Unfortunately like I said, I’m stuck with how HE works. The next button can’t be moved. I can probably code some magic with JavaScript. The problem is the more JavaScript I use the more likely HPM is to break if/when the hubitat team changes the UI since I’m doing things in unsupported ways.
I am trying to install the myQ garage integration, but am getting the following error:
app:442020-08-01 17:49:50.750 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:49:50.710 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
I tried rebooting the hub to see if it would help, but it did not. I am able to match and update other apps with no issues.
Any recommendations for a next step?
Update: I found that the app and driver code were already on the device and I had not uninstalled them from HPM. I did that and the problem was resolved. (I had previously only removed the App and Drivers manually.)
I believe that error means there’s something wrong with the github of one of the devs that’s included in HPM.
Could you give me a little more detail on what you did? The app being installed already shouldn't cause errors like this (actually it shouldn't cause any problems at all). Any chance you can show more of the logs? It looks to me like HPM couldn't connect to Github but I'd need to see further back in the logs.
For the logs, I'll have to wait until my father is back at his place. I went through this on the hub I bought for him - will need to remote into his laptop to access them.
As for what I did - from memory:
- Deleted the garage door devices
- Deleted the garage door app (and child) but left the app and driver codes in place
- Went to HPM and searched for MyQ. Tried to install it from search result, but it didn't seem to respond
- Found it via the Garage category, tried to install it and got the error.
Edit: Added Logs. I know some prefer a Screenshot, but there is a lot in here, so I did a cut & Paste. Let me know if that's a problem. (There is probably way more than you need here, but I aired on the side of too much, rather than not enough.)
Logs (Part 1)
app:442020-08-02 01:00:01.951 infoChecking for updates for Hubitat Package Manager
app:442020-08-02 01:00:01.650 infoChecking for updates for Tasmota for Hubitat Elevation
app:442020-08-02 01:00:01.252 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-02 01:00:00.337 debugRefreshing repository list
app:442020-08-01 18:08:50.437 infoInstalling MyQ Garage Door Opener-NoSensor
app:442020-08-01 18:08:48.995 infoInstalling MyQ Garage Door Opener
app:442020-08-01 18:08:43.931 infoInstalling MyQ Lite
app:442020-08-01 18:08:43.434 infoDownloading MyQ Garage Door Opener-NoSensor
app:442020-08-01 18:08:43.043 infoDownloading MyQ Garage Door Opener
app:442020-08-01 18:08:42.679 infoDownloading MyQ Lite
app:442020-08-01 18:08:42.230 debugInstall beginning
app:442020-08-01 18:08:42.228 debugprefInstall
app:442020-08-01 18:08:39.400 debugprefInstallVerify
app:442020-08-01 18:08:23.255 debugprefInstallChoices
app:442020-08-01 18:08:17.600 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:08:17.548 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:08:17.514 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:08:17.509 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:08:17.504 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:08:17.501 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:08:17.496 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:08:17.493 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:08:17.481 debugprefInstallChoices
app:442020-08-01 18:08:11.784 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:08:11.745 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:08:11.735 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:08:11.729 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:08:11.724 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:08:11.721 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:08:11.715 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:08:11.711 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:08:11.696 debugprefInstallChoices
app:442020-08-01 18:08:10.840 debugRepositories refreshed
app:442020-08-01 18:08:10.127 infoRefreshing craigde
app:442020-08-01 18:08:09.734 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 18:08:09.333 infoRefreshing Jo Rhett
app:442020-08-01 18:08:08.903 infoRefreshing Joel Wetzel
app:442020-08-01 18:08:08.520 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 18:08:08.141 infoRefreshing Rory Jaffe
app:442020-08-01 18:08:07.725 infoRefreshing dennypage
app:442020-08-01 18:08:07.376 infoRefreshing mikec85
app:442020-08-01 18:08:06.998 infoRefreshing jrfarrar
app:442020-08-01 18:08:06.629 infoRefreshing n3!
