Basic rule for sunrise/sunset fails intermittently
I have a Zooz ZEN77 800LR dimmer that controls two outdoor lights. I set up a couple of basic rules to turn the switch/lights on/off at sunset/sunrise. This has been failing intermittently.
The C7 hub is running 2.3.5.152. The ZEN77 is at firmware 4.20 and is running the "Zooz ZEN Dimmer Advanced" driver.
The above screenshot shows what happens when it works (when the light was turned on at sunset yesterday) and when it doesn't (at sunrise this morning). The screenshot also shows that the switch was manually turned off when it failed to turn off at sunrise.
The log has an entry ("...switch is turned on (digital)") for the action that worked yesterday at sunset. It does not have any entries for when the switch failed to turn off at sunrise this morning. There is an entry ("...switch is turned off (physical)") for when the switch was turned off manually after the "sunrise rule failure".
I created the rules about a week ago. There's no "pattern" for failures/success that I see. Sometimes the sunrise rule fails. Sometimes the sunrise rule fails.
Where should I go from here?
Can you update to the latest version to see if that resolves your problem?
Updated hub to 2.3.6.145. I will update this topic if problem reoccurs.
