I get a little annoyed at smart TV's that are not really smart...IE Don't report status back like mute. In this case it's my Frame TV...but TV's in general are not that home automation smart. And things like "on" are are often just toggles...IE The same command for on AND off.
So, I end up measuring outlet power to tell when it's off/on/ambient and use IF statements to get it to the desired state.
But I get annoyed sometimes by volume setting and it not being muted when it's switching between say off...then on...then setting it to ambient mode.
Is there a sound "level" sensor anybody could recommend that could be used to determine if it needed muting...the rules run in morning and at night and it's not like I'm standing there with the control in my hand.
If you want to know "how loud is that sound?" you need a decibel meter/sensor.
Pretty much any kind of sensor could be connected to Hubitat, but may require something like a Raspberry Pi to be setup in between. I'm not sure if there's an off-the-shelf solution that uses Z-Wave, Zigbee, matter, etc.
But I'm also not so clear on why you need to measure the sound level of your TV when it turns on?
Since it is a frame TV that I turn off at night when you power it on everything is a toggleā¦including volumeā¦so sending a mute command could mute it OR tigger volumeā¦since āambientā is a toggle tooā¦sometimes you end up at the default Samsung tv appā¦and get blasted by some newscast or somethingā¦
I can tell what mode the tv is in based on the power draw of the outlet and end up in the right placeā¦but that takes timeā¦the loop for that right now is 20 seconds so the plug can reportā¦if it toggles to tv when I send the ambient commandā¦it can be loud as heck.
there is always more that one way to skin a cat..but if a device could measure decibelsā¦I could send a mute command to shut it up.