app:442020-08-01 18:08:06.252 infoRefreshing christi999
app:442020-08-01 18:08:05.878 infoRefreshing ardichoke
app:442020-08-01 18:08:05.503 infoRefreshing lnjustin
app:442020-08-01 18:08:05.501 infoFailed to refresh null
app:442020-08-01 18:08:05.500 warnError refreshing null
app:442020-08-01 18:08:05.497 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 18:08:05.152 infoRefreshing null
app:442020-08-01 18:08:04.737 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 18:08:04.319 infoRefreshing Arn Burkhoff
app:442020-08-01 18:08:03.911 infoRefreshing thomas.c.howard
app:442020-08-01 18:08:03.548 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 18:08:03.183 infoRefreshing nh.schottfam
app:442020-08-01 18:08:02.807 infoRefreshing napalmcsr
app:442020-08-01 18:08:02.403 infoRefreshing mircolino
app:442020-08-01 18:08:01.988 infoRefreshing imnotbob
app:442020-08-01 18:08:01.575 infoRefreshing dman2306
app:442020-08-01 18:08:01.186 infoRefreshing bsileo
app:442020-08-01 18:08:00.760 infoRefreshing bcopeland
app:442020-08-01 18:08:00.386 infoRefreshing apwelsh
app:442020-08-01 18:08:00.017 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 18:07:59.645 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 18:07:59.271 infoRefreshing Matthew (@scottma61)
app:442020-08-01 18:07:58.821 infoRefreshing Markus (@markus)
app:442020-08-01 18:07:58.387 infoRefreshing MFornander
app:442020-08-01 18:07:57.977 infoRefreshing Joseph Kregloh
app:442020-08-01 18:07:57.590 infoRefreshing Inovelli
app:442020-08-01 18:07:57.204 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 18:07:56.822 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 18:07:56.411 infoRefreshing BPTWorld
app:442020-08-01 18:07:55.995 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 18:07:55.566 infoRefreshing AaronW
app:442020-08-01 18:07:55.402 debugprefPkgInstallRepository
app:442020-08-01 18:07:51.181 debugprefPkgInstall
app:442020-08-01 18:07:44.454 infoUninstalling MyQ Garage Door Opener-NoSensor
app:442020-08-01 18:07:44.331 infoUninstalling MyQ Garage Door Opener
app:442020-08-01 18:07:44.208 infoUninstalling MyQ Lite
app:442020-08-01 18:07:43.976 debugPerforming uninstall
app:442020-08-01 18:07:34.542 debugprefPkgUninstallConfirm
app:442020-08-01 18:07:28.787 debugprefPkgUninstall
app:442020-08-01 18:07:19.492 debugprefInstallChoices
app:442020-08-01 18:07:11.578 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:07:11.524 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:07:11.511 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:07:11.504 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:07:11.497 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:07:11.493 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:07:11.486 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:07:11.482 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:07:11.462 debugprefInstallChoices
app:442020-08-01 18:06:55.446 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:06:55.406 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:06:55.397 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:06:55.392 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:06:55.386 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:06:55.383 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:06:55.378 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:06:55.374 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:06:55.361 debugprefInstallChoices
app:442020-08-01 18:06:51.134 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 18:06:51.094 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 18:06:51.036 debugprefInstallVerify
app:442020-08-01 18:03:33.047 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:03:32.994 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:03:32.981 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:03:32.974 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:03:32.967 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:03:32.964 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:03:32.957 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:03:32.953 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:03:32.935 debugprefInstallChoices
app:442020-08-01 18:02:27.380 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 18:02:27.321 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 18:02:27.269 debugprefInstallVerify
app:442020-08-01 18:02:18.834 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:02:18.798 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:02:18.789 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:02:18.782 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:02:18.777 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:02:18.774 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:02:18.769 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:02:18.765 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:02:18.753 debugprefInstallChoices
app:442020-08-01 18:01:59.148 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 18:01:59.094 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 18:01:59.082 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 18:01:59.075 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 18:01:59.066 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 18:01:59.062 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 18:01:59.056 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 18:01:59.051 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 18:01:59.018 debugprefInstallChoices
