I unchecked “Pre-roll silence” and it did not make a difference. The first sentence was clipped. It only played the second sentence.
Not sure how to change the silence.wav file to silence.mp3. Are there some lines in the app code that you want me to change on my end? If so let me know
Thanks for all your help. If you want to take a break from this I would understand.
EDIT: Here is a code snippet of the log with Pre-roll silence unchecked:
dev:17872026-07-10 7:23:23.485 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> e70c6394-67f5-44da-882b-44e7c9be5569: {"type":"GET_STATUS","requestId":660}
dev:17872026-07-10 7:23:22.473 amdebugGC+ [Kitchen display] media: IDLE
dev:17872026-07-10 7:23:22.471 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.receiver -> receiver-0: {"type":"SET_VOLUME","volume":{"level":0.65},"requestId":659}
dev:17642026-07-10 7:23:22.372 aminfoKitchen display - [Google Nest Hub] is idle
dev:17872026-07-10 7:23:22.342 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> e70c6394-67f5-44da-882b-44e7c9be5569: {"type":"GET_STATUS","requestId":658}
dev:17872026-07-10 7:23:20.260 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> e70c6394-67f5-44da-882b-44e7c9be5569: {"type":"GET_STATUS","requestId":657}
dev:17872026-07-10 7:23:19.453 amdebugGC+ [Kitchen display] media: PLAYING | Announcement
dev:17642026-07-10 7:23:19.432 aminfoKitchen display - [Google Nest Hub] is playing
dev:17872026-07-10 7:23:19.406 amdebugGC+ [Kitchen display] media: BUFFERING
dev:17642026-07-10 7:23:19.389 aminfoKitchen display - [Google Nest Hub] is buffering
dev:17872026-07-10 7:23:19.365 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> e70c6394-67f5-44da-882b-44e7c9be5569: {"type":"GET_STATUS","requestId":656}
dev:17872026-07-10 7:23:19.337 amdebugGC+ [Kitchen display] media: IDLE | Announcement
dev:17872026-07-10 7:23:19.254 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> e70c6394-67f5-44da-882b-44e7c9be5569: {"type":"LOAD","requestId":655,"autoplay":true,"currentTime":0,"media":{"contentId":"http://192.168.11.100/tts/3a9210e05a56e555a1ffb67e908c29a1.mp3","streamType":"BUFFERED","contentType":"audio/mpeg","metadata":{"metadataType":0,"title":"Announcement","subtitle":""}}}
dev:17872026-07-10 7:23:19.247 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.receiver -> receiver-0: {"type":"SET_VOLUME","volume":{"level":0.65},"requestId":654}
dev:17872026-07-10 7:23:19.245 amdebugGC+ [Kitchen display] TTS: begin (conn=APP_CONNECTED, transport=set, mode=restore)
dev:17872026-07-10 7:23:19.239 aminfoGC+ [Kitchen display] TTS: "This is a test. This is another test" (mode=restore, volume=65, voice=Salli)
EDIT: Here are the logs with the Pre-Roll checked with a 2 sec delay using your Version 1.05. Note the first sentence is still truncated.
dev:17872026-07-10 8:08:36.937 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":702}
dev:17872026-07-10 8:08:35.922 amdebugGC+ [Kitchen display] media: IDLE
dev:17872026-07-10 8:08:35.920 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.receiver -> receiver-0: {"type":"SET_VOLUME","volume":{"level":0.65},"requestId":701}
dev:17642026-07-10 8:08:35.859 aminfoKitchen display - [Google Nest Hub] is idle
dev:17872026-07-10 8:08:35.827 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":700}
dev:17872026-07-10 8:08:32.913 amdebugGC+ [Kitchen display] media: PLAYING | Announcement
dev:17642026-07-10 8:08:32.885 aminfoKitchen display - [Google Nest Hub] is playing
dev:17642026-07-10 8:08:32.862 aminfoKitchen display - [Google Nest Hub] is buffering
dev:17872026-07-10 8:08:32.860 amdebugGC+ [Kitchen display] media: BUFFERING
dev:17872026-07-10 8:08:32.765 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":699}
dev:17872026-07-10 8:08:32.727 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":698}
dev:17642026-07-10 8:08:32.672 aminfoKitchen display - [Google Nest Hub] is idle
dev:17872026-07-10 8:08:32.667 amdebugGC+ [Kitchen display] media: IDLE
dev:17872026-07-10 8:08:32.607 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"LOAD","requestId":697,"autoplay":true,"currentTime":0,"media":{"contentId":"http://192.168.11.100/tts/2a766eb9468cabbc782a0d063fa73100.mp3","streamType":"BUFFERED","contentType":"audio/mpeg","metadata":{"metadataType":0,"title":"Announcement","subtitle":""}}}
dev:17872026-07-10 8:08:30.581 amdebugGC+ [Kitchen display] media: PLAYING | Announcement
dev:17642026-07-10 8:08:30.550 aminfoKitchen display - [Google Nest Hub] is playing
dev:17642026-07-10 8:08:30.416 aminfoKitchen display - [Google Nest Hub] is buffering
dev:17872026-07-10 8:08:30.411 amdebugGC+ [Kitchen display] media: BUFFERING
dev:17872026-07-10 8:08:30.112 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":696}
dev:17872026-07-10 8:08:30.067 amdebugGC+ [Kitchen display] media: IDLE | Announcement
dev:17642026-07-10 8:08:30.062 aminfoKitchen display - [Google Nest Hub] is idle
dev:17872026-07-10 8:08:29.932 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":695}
dev:17872026-07-10 8:08:28.982 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":694}
dev:17872026-07-10 8:08:28.949 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":693}
dev:17872026-07-10 8:08:28.918 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"LOAD","requestId":692,"autoplay":true,"currentTime":0,"media":{"contentId":"http://192.168.11.100/local/gcplus-silence.wav","streamType":"BUFFERED","contentType":"audio/wav","metadata":{"metadataType":0,"title":"Announcement","subtitle":""}}}
dev:17872026-07-10 8:08:28.916 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.receiver -> receiver-0: {"type":"SET_VOLUME","volume":{"level":0.65},"requestId":691}
dev:17872026-07-10 8:08:28.914 amdebugGC+ [Kitchen display] TTS: begin (conn=APP_CONNECTED, transport=set, mode=restore)
dev:17872026-07-10 8:08:28.912 amdebugGC+ [Kitchen display] conn: APP_LAUNCHING -> APP_CONNECTED (DMR launched)
dev:17872026-07-10 8:08:28.911 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.tp.connection -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"CONNECT"}
dev:17872026-07-10 8:08:28.909 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.media -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"GET_STATUS","requestId":690}
dev:17872026-07-10 8:08:28.907 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.tp.connection -> 5139b2ed-18a7-462f-bc5c-b9cb5d353f2a: {"type":"CONNECT"}
dev:17642026-07-10 8:08:28.905 aminfoKitchen display - [Google Nest Hub] media source is Hubitat
dev:17872026-07-10 8:08:26.974 amdebugGC+ [Kitchen display] conn: READY -> APP_LAUNCHING (launching DMR)
dev:17872026-07-10 8:08:26.972 amtraceGC+ [Kitchen display] TX urn:x-cast:com.google.cast.receiver -> receiver-0: {"type":"LAUNCH","appId":"CC1AD845","requestId":689}
dev:17872026-07-10 8:08:26.901 aminfoGC+ [Kitchen display] TTS: "This is a test. This is another test." (mode=restore, volume=65, voice=Salli)
