Automate Three Stage Touch Dimmer Switch
Does anyone know any IoT products that I can hook up to a touch switch similar to this one ? I would like to be able to turn on, set brightness, and turn off the light that associated with this switch.
The switch takes a finger touch, and then ramps the light to low, med, high and then off states with each finger touch. Would a low voltage relay switch do in this case?