app:442020-08-01 18:01:58.369 debugRepositories refreshed
app:442020-08-01 18:01:57.677 infoRefreshing craigde
app:442020-08-01 18:01:57.417 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 18:01:57.159 infoRefreshing Jo Rhett
app:442020-08-01 18:01:56.910 infoRefreshing Joel Wetzel
app:442020-08-01 18:01:56.613 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 18:01:56.314 infoRefreshing Rory Jaffe
app:442020-08-01 18:01:56.008 infoRefreshing dennypage
app:442020-08-01 18:01:55.709 infoRefreshing mikec85
app:442020-08-01 18:01:55.411 infoRefreshing jrfarrar
app:442020-08-01 18:01:55.118 infoRefreshing n3!
app:442020-08-01 18:01:54.887 infoRefreshing christi999
app:442020-08-01 18:01:54.596 infoRefreshing ardichoke
app:442020-08-01 18:01:54.312 infoRefreshing lnjustin
app:442020-08-01 18:01:54.309 infoFailed to refresh null
app:442020-08-01 18:01:54.306 warnError refreshing null
app:442020-08-01 18:01:54.296 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 18:01:54.000 infoRefreshing null
app:442020-08-01 18:01:53.741 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 18:01:53.483 infoRefreshing Arn Burkhoff
app:442020-08-01 18:01:53.223 infoRefreshing thomas.c.howard
app:442020-08-01 18:01:52.715 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 18:01:52.459 infoRefreshing nh.schottfam
app:442020-08-01 18:01:52.203 infoRefreshing napalmcsr
app:442020-08-01 18:01:51.929 infoRefreshing mircolino
app:442020-08-01 18:01:51.643 infoRefreshing imnotbob
app:442020-08-01 18:01:51.383 infoRefreshing dman2306
app:442020-08-01 18:01:51.126 infoRefreshing bsileo
app:442020-08-01 18:01:50.894 infoRefreshing bcopeland
app:442020-08-01 18:01:50.653 infoRefreshing apwelsh
app:442020-08-01 18:01:50.361 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 18:01:50.078 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 18:01:49.794 infoRefreshing Matthew (@scottma61)
app:442020-08-01 18:01:49.525 infoRefreshing Markus (@markus)
app:442020-08-01 18:01:49.261 infoRefreshing MFornander
app:442020-08-01 18:01:48.992 infoRefreshing Joseph Kregloh
app:442020-08-01 18:01:48.713 infoRefreshing Inovelli
app:442020-08-01 18:01:48.410 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 18:01:48.122 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 18:01:47.691 infoRefreshing BPTWorld
app:442020-08-01 18:01:47.199 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 18:01:46.831 infoRefreshing AaronW
app:442020-08-01 18:01:46.656 debugprefPkgInstallRepository
app:442020-08-01 18:01:42.905 debugprefPkgInstall
app:442020-08-01 18:01:34.695 debugUpdates complete
app:442020-08-01 18:01:33.374 infoInstalling Tasmota - Universal Multi Sensor (Child)
app:442020-08-01 18:01:31.738 infoUpgrading Tasmota - Universal Metering Plug/Outlet (Child)
app:442020-08-01 18:01:29.909 infoUpgrading Tasmota - Universal CT/RGB/RGB+CW+WW (Child)
app:442020-08-01 18:01:21.585 infoUpgrading Tasmota - Universal Parent
app:442020-08-01 18:01:11.560 infoUpgrading Tasmota Device Manager
app:442020-08-01 18:01:10.925 infoDownloading Tasmota - Universal Multi Sensor (Child) because it is required and not installed
app:442020-08-01 18:01:10.529 infoDownloading Tasmota - Universal Metering Plug/Outlet (Child)
app:442020-08-01 18:01:09.817 infoDownloading Tasmota - Universal CT/RGB/RGB+CW+WW (Child)
app:442020-08-01 18:01:09.251 infoDownloading Tasmota - Universal Parent
app:442020-08-01 18:01:08.746 infoDownloading Tasmota Device Manager
app:442020-08-01 18:01:08.276 debugPerforming update
app:442020-08-01 18:01:05.276 debugprefPkgVerifyUpdates
app:442020-08-01 18:01:02.530 debugUpdates available
app:442020-08-01 18:00:58.085 debugUpdates available
app:442020-08-01 18:00:56.523 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 18:00:56.511 debugUpdates found specificdriver for https://raw.githubusercontent.com/markus-li/Hubitat/release/packageManifest.json -> Tasmota - Universal Metering Plug/Outlet (Child) (force production: true)
app:442020-08-01 18:00:56.502 debugUpdates found specificdriver for https://raw.githubusercontent.com/markus-li/Hubitat/release/packageManifest.json -> Tasmota - Universal CT/RGB/RGB+CW+WW (Child) (force production: true)
app:442020-08-01 18:00:56.483 debugUpdates found specificdriver for https://raw.githubusercontent.com/markus-li/Hubitat/release/packageManifest.json -> Tasmota - Universal Parent (force production: true)
app:442020-08-01 18:00:56.478 debugUpdates found specificapp for https://raw.githubusercontent.com/markus-li/Hubitat/release/packageManifest.json -> Tasmota Device Manager (force production: true)
app:442020-08-01 18:00:56.207 infoChecking for updates for Tasmota for Hubitat Elevation
app:442020-08-01 18:00:55.943 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 18:00:55.777 debugUpdate chosen
app:442020-08-01 18:00:51.499 debugRefreshing repository list
app:442020-08-01 18:00:40.847 debugprefPkgMatchUpComplete
app:442020-08-01 18:00:27.867 infoMatching up packages
app:442020-08-01 18:00:27.114 infoRefreshing craigde
app:442020-08-01 18:00:25.858 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 18:00:25.050 infoRefreshing Jo Rhett
app:442020-08-01 18:00:20.663 infoRefreshing Joel Wetzel
app:442020-08-01 18:00:18.243 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 18:00:17.434 infoRefreshing Rory Jaffe
app:442020-08-01 18:00:15.050 infoRefreshing dennypage
app:442020-08-01 18:00:13.977 infoRefreshing mikec85
app:442020-08-01 18:00:13.237 infoRefreshing jrfarrar
app:442020-08-01 18:00:11.646 infoRefreshing n3!
