I didn't look real hard at what the broadcast was, but could look again later.
I do know you get exactly nothing via parse on the driver in my C7 when the broadcast is sent. So not sure how anyone would do anything with it on the driver side? But I'll defer to the real developers in that.
Again, I spent all of 5 minutes on this, so maybe I missed something.
So, I'm guessing the Node Information Frame is the broadcast message, as @martyn suggested above. He mentioned that he believed there was some change related to NIF processing between C-4 and C-7 or perhaps different revisions of the platform firmware.
Could someone from Hubitat please confirm/deny if there was a change to NIF processing? If there was, could it be reverted in a future platform firmware update? If there wasn't, could NIF's get passed to the driver-level for processing in a future platform firmware update?
I can certainly understand Hubitat's position that these devices should operate differently and that it is their responsibility to send timely reports, but it feels like this is not some isolated issue related to a specific model or even manufacturer. And, since I have not seen widespread usage of OTA updates, I think the devices are what they are.
As I mentioned, this is something that makes Hubitat unsuitable for this use-case (no-load/remote switch), with this device. Admittedly, this is probably not a common use-case.
Thanks to all who have helped hunt down what is going on here and apologies for the lengthy thread. I've learned a lot.
To my knowledge the NIF/broadcast frames have never been available to use in drivers in Hubitat. I don't remember them ever triggering anything in parse() on any version of the hub or platform software (?). So even if there was "a change" I'm not sure it matters in this context?
If we can trigger things in a driver off the NIF, I would love to know how as I would likely go back and add a manual report request triggered off of it for these devices. But I don't think we can.
Would be cool if we could though... Maybe it should be a feature request?
@JasonJoel, I guess the feasibility depends if the SiLabs platform stuff makes the act of receiving an NIF available to the higher-up level. My guess is that this information is available.
@bcopeland, It's not really the information contained in the NIF so much as the act of receiving an NIF, which apparently (in this device's case) indicates a change in device status. Upon reception of the NIF, we could manually query device status/request a basic report. In this device's case (and others), this is faster than waiting for the device-generated updates (binary report/basic set/centralscene report).
I probably phrased it poorly originally. The question really was whether there was a way to use the initial broadcast packet the devices send out on single taps in a driver, similar to what some hubs did with zwave non-plus devices back in the day. The reason is that the initial broadcast packet proceeds the normal multilevel report by 1-2s - so could be used as a trigger for a manual report request to update status faster than waiting for the normal report the device sends.
I assumed the answer was no, as I haven't seen any evidence that the broadcast packet is available to drivers in any way.
Thanks, as always, for answering our weird questions.
How does one read / interpret the info. in zwNodeInfo. I had assumed it was a list of neighboring nodes or something --is that correct or is there something else there?
So, for the example from a few posts above, zwNodeInfo is basically iClusters, but with an extra 6 bytes in the front and it looks like an extra few classes (68, 23) at the tail.
The first bit is a good one for devices that can be listening or sleepy.. If the first bit is on you can send commands anytime.. If it is off, you must wait for wakeup
Having access to that "listening" bit seems useful (particularly for sensor devices that can run on either battery or USB so they may or may not be sleepy). Is there a system call or way to get this into a class structure, or do I have to parse it myself? Thanks.
