does it in motion lighting also when i have different levels for different modes and have it set to change level on mode change.
If you use the setLevel with duration directly from the deviceās page, does it still do this? I may add a fade-over-duration option, if so.
I'm not seeing set-level with duration. These are the 26933 switches.
However the problem with that is, this is my kitchen. And when someone first walks in I don't want a slow ramp rate. I want the lights on as fast as possible. So I don't really even want to do this in the switch, unless this only effects level changes (aka light already on).
In the evening I dim that light, then at night it doesn't get used at all. That change in the evening is very abrupt. Again, totally willing to sacrifice that since everything else works exactly as I'd like it to. It would just complicate the motion lighting, which is already pretty complicated from what I understand.