app:442020-08-01 18:00:10.888 infoRefreshing christi999
app:442020-08-01 18:00:10.012 infoRefreshing ardichoke
app:442020-08-01 18:00:08.944 infoRefreshing lnjustin
app:442020-08-01 18:00:08.942 infoFailed to refresh null
app:442020-08-01 18:00:08.940 warnError refreshing null
app:442020-08-01 18:00:08.931 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 18:00:08.611 infoRefreshing null
app:442020-08-01 18:00:07.769 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 18:00:07.002 infoRefreshing Arn Burkhoff
app:442020-08-01 18:00:06.179 infoRefreshing thomas.c.howard
app:442020-08-01 18:00:04.582 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 18:00:02.090 infoRefreshing nh.schottfam
app:442020-08-01 18:00:00.123 infoRefreshing napalmcsr
app:442020-08-01 17:59:59.305 infoRefreshing mircolino
app:442020-08-01 17:59:58.504 infoRefreshing imnotbob
app:442020-08-01 17:59:50.230 infoRefreshing dman2306
app:442020-08-01 17:59:49.451 infoRefreshing bsileo
app:442020-08-01 17:59:39.848 infoRefreshing bcopeland
app:442020-08-01 17:59:38.524 infoRefreshing apwelsh
app:442020-08-01 17:59:36.557 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:59:35.357 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 17:59:33.279 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:59:25.503 infoRefreshing Markus (@markus)
app:442020-08-01 17:59:24.135 infoRefreshing MFornander
app:442020-08-01 17:59:23.371 infoRefreshing Joseph Kregloh
app:442020-08-01 17:59:22.205 infoRefreshing Inovelli
app:442020-08-01 17:59:20.635 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:59:17.315 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:59:00.556 infoRefreshing BPTWorld
app:442020-08-01 17:58:59.853 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:58:57.064 infoRefreshing AaronW
app:442020-08-01 17:58:56.729 debugRefreshing repository list
app:442020-08-01 17:58:56.524 infoRetrieving list of installed drivers
app:442020-08-01 17:58:55.110 infoRetrieving list of installed apps
app:442020-08-01 17:58:54.962 debugPerforming Package Matching
app:442020-08-01 17:58:51.845 debugprefPkgMatchUp
app:442020-08-01 17:58:41.930 debugNo updates available
app:442020-08-01 17:58:40.220 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:58:39.891 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:58:39.487 debugUpdate chosen
app:442020-08-01 17:58:32.982 debugRefreshing repository list
app:442020-08-01 17:56:02.139 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:56:02.127 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:56:02.096 debugprefInstallVerify
app:442020-08-01 17:56:00.266 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:56:00.008 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:59.871 debugUpdate chosen
app:442020-08-01 17:55:59.156 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:59.144 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:59.113 debugprefInstallVerify
app:442020-08-01 17:55:57.289 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:57.027 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:56.857 debugUpdate chosen
app:442020-08-01 17:55:56.220 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:56.208 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:56.175 debugprefInstallVerify
app:442020-08-01 17:55:54.360 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:54.101 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:53.941 debugUpdate chosen
app:442020-08-01 17:55:53.132 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:53.119 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:53.087 debugprefInstallVerify
app:442020-08-01 17:55:51.287 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:51.016 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:50.852 debugUpdate chosen
app:442020-08-01 17:55:50.136 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:50.123 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:50.081 debugprefInstallVerify
app:442020-08-01 17:55:48.244 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:47.988 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:47.850 debugUpdate chosen
app:442020-08-01 17:55:47.079 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:47.066 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:47.034 debugprefInstallVerify
app:442020-08-01 17:55:45.187 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:44.956 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:44.812 debugUpdate chosen
app:442020-08-01 17:55:44.008 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:43.997 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:43.963 debugprefInstallVerify
app:442020-08-01 17:55:42.141 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:41.883 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:41.729 debugUpdate chosen
app:442020-08-01 17:55:32.730 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:32.717 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:32.684 debugprefInstallVerify
app:442020-08-01 17:55:31.001 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:30.617 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:30.441 debugUpdate chosen
app:442020-08-01 17:55:20.369 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:20.355 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
Logs (Part 2)
app:442020-08-01 17:55:18.504 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:18.247 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:18.091 debugUpdate chosen
app:442020-08-01 17:55:17.483 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:17.470 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:17.438 debugprefInstallVerify
app:442020-08-01 17:55:15.611 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:15.342 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:15.196 debugUpdate chosen
app:442020-08-01 17:55:14.044 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:14.027 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:13.971 debugprefInstallVerify
app:442020-08-01 17:55:12.162 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:11.899 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:11.752 debugUpdate chosen
app:442020-08-01 17:55:10.396 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:10.380 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:10.349 debugprefInstallVerify
app:442020-08-01 17:55:08.522 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:08.260 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:08.107 debugUpdate chosen
app:442020-08-01 17:55:07.037 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:07.022 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:06.990 debugprefInstallVerify
app:442020-08-01 17:55:05.171 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:04.912 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:04.741 debugUpdate chosen
app:442020-08-01 17:55:03.374 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:55:03.360 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:55:03.326 debugprefInstallVerify
app:442020-08-01 17:55:01.466 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:55:01.236 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:55:01.088 debugUpdate chosen
app:442020-08-01 17:54:52.775 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:54:52.759 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:54:52.724 debugprefInstallVerify
app:442020-08-01 17:54:51.339 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 17:54:50.630 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 17:54:50.473 debugUpdate chosen
app:442020-08-01 17:54:35.540 debugRepositories refreshed
app:442020-08-01 17:54:35.191 infoRefreshing craigde
app:442020-08-01 17:54:34.919 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 17:54:34.647 infoRefreshing Jo Rhett
app:442020-08-01 17:54:34.351 infoRefreshing Joel Wetzel
app:442020-08-01 17:54:34.092 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 17:54:33.842 infoRefreshing Rory Jaffe
app:442020-08-01 17:54:33.584 infoRefreshing dennypage
app:442020-08-01 17:54:33.442 debugprefPkgInstall
app:442020-08-01 17:54:33.352 infoRefreshing mikec85
app:442020-08-01 17:54:33.064 infoRefreshing jrfarrar
app:442020-08-01 17:54:32.776 infoRefreshing n3!
