I know it’s been asked, but how about as of June 2026. Thank you!
In what sense? You need to provide a bit more info here.
It’s hard to say that one doorbell camera is “best” for all possible use cases.
Can you describe any other considerations that are important for you?
For example, power source and network connectivity will depend on whether you’re using existing doorbell wiring, can bring an Ethernet cable to where the doorbell is, etc.
Do you have any other cameras? Are you integrating them with Hubitat in any way?
Only speaking for myself. I’ve tried Ring, and eufy and was never happy. Finally got a reolink POE. It’s been rock solid.
I ordered a Reolink. To arrive tommorow. I think I will be fine using the Reolink app.
Poe one is the best. No wifi to worry about
FWIW, if you can run Scrypted on your LAN, it is simple to integrate events from the doorbell camera into Hubitat via MQTT.
For example, motion events after dark triggering lights, or a package delivery triggering a notification.
