A new update to BWA Spa Manager 1.3.0 has the following new command feature for setting the spa time clock from hubitat's local time.
v1.3.0 - Feb-07-2024
Install/Update using Hubitat Package Manager (HPM)
- REQUIRES HPM v1.9.2 or higher for install/update.
- This BWA Spa Manager release has extensive changes to both application & drivers to catch/handle spa offline/disconnected conditions as best as possible. *The Balboa SPA WiFi controller can be very unstable and randomly losses network connection to the BWA Cloud. Refresh SPA parent driver and then check for an 'online' state in parent SPA driver to determine if the spa is 'online' before sending any events, like pump on, lights on, etc. Re-check that the events have been changed in a refresh.
- Added new feature 'Set Spa to Local Time' command in the spa parent device to update the SPA's internal time clock to hubs local time in HH:mm format'.
- Added a new 'speed' attribute to the spa switch child driver(s) for selected spa devices, like pumps, blower, etc that have a low or high capabilities in addition to a switch state of 'on/off'.
- Added detection of a blower pump (if present) and the current on/off state and speed level if on. Current BBWA release does not provide control of this blower device, just current state.
- Changed default polling location modes to ALL when installed the first time. It is recommended that one deselects those modes in which polling is not needed to reduce hub usage. One can use a RM to poll/refresh the spa state less frequently than what is offered in the BWA app preferences for auto polling.
- Updated BWA Spa Manager code stream to use HE libraries and bundles. As a reminder, your HPM must be at v1.9.2 or higher to install/update BWA successfully.