app:442020-08-01 17:54:32.470 infoRefreshing christi999
app:442020-08-01 17:54:32.186 infoRefreshing ardichoke
app:442020-08-01 17:54:31.879 infoRefreshing lnjustin
app:442020-08-01 17:54:31.874 infoFailed to refresh null
app:442020-08-01 17:54:31.871 warnError refreshing null
app:442020-08-01 17:54:31.863 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 17:54:31.619 infoRefreshing null
app:442020-08-01 17:54:31.357 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 17:54:31.100 infoRefreshing Arn Burkhoff
app:442020-08-01 17:54:30.864 errorjava.util.ConcurrentModificationException: null on line 429 (prefPkgInstallRepository)
app:442020-08-01 17:54:30.844 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 17:54:30.844 infoRefreshing thomas.c.howard
app:442020-08-01 17:54:30.835 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 17:54:30.830 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 17:54:30.808 debugprefInstallChoices
app:442020-08-01 17:54:30.743 debugRepositories refreshed
app:442020-08-01 17:54:30.574 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 17:54:30.379 infoRefreshing craigde
app:442020-08-01 17:54:30.335 infoRefreshing nh.schottfam
app:442020-08-01 17:54:30.140 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 17:54:30.098 infoRefreshing napalmcsr
app:442020-08-01 17:54:29.905 infoRefreshing Jo Rhett
app:442020-08-01 17:54:29.858 infoRefreshing mircolino
app:442020-08-01 17:54:29.663 infoRefreshing Joel Wetzel
app:442020-08-01 17:54:29.622 infoRefreshing imnotbob
app:442020-08-01 17:54:29.402 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 17:54:29.357 infoRefreshing dman2306
app:442020-08-01 17:54:29.151 infoRefreshing Rory Jaffe
app:442020-08-01 17:54:29.110 infoRefreshing bsileo
app:442020-08-01 17:54:28.913 infoRefreshing dennypage
app:442020-08-01 17:54:28.871 infoRefreshing bcopeland
app:442020-08-01 17:54:28.678 infoRefreshing mikec85
app:442020-08-01 17:54:28.637 infoRefreshing apwelsh
app:442020-08-01 17:54:28.442 infoRefreshing jrfarrar
app:442020-08-01 17:54:28.398 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:54:28.203 infoRefreshing n3!
app:442020-08-01 17:54:28.159 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 17:54:27.977 infoRefreshing christi999
app:442020-08-01 17:54:27.935 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:54:27.874 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:54:27.859 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:54:27.818 debugprefInstallVerify
app:442020-08-01 17:54:27.738 infoRefreshing ardichoke
app:442020-08-01 17:54:27.694 infoRefreshing Markus (@markus)
app:442020-08-01 17:54:27.502 infoRefreshing lnjustin
app:442020-08-01 17:54:27.500 infoFailed to refresh null
app:442020-08-01 17:54:27.499 warnError refreshing null
app:442020-08-01 17:54:27.496 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 17:54:27.451 infoRefreshing MFornander
app:442020-08-01 17:54:27.258 infoRefreshing null
app:442020-08-01 17:54:27.216 infoRefreshing Joseph Kregloh
app:442020-08-01 17:54:27.022 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 17:54:26.979 infoRefreshing Inovelli
app:442020-08-01 17:54:26.786 infoRefreshing Arn Burkhoff
app:442020-08-01 17:54:26.744 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:54:26.541 infoRefreshing thomas.c.howard
app:442020-08-01 17:54:26.501 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:54:26.291 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 17:54:26.249 infoRefreshing BPTWorld
app:442020-08-01 17:54:26.052 infoRefreshing nh.schottfam
app:442020-08-01 17:54:26.010 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:54:25.813 infoRefreshing napalmcsr
app:442020-08-01 17:54:25.762 errorjava.lang.IllegalArgumentException: Comparison method violates its general contract! on line 578 (performRepositoryRefresh)
app:442020-08-01 17:54:25.762 errorjava.util.ConcurrentModificationException: null on line 578 (performRepositoryRefresh)
app:442020-08-01 17:54:25.759 infoRefreshing AaronW
app:442020-08-01 17:54:25.575 debugprefPkgInstallRepository
app:442020-08-01 17:54:25.566 infoRefreshing mircolino
app:442020-08-01 17:54:25.307 infoRefreshing imnotbob
app:442020-08-01 17:54:25.303 infoRefreshing craigde
app:442020-08-01 17:54:25.259 infoRefreshing craigde
app:442020-08-01 17:54:25.074 infoRefreshing dman2306
app:442020-08-01 17:54:24.968 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 17:54:24.919 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 17:54:24.843 infoRefreshing bsileo
app:442020-08-01 17:54:24.584 infoRefreshing bcopeland
app:442020-08-01 17:54:24.487 infoRefreshing Jo Rhett
app:442020-08-01 17:54:24.342 infoRefreshing apwelsh
app:442020-08-01 17:54:24.144 infoRefreshing Joel Wetzel
app:442020-08-01 17:54:24.079 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:54:23.840 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 17:54:23.808 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 17:54:23.605 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:54:23.540 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:54:23.525 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:54:23.485 debugprefInstallVerify
app:442020-08-01 17:54:23.447 infoRefreshing Rory Jaffe
app:442020-08-01 17:54:23.369 infoRefreshing Markus (@markus)
app:442020-08-01 17:54:23.131 infoRefreshing MFornander
app:442020-08-01 17:54:23.097 infoRefreshing dennypage
app:442020-08-01 17:54:22.902 infoRefreshing Joseph Kregloh
app:442020-08-01 17:54:22.854 infoRefreshing mikec85
app:442020-08-01 17:54:22.735 infoRefreshing mikec85
app:442020-08-01 17:54:22.624 infoRefreshing Inovelli
app:442020-08-01 17:54:22.568 infoRefreshing jrfarrar
app:442020-08-01 17:54:22.392 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:54:22.352 infoRefreshing jrfarrar
app:442020-08-01 17:54:22.338 infoRefreshing n3!
