My automations broke after the last update. Rules are becoming true, but I'm getting this error when they try to trigger the z wave devices.
Can you specify what device/driver is causing the issue?
They're all iris motion sensors and all GE or jasco switches. The motion registers in the log and the rules trigger as true. I can manually control them from the hub interface and that also shows in the log. These automations are both on the built in motion lighting app AND old rule machine. Lighting rules triggered by door contact sensors are also not working. Other automations like setting the alarm via presence are wworking. These have all been working fine for at least two years until now.
Thanks for the additional information! Cana you turn on the logging on some of the rules that arenβt running to see what if anything is happening with them?
