I'm satisfied with the price/performance on this little device. I have four physical locations, remote admin works like a charm.
Also, Hubitat have a nice feature that will allow you to get every device, without unlocking the backup, this is much better than a good dump!!
I must agree that you can't reprogram back a dead unit, but in that case, use the backup.
Use the "Maker API", with just on curl/wget you can dump all your devices.
Get your own access codes/tokens. Actually, it's very cool.
wget https://cloud.hubitat.com/api/[redacted]/apps/166/devices/all?access_token=[redacted]
sample reply:
......{"command":"doubleTap"},{"command":"hold"},{"command":"off"},{"command":"on"},{"command":"push"},{"command":"refresh"},{"command":"release"}]},{"name":"Wall Dimmer","label":"Patio Sitting","type":"Generic Z-Wave Dimmer","id":"16","date":"2022-07-12T00:15:07+0000","model":null,"manufacturer":null,"room":"Outdoor","capabilities":["Configuration","Actuator","Refresh","Polling","ChangeLevel","SwitchLevel","Switch"],"attributes":{"switch":"on","dataType":"NUMBER","values":null,"level":"48"},"commands":[{"command":"configure"},{"command":"flash"},{"command":"off"},{"command":"on"},{"command":"poll"},{"command":"refresh"},{"command":"setLevel"},{"command":"startLevelChange"},{"command":"stopLevelChange"}]},{"name":"Generic Z-Wave Switch","label":"Wall right","type":"Generic Z-Wave Switch","id":"17","date":"2022-07-12T00:15:02+0000","model":null,"manufacturer":null,"room":null,"capabilities":["Configuration","Actuator","Refresh","Polling","Switch"],"attributes":{"switch":"on","dataType":"ENUM","values":["on","off"]},"commands":[{"command":"configure"},{"command":"flash"},{"command":"off"},{"command":"on"},{"command":"poll"},{"command":"refresh"}]},{"name":"Generic Z-Wave Switch","label":"Wall left","type":"Generic Z-Wave Switch","id":"18","date":"2022-07-12T00:15:02+0000","model":null,"manufacturer":null,"room":null,"capabilities":["Configuration","Actuator","Refresh","Polling","Switch"],"attributes":{"switch":"on","dataType":"ENUM","values":["on","off"]},"commands":[{"command":"configure"},{"command":"flash"},{"command":"off"},{"command":"on"},{"command":"poll"},{"command":"refresh"}]},{"name":"Wall Dimmer","label":"Porch","type":"Generic Z-Wave Dimmer","id":"19","date":"2022-07-12T00:15:02+0000","model":null,"manufacturer":null,"room":"Outdoor","capabilities":["Configuration","Actuator","Refresh","Polling","ChangeLevel","SwitchLevel","Switch"],"attributes":{"switch":"on......
