Yea when I came from ST i was using a Raspberry Pi zero W with VLC to connect to a google Nest Mini via BT and send audio with the VLCThing driver pretty much anything i wanted to. The problem is that it didn't take much to break the solution.
That was mostly a issue with BT to the Google Home Mini. I am sure a regular speaker using a wire wouldn't of had the issues. VLCThing and on a using a PI is amazingly powerful for audio tasks. this espeaks software could make it a extreamly complete package if possible.
@mavrick58
Actually, I found just the opposite - I tried VLCThing on a PI, and found a number of issues with it. I found that espeak (while certainly not as powerful as VLC), was much simpler - set it up, and then forget about it.
Each to their own!
Well I really can't speak for how hard or easy espeak is to use. VLC thing was a pain to get working, but once i did it seems pretty stable. Most of the problems i saw were related to speaker connections to the pi.
I dont disagree it could be a pain to get workong though. Getting VLC setup properly and then getting it to autostart were annoying.
I have just spent a week or so playing around with the best audio notification system. I did not want to spend $400 for a pair of Sonos.
I tried Echo Speaks. I did not like the idea of having to run a server to monitor cookie changes and authentication services. Also, I did not want Heroku knowing every command I send.
I tried Google Nest speakers. I liked these. I used one for a couple days and it worked great. Then, I learned about making Nest speaker groups. So, I ran out and bought a second Nest, grouped them from the Google app, and that is when all hell broke loose. Nothing would work consistently. One speaker kept dropping out and had to be manually initialized. The Google app would keep losing the group. It just became an unmanageable mess. Returned both Nests!
I use a tablet for my dashboard mounted on the wall next to the main door. It runs the Fully Dashboard. I found a driver, Fully Kiosk Browser Controller, which allowed the tablet to be recognized as a TTS device from hubitat. Awesome! But.... it just was not loud enough. It worked great; no delays; no drops; immediate responses... just not loud enough. Sigh...
I read about raspberry pi's; home brewed software and mods; arduino boards and the like. Knowing I could handle the task; I did not want to reinvent the wheel. Certainly there had to be something...
Two days ago, I broke down and went to Best Buy to get a Sonos One. $200. Ouch. I came home, plugged it in, downloaded the Sonos app, and it was recognized immediately. I linked my Spotify from the app to play a song, and WOW. The sound is absolutely stunning. Deep, immersive and simply outstanding. Next, I went to Hubitat dashboard and installed the native Sonos app. Once again, device was recognized immediately.
Now, I am SUPER happy with audio notifications. It is loud, clear and crisp. There is hardly ever a delay (if there is, it's barely noticeable). I will be going to Best Buy again today to purchase another; and see how it works with different zones; paired; etc.
I have no plug with Sonos. I would be in the front of the line complaining about the price. But... at the end of the day... the Sonos integration was by far the best choice for me.
Yes, I did look at the Symfonisk. I live in Louisville, KY. There is an IKEA in Cincinnati, Ohio (about an hour away). But, with Best Buy the return policy is super easy and they are local, so I knew I could easily return if disappointed. I have read quite a few people on here say the Symfonisk are just as easy to incorporate with Hubitat; at a much better price point.
I have been a musician for 30+ years. Not professionally, but as a hobbyist (albeit an expensive hobby). Anyways, I have an ear for sound. The Sonos just blew me away when I heard it. When I was a kid, we needed speakers at least 5 feet tall, about 2 feet wide, and a 1000watt amplifier (with an eq) driving them to match the sound quality. I was not expecting to use the Sonos as a primary speaker system; but after hearing them, I may have to reconsider.
I will probably buy a set of the Symfonisk to use as additional sources throughout the house (kids rooms, garage). But in my main room where we spend the majority of our time; I'm going with a set of Sonos.
If you have a supported iOS device, make sure you do the special calibration that they support in the Sonos app. It makes an additional huge difference in tuning for the specific room.
Same for me. I had to borrow an iPhone from a family member. Be warned -- the process is frustrating (might require multiple tries to succeed), but it's worth it.
Select the text of interest and then hit the Quote button that pops up.
One cool thing is that you can start a reply with one block, and while that reply edit window is active you can select another block and click Quote again. And it will put in two blocks automatically.
Understood, and good to know. Thank you.
I'll be back here either after Sonos blows me further away during calibration; or when I get a Symfonisk to experiment with.
If you’re not totally satisfied with your IKEA purchase you can return new and unopened products within 365 days, together with your proof of purchase, for a full refund. You may also return open products within 180 days, with your proof of purchase, for a full refund.