app:442020-08-01 17:54:22.162 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:54:22.109 infoRefreshing christi999
app:442020-08-01 17:54:22.021 infoRefreshing n3!
app:442020-08-01 17:54:21.915 infoRefreshing BPTWorld
app:442020-08-01 17:54:21.873 infoRefreshing ardichoke
app:442020-08-01 17:54:21.677 infoRefreshing christi999
app:442020-08-01 17:54:21.676 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:54:21.623 infoRefreshing lnjustin
app:442020-08-01 17:54:21.620 infoFailed to refresh null
app:442020-08-01 17:54:21.619 warnError refreshing null
app:442020-08-01 17:54:21.617 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 17:54:21.443 infoRefreshing AaronW
app:442020-08-01 17:54:21.379 infoRefreshing null
app:442020-08-01 17:54:21.337 infoRefreshing ardichoke
app:442020-08-01 17:54:21.222 debugprefPkgInstallRepository
app:442020-08-01 17:54:21.145 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 17:54:20.977 infoRefreshing lnjustin
app:442020-08-01 17:54:20.975 infoFailed to refresh null
app:442020-08-01 17:54:20.974 warnError refreshing null
app:442020-08-01 17:54:20.972 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 17:54:20.914 infoRefreshing Arn Burkhoff
app:442020-08-01 17:54:20.680 infoRefreshing thomas.c.howard
app:442020-08-01 17:54:20.657 infoRefreshing null
app:442020-08-01 17:54:20.450 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 17:54:20.292 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 17:54:20.224 infoRefreshing nh.schottfam
app:442020-08-01 17:54:19.988 infoRefreshing napalmcsr
app:442020-08-01 17:54:19.890 infoRefreshing Arn Burkhoff
app:442020-08-01 17:54:19.751 infoRefreshing mircolino
app:442020-08-01 17:54:19.541 infoRefreshing thomas.c.howard
app:442020-08-01 17:54:19.512 infoRefreshing imnotbob
app:442020-08-01 17:54:19.248 infoRefreshing dman2306
app:442020-08-01 17:54:19.207 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 17:54:19.018 infoRefreshing bsileo
app:442020-08-01 17:54:18.862 infoRefreshing nh.schottfam
app:442020-08-01 17:54:18.787 infoRefreshing bcopeland
app:442020-08-01 17:54:18.547 infoRefreshing apwelsh
app:442020-08-01 17:54:18.515 infoRefreshing napalmcsr
app:442020-08-01 17:54:18.311 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:54:18.162 infoRefreshing mircolino
app:442020-08-01 17:54:18.053 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 17:54:17.795 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:54:17.793 infoRefreshing imnotbob
app:442020-08-01 17:54:17.622 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:54:17.605 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:54:17.566 debugprefInstallVerify
app:442020-08-01 17:54:17.527 infoRefreshing Markus (@markus)
app:442020-08-01 17:54:17.438 infoRefreshing dman2306
app:442020-08-01 17:54:17.290 infoRefreshing MFornander
app:442020-08-01 17:54:17.090 infoRefreshing bsileo
app:442020-08-01 17:54:17.052 infoRefreshing Joseph Kregloh
app:442020-08-01 17:54:16.823 infoRefreshing Inovelli
app:442020-08-01 17:54:16.674 infoRefreshing bcopeland
app:442020-08-01 17:54:16.556 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:54:16.287 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:54:16.275 infoRefreshing apwelsh
app:442020-08-01 17:54:15.988 infoRefreshing BPTWorld
app:442020-08-01 17:54:15.891 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:54:15.744 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:54:15.545 infoRefreshing Miles Budnek (@mbudnek)
Logs (Part 3)
app:442020-08-01 17:54:15.493 infoRefreshing AaronW
app:442020-08-01 17:54:15.300 debugprefPkgInstallRepository
app:442020-08-01 17:54:15.159 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:54:14.756 infoRefreshing Markus (@markus)
app:442020-08-01 17:54:14.315 infoRefreshing MFornander
app:442020-08-01 17:54:13.927 infoRefreshing Joseph Kregloh
app:442020-08-01 17:54:13.553 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:54:13.534 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:54:13.511 infoRefreshing Inovelli
app:442020-08-01 17:54:13.492 debugprefInstallVerify
app:442020-08-01 17:54:13.119 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:54:12.691 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:54:12.240 infoRefreshing BPTWorld
app:442020-08-01 17:54:11.820 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:54:11.388 infoRefreshing AaronW
app:442020-08-01 17:54:11.224 debugprefPkgInstallRepository
app:442020-08-01 17:54:06.809 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:54:06.791 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:54:06.720 debugprefInstallVerify
app:442020-08-01 17:53:00.575 debugRepositories refreshed
app:442020-08-01 17:53:00.166 infoRefreshing craigde
app:442020-08-01 17:52:59.871 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 17:52:59.611 infoRefreshing Jo Rhett
app:442020-08-01 17:52:59.351 infoRefreshing Joel Wetzel
app:442020-08-01 17:52:59.093 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 17:52:58.825 infoRefreshing Rory Jaffe
app:442020-08-01 17:52:58.554 infoRefreshing dennypage
app:442020-08-01 17:52:58.290 infoRefreshing mikec85
app:442020-08-01 17:52:58.032 infoRefreshing jrfarrar
app:442020-08-01 17:52:57.764 infoRefreshing n3!
