Basic rules have been pretty nice, thanks for adding it.
I have a basic rule for a HS-WD200+ double tap up turning on a scene device. It seems the HS-WD200+ driver is creating 8 to 10 events when the button is pushed, which causes the basic rule to trigger the same number of times. This manifests as the scene getting “stuck” on for for a few minutes. Turning off a light just has the light mysteriously turn on as the hub processes all the actions and turns on the scene multiple times.
Is there an easy way to debounce a button push? It’d be great if there was a check box in basic rules, “Only execute once in within 2 seconds” or something.
Alternatively, do you have any suggestions to overcome this problem of multiple events triggering the rules multiple times?
dev:712021-07-18 09:43:16.094 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:16.008 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:15.948 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:15.644 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:15.571 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:15.513 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:14.930 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:14.674 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:14.358 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:13.685 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:13.341 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:12.604 am infoScene Main Floor was turned on
dev:712021-07-18 09:43:12.196 am infoScene Main Floor was turned on
dev:712021-07-18 09:34:25.822 am infoScene Main Floor was turned on
dev:712021-07-18 09:26:11.445 am infoScene Main Floor was turned on
dev:712021-07-18 09:24:14.145 am infoScene Main Floor was turned on
