Aurora AOne Contact Sensors (UK)
Hi all, has anyone managed to successfully connect and configure Aurora AOne Contact Sensors with their HE? My hub sees the sensor as a generic “device” I then change type to “Generic Zigbee Contact Sensor (no temp)”, trigger “Configure” command for HE to get to talk to the sensor and then nothing. I keep seeing permanent “warn - configure...” message in my log and nothing happens.
Anyone managed to connect them successfully?
There were a few of the Aone devices that @mike.maxwell said used a odd zigbee profile, maybe this device was one of them?
@TUllman HE has a whole box of the whole range of Aone stuff stuff so best to ask just incase its a odd device. I think the motion sensor is also a no go.
The kinetic stuff for example is "correct" but cant work with HE "yet".
@BorrisTheCat, great suggestion. Cheers!
@mike.maxwell -- do you know if the Aurora contact sensor is one of those odd cases that require a slightly different configuration?
The Aurora contact and motion sensors do not work with Hubitat.
Thanks for confirming @mike.maxwell!
