Automating Grow Lights?
Does anyone have ideas on how to automate these lights? If I plug it into a Zigbee or Zwave socket, they will not come back on if power is cut. I’m open to replacing the LED strips if someone can recommend ones that will work.
I have done this once before with some other grow light (just on/off - no color or level) but these default to a very bright white so not sure that surgery will work!
Thanks for your help.
Have you checked to see if there is a zigbee/wled controller with what you need. Seems like a RGBWW controller could possibly work just. Would just need to remember it only has the r part of the rgb lol. What wires does it have coming from the controller.
That depends upon the plug. I have some that will restore the power-on state.
E.g., this setting is on a Thirdreality Outlet using the Tuya Zigbee Metering Plug driver. These plugs are 4 for US$30.
I wasn’t referring to the Zigbee plug. It’s the in-line switch on the lights that will not turn on when powered on. You have to turn the lights on from the switch itself.
The LEDs are 5V and have an in-line switch, so unfortunately, won’t work with a RGB controller. I’m going to try replacing the whole thing with LED white color temp strips and a controller.
I was just trying to think of a way to give you controll of each set of lights. A RGBWW controller would give you sperste warm and cool white color control as well as a r channel that is part of thr RGB component. Generally LED controllers provide a positive for the volts they support for the entire device and then a negative wire for the part they control. So on a rgbWW that is 6 wires 1 for the general +DC power and then a negative wire for red,blue,green,cool white,warm white. Your 3000k would be warm white, the cool white would be the 6000k. Then red would simply be red. Leave blue and green unconnected. Then you just have to control it appropriately. This all depends on how the wires are in the controller. If the current controller somehow is wired in some other way then that not work. You could also try 3 different simple on/off controllers with dimming. One for each channel. All of that requires pulling the existing controller out of the circut though.
I thought about removing the existing switch and just using the LEDs but that would require a 5V Zigbee controller and I only saw 12/24V ones. Do you know if a 5V one that would work with Hubitat?
It wouldn't have to be zigbee. It could also be wifi with something like wled. It just needs to support multiple channels so you could control each set of LEDs independently.
This looks promising.
