When I use the built in driver for the HEM only info available when I select custom attributes is what is circled in blue, I need what is circled in red to be able to monitor each clamp
DSB09104-ZWUS is the model I have, do not have batteries installed
I realize that but the driver you are using is obviously not working correctly. Until you use a driver that works right, it's going to be tough to troubleshoot your issues. Also unfortunately, the driver your using doesn't even allow you to turn on logging so it's tough to even know what it's doing.
does anyone have a plugin adapter they recommend for this purpose Z-Wave or Zigbee, washer and dryer(gas) are 120v
I have seen a few different devices on Amazon but want to waste $$ on something that isn't going to work
