I'm migrating from SmartThings to Hubitat, and am trying to enable the external contacts on a MonoPrice Contact Sensor model 15270. I was following this advice
Looking for a Driver for Monoprice 15270
et al, I'm using the "Generic Z-Wave Contact Sensor" driver for my Monoprice 15270 Door/Window Sensor and finally had success with the External contact. Out of the box, this version's External Sensor is DISABLED by default as indicated on page 7 of the User's Manual. I used the "Basic Z-Wave Tool" to enable it WHILE IT'S AWAKE (that was the key for me). Once set, the Magnet MUST be Attached for the Wires to Respond, and the Wires must be SHORTED for the Magnet to respond.
Then temporarily switch to the "Basic Z-Wave Tool" to send a "SetParameter 1,1,255" Command to enable the external feature. If successfully enabled, the Tool will report in the Log "parameterNumber:1, size:1, value:-1."
I've entered the parameters a shown
but am not seeing the "value:" change to -1
