Hello,
Wish List for the 'Compatible Devices' list
- Add a column for the device is Battery Powered
- Add a column for the device uses (Qty) Battery XXX
This is hopefully a "Help Others Post". In dealing with recent notification issues (solved in another post with GCal API App and Pushover) I wanted to document my battery powered devices by battery type so that I can add that to the Email Alerts for Low battery. Also, so I can potentially buy devices that use batteries I have a lot of, or like (CR123, AA, AAA, CR2032. I have found multi-function motion sensors like the Aeon MultiSensor 6 using it outside was "terrible" at battery consumption. I think due to it having too many functions for outside, temp, illumination, motion, etc. Similar with a contact sensor that did temperature. Maybe configuration to turn off features might be needed, but I have not gone down that route yet,
So I wanted to build a list so I can better choose products by battery type, yes you have to go find the manual online or contact support to find the battery type to use. If the battery type and count could be added to the 'Compatible Devices', then we could choose products by battery type we like, or by posts like this. And of course identify devices that are powered by batteries. For example the CR2477 do NOT do a good job at battery level readings.. 100% or Empty so false data and I get notifications to replace the battery that isn't dead yet... I would avoid this battery type in future buys personally. Guessing similar thick watch batteries types may have the same issue with this type and chemistry batteries.
My take on Performance ratings I used below:
Good= up to a year
Fantastic= over 1 year
Poor= under 1 year
Terrible = Less than 6 months or two batteries draining fast, worse than terrible
Below are items I am using and the Perf Rating, I have retired the "terrible" items as I have better options.
Leak Sensors:
Dome - CR123 Perf=Fantastic
Zooz ZSE42 - CR2450 Perf=New
EcoLink FLF-ZWAVE5-ECO - Generic Z-Wave - CR123 Perf=Good
ThirdReality Generic Zigbee - (2) AAA Perf=Good
Motion Sensors:
Ring - (2) AA Perf=Fantastic
Aeotec TriSensor - CR123 Perf=Good
Aeon MultiSensor 6 - CR123 Perf=New
Contact Sensors:
Ring - (2) CR2032 Perf=Fantastic
Aquara Zigbee (no temp) - CR2032 Perf=Good
Tilt Sensor:
Ecolink Tilt Sensor - CR123 Perf=Good
Smoke Alarms:
First Alert - Generic Z-Wave Smoke/CO Detector - (2) AA Perf = Good
First Alert - Generic Z-Wave Plus Smoke/CO Detector - (2) AA Perf = Good
Tempature Sensors:
Aeotec Aer2 - CR2477 Perf = Poor
Zooz ZSE44 - CR2450 Perf = New
Switches:
Zooz Zen34 - CR2032 Perf = Good
I hope this gives some folks an idea and to track their battery types and include the type in the notifications for low battery so you can order more when you find you are out... BEFORE the device dies ![]()
Lets expand the list for others and maybe Hubitat will add the 2 columns into the Compatible Devices list.
Cheers