app:442020-08-01 17:52:57.470 infoRefreshing christi999
app:442020-08-01 17:52:57.177 infoRefreshing ardichoke
app:442020-08-01 17:52:56.893 infoRefreshing lnjustin
app:442020-08-01 17:52:56.891 infoFailed to refresh null
app:442020-08-01 17:52:56.889 warnError refreshing null
app:442020-08-01 17:52:56.883 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 17:52:56.532 infoRefreshing null
app:442020-08-01 17:52:56.274 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 17:52:56.018 infoRefreshing Arn Burkhoff
app:442020-08-01 17:52:55.779 infoRefreshing thomas.c.howard
app:442020-08-01 17:52:55.518 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 17:52:55.255 infoRefreshing nh.schottfam
app:442020-08-01 17:52:54.992 infoRefreshing napalmcsr
app:442020-08-01 17:52:54.874 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:52:54.858 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:52:54.818 debugprefInstallVerify
app:442020-08-01 17:52:54.724 infoRefreshing mircolino
app:442020-08-01 17:52:54.448 infoRefreshing imnotbob
app:442020-08-01 17:52:54.170 infoRefreshing dman2306
app:442020-08-01 17:52:53.913 infoRefreshing bsileo
app:442020-08-01 17:52:53.648 infoRefreshing bcopeland
app:442020-08-01 17:52:53.338 infoRefreshing apwelsh
app:442020-08-01 17:52:53.020 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:52:52.725 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 17:52:52.458 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:52:52.188 infoRefreshing Markus (@markus)
app:442020-08-01 17:52:52.065 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:52:52.048 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:52:52.008 debugprefInstallVerify
app:442020-08-01 17:52:51.910 infoRefreshing MFornander
app:442020-08-01 17:52:51.622 infoRefreshing Joseph Kregloh
app:442020-08-01 17:52:51.359 infoRefreshing Inovelli
app:442020-08-01 17:52:51.095 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:52:50.831 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:52:50.550 infoRefreshing BPTWorld
app:442020-08-01 17:52:50.277 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:52:49.923 infoRefreshing AaronW
app:442020-08-01 17:52:49.765 debugprefPkgInstallRepository
app:442020-08-01 17:52:47.308 errorjava.lang.NullPointerException: Cannot get property 'licenseFile' on null object on line 601 (prefInstallVerify)
app:442020-08-01 17:52:47.293 errorError downloading null: java.lang.IllegalStateException: Default URI is null, and no 'uri' parameter was given
app:442020-08-01 17:52:47.240 debugprefInstallVerify
app:442020-08-01 17:49:50.670 debugprefInstallVerify
app:442020-08-01 17:49:45.442 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 17:49:45.408 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 17:49:45.399 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 17:49:45.395 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 17:49:45.390 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 17:49:45.388 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 17:49:45.383 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 17:49:45.380 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 17:49:45.364 debugprefInstallChoices
app:442020-08-01 17:49:42.022 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 17:49:41.987 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 17:49:41.978 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 17:49:41.974 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 17:49:41.966 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 17:49:41.964 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 17:49:41.959 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 17:49:41.956 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 17:49:41.944 debugprefInstallChoices
app:442020-08-01 17:49:26.173 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STAmbientWeather/master/hubitat/packageManifest.json
app:442020-08-01 17:49:26.135 warnInvalid category found Weather for https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/NOAA/packageManifest.json
app:442020-08-01 17:49:26.125 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/weatherflow/packageManifest.json
app:442020-08-01 17:49:26.119 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/sun-calc/packageManifest.json
app:442020-08-01 17:49:26.112 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/rainforest-eagle/packageManifest.json
app:442020-08-01 17:49:26.109 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/somfy-zrtsi/packageManifest.json
app:442020-08-01 17:49:26.104 warnInvalid tag found Integrations for https://raw.githubusercontent.com/KurtSanders/STBitBarApp-V2/master/packageManifest.json
app:442020-08-01 17:49:26.100 warnInvalid category found null for https://raw.githubusercontent.com/augoisms/hubitat/master/laundry-manager/packageManifest.json
app:442020-08-01 17:49:26.067 debugprefInstallChoices
app:442020-08-01 17:49:24.443 debugRepositories refreshed
app:442020-08-01 17:49:23.701 infoRefreshing craigde
app:442020-08-01 17:49:23.310 infoRefreshing Kurt Sanders (kurtsanders)
app:442020-08-01 17:49:22.899 infoRefreshing Jo Rhett
app:442020-08-01 17:49:22.593 infoRefreshing Joel Wetzel
app:442020-08-01 17:49:22.280 infoRefreshing Justin Walker (augoisms)
app:442020-08-01 17:49:21.916 infoRefreshing Rory Jaffe
app:442020-08-01 17:49:21.522 infoRefreshing dennypage
app:442020-08-01 17:49:21.082 infoRefreshing mikec85
app:442020-08-01 17:49:20.694 infoRefreshing jrfarrar
app:442020-08-01 17:49:20.346 infoRefreshing n3!
