Automations stopped working
C8 hub, had several automations that i paused. When i started them up again they dont work.
One turns on the bath light depending on lux and time of day for brightness. Worked fine in the past. I paused them for awhile, then when i started them again nothing. I can set it to turn on and off useing alexa or google home. But neither recognizes the lux reading on the dome sensors. I upgrade to c8 , so am i missing a switch or option somewhere? Did the program change? I cant find a reason why it doesnt work, i can see the devices and readings. Ive trued writing a new app, nothing is working. Is alexa or google blocking it? Im stumped
In order for us to help you, we will need some more information including:
A screenshot of the rule that is not working as intended.
A screenshot of the logs showing the issue (logging should be turned on for the rule and the devices used by the rule).
Rules should not be impacted by their transfer to a new hub. I have upgraded hubs many times, and have never seen that impact my rules. It is likely that one of the devices is not reporting information (ex.: Lux) as expected.
