[Yes, I'm suddenly choosing to migrate from another hub's platform. (: ]
I've got 8 Caseta in-wall switches installed, as well as Pico remotes, that have worked fine over several years. All switches control a hard-wired overhead light (dimmable) or outlet (lamp + Cree/Philips non-smart, dimmable LED bulb).
Can the Caseta switches can be used to automate groups of other lights through HE and a Pro bridge from Lutron? I think I understand that HE can issue commands to the Lutron Pro, but what about the reverse direction?
For example, if I have also have a group of ZigBee or Hue lights in the same room, can I build automations/rules in HE that would turn on the lights in the ZigBee/Hue group whenever I turn on the "main" light via the Caseta switch (or remote paired to the switch)?
This might be a rule/Rule Machine question, but what about dimming at the switch? Can a dimming adjustment made at the switch also trigger dimming for those other bulbs via HE automation?