app:442020-08-01 17:49:19.967 infoRefreshing christi999
app:442020-08-01 17:49:19.654 infoRefreshing ardichoke
app:442020-08-01 17:49:19.290 infoRefreshing lnjustin
app:442020-08-01 17:49:19.287 infoFailed to refresh null
app:442020-08-01 17:49:19.286 warnError refreshing null
app:442020-08-01 17:49:19.282 errorError downloading https://raw.githubusercontent.com/dmike3/Hubitat/master/repository.json: groovyx.net.http.HttpResponseException: Not Found
app:442020-08-01 17:49:18.903 infoRefreshing null
app:442020-08-01 17:49:18.567 infoRefreshing Marco Felicio (maffpt@gmail.com)
app:442020-08-01 17:49:18.251 infoRefreshing Arn Burkhoff
app:442020-08-01 17:49:17.882 infoRefreshing thomas.c.howard
app:442020-08-01 17:49:17.522 infoRefreshing storageaanarchy (SANdood)
app:442020-08-01 17:49:17.161 infoRefreshing nh.schottfam
app:442020-08-01 17:49:16.852 infoRefreshing napalmcsr
app:442020-08-01 17:49:16.469 infoRefreshing mircolino
app:442020-08-01 17:49:16.077 infoRefreshing imnotbob
app:442020-08-01 17:49:15.694 infoRefreshing dman2306
app:442020-08-01 17:49:15.270 infoRefreshing bsileo
app:442020-08-01 17:49:14.846 infoRefreshing bcopeland
app:442020-08-01 17:49:14.462 infoRefreshing apwelsh
app:442020-08-01 17:49:14.063 infoRefreshing RMoRobert (BertABCD1234)
app:442020-08-01 17:49:13.696 infoRefreshing Miles Budnek (@mbudnek)
app:442020-08-01 17:49:13.318 infoRefreshing Matthew (@scottma61)
app:442020-08-01 17:49:12.936 infoRefreshing Markus (@markus)
app:442020-08-01 17:49:12.531 infoRefreshing MFornander
app:442020-08-01 17:49:12.104 infoRefreshing Joseph Kregloh
app:442020-08-01 17:49:11.729 infoRefreshing Inovelli
app:442020-08-01 17:49:11.383 infoRefreshing Dave Gutheinz(DavGut)
app:442020-08-01 17:49:11.000 infoRefreshing Brian Wilson (@brianwilson)
app:442020-08-01 17:49:10.616 infoRefreshing BPTWorld
app:442020-08-01 17:49:10.289 infoRefreshing Anthony S. (tonesto7)
app:442020-08-01 17:49:09.952 infoRefreshing AaronW
app:442020-08-01 17:49:09.821 debugprefPkgInstallRepository
app:442020-08-01 17:49:06.448 debugprefPkgInstall
app:442020-08-01 17:48:58.865 debugprefInstallRepositorySearchResults
app:442020-08-01 17:48:46.985 debugprefInstallRepositorySearchResults
app:442020-08-01 17:48:37.940 debugprefInstallRepositorySearchResults
app:442020-08-01 17:48:25.876 debugprefInstallRepositorySearchResults
app:442020-08-01 17:48:18.072 debugprefInstallRepositorySearch
app:442020-08-01 17:48:16.226 debugprefPkgInstall
app:442020-08-01 17:48:13.459 debugUpdating HPM version to 1.6.0 from previous upgrade
app:442020-08-01 17:48:12.885 debugRefreshing repository list
app:442020-08-01 01:00:01.247 infoChecking for updates for Hubitat Package Manager
app:442020-08-01 01:00:00.863 infoChecking for updates for MyQ Garage Door Integration
app:442020-08-01 01:00:00.337 debugRefreshing repository list
Those logs are very confusing... any chance you were trying to do this at the same time the autoupdate is configured to run?
Now that you say that, I do remember that I tried an update at some point during the process... I wanted to ensure I had the latest version of HPM. I suspect that that is what you are seeing.
Was it in a different tab? What's confusing is they seem to be happening at the same time which would cause issues.
@dman2306 Why is package manager attaching itself to an app in a way that if we wanted to remove package manager, say to another hub, it won't let you remove it until you remove the associations to the apps it has in the list. Does that mean you would have to delete all the apps it is tracking?? There is no Remove button.
If you hit the gear in the upper right corner of the Hubitat Package Manager and scroll to the bottom and click remove will it remove without removing the apps it is monitoring? I'd rather not remove it right now but would like to know how if necessary.
Thanks, that worked. I was able to re-install it on another hub.
Good question... I think I did it sequentially, but can't say for 100% sure that I did.
Interesting, that's mine ... it worked when I used it to update but I admit I didn't try match up; let me see what's wrong there.
[update] Sorry about that, I updated the description but missed the trailing comma required by json. All fixed now.
Only thing worse than commas in programming are spaces.
Installed.
This is awesome.....how do we convince other package devs to add theirs?
bribes work sometimes
