Awair Local API - Parsing Error
Good morning @Digital_BG , wondering if you are still around supporting this driver [Release] AwAir Elements Driver - co2 air quality monitor =). I recently had some stuck values, and found that I was getting "Parsing Error" over and over again for a week. I tried refresh/poll and debug logging but now i'm stuck with "-1" values in the attributes and nothing else really showing in the logs now. Any ideas on how to fix or debug something like this? The IP is still correct, and my other Awair Elements are working without issue.
THANKS!
-1 usually means that the search for a value (.indexOf(...)) was not successful.
welp, I restarted it - first time no luck, seems like the 2nd time it just works again. No idea!
Just adding to this thread/issue, I now have 2 of my 4 awair devices, all using the same driver and local API, that being to exhibit this issue and stop reporting data randomly. It happens every few days and the only cure is to power cycle the device.
I assume nobody else is experiencing this issue. I’ve emailed Awair but don’t expect too much back from them. My temporary solve will be to put the 2 devices with issues on a wave plug and cycle power every few days through an automation. Not ideal though.
My Awair devices connect and disconnect all day long and sometimes go away for multiple days. I sent a question to Awair as well and they just send me Wi-Fi how-to. They are the only device on my network that behaves this way. Agree after one day of non-connection the only fix is power cycling.
I am not sure what finally solved this, however, I had a voltage problem at my house. I eventually figured out it was upstream of my panel, and turns out I had bad feeder cables which were causing the issue. Voltage would have very short sub-cycle dips and I believe this was the root of my Awair issues. When that was fixed, I have never had a problem since. So for what it's worth, if you see flickering lights ever, it could be that (and for you, it could be a specific circuit or large load causing it if you have old wiring that is undersized or old wire insulation issues - also dangerous if it's the latter).
