you upgrade.
There's bound to be a few initial issues and so I will promptly post hot fixes if needed and I will be looking to add this version into Hubitat Package Manager shortly. It's only one app and one driver and one optional driver so not hard to install anyway.
@kevin did you get to creating Virtual Pressure Sensor or Omni sensor with the pressure sensor in it?
I have multiple smoke detectors, environmental sensors, and weather station, unfortunately, I can't use it easily without habitat support. Maybe @mike.maxwell will create Virtual Pressure Sensor later in some next firmware updates, pressure also missing in RM4. Until then I could use user-created driver.
The only driver I am offering is the virtual MQTT text device. I'm not intending any others and I only support creation of virtual devices using HE's virtual drivers of which there isn't a pressure one unfortunately.
@mike.maxwell any chance for creating Hubitat Virtual Pressure Sensor or is it completely out of the scope?
I am very new to MQTT. I have a broker setup and can connect to it using MQTT Explorer, but I get the following repeating message. I tried completely removing the driver and app, restarted the Hubitata, and reinstalled, but the same message pops:
2020-06-01 04:21:37.394 pm infoMQTT> MQTT connect failed attempt:[null], try again in 10 secs
dev:652020-06-01 04:21:36.362 pm infoMQTT> Connecting as Hubitat_temporary to MQTT broker null
dev:652020-06-01 04:21:36.357 pm infoMQTT> MQTT> client null temporary
Maybe a view of my broker config will help. If not, post yours so we can see what you're doing.
I could post it, but it looks nearly identical...except for the Hub Name. I have the tcp and the port the same.
OK, which broker are you running and on which operating system? What network components lie between your HE and the broker system? Using any firewall?
Have you rebooted HE after installing the MQTT app?
Mosquitto runnning on a Synology NAS. The HE is on a different subnet than the broker, but it's on the same subnet as the MQTT Alarm Panel that can connect. The gateway has full, bidirectional allow rules between the two internal subnet, and the traffic logs do not show any indications that the traffic is dropped.
