From what I can see it reports a "live" power reading, though it would appear you may need to setup some more frequent polling. But I can't see any details of overall usage. Perhaps Samsung do that in their software if it is available there...
Yeah you basically need to measure time between power reporting changes and then calc the energy use over that period and sum it up. I have a nodemcu running something like that to monitor usage at the main power meter.
I have a TP-Link one plugged into my washing machine and the monitoring app works quite well with it, though it can be a little bit of a lag at times but I've never looked into where...and it doesn't really bother me in that situation.
Based on some preliminary use of the plugs like I mentioned in another post, you may want to setup some more frequent refreshing of the devices on HE, updates to the power and status seemed to be done about every two minutes I think.
I kept refreshing the page all day after the plugs sold out and managed to order 2 as it briefly popped back. This one has been shipped (woot!) .... but my earlier order of multipurpose sensors is still 'processing'
They are wifi and not natively supported, i.e. there's no built in driver, but there is a community driver / app that can integrate with the kasa platform or connect directly to the devices for local control, though it looks like a firmware upgrade may stop the local control option now. I still have them connected to the cloud.
I've just been using the kogan ones flashed with tasmota. I usually get when they're around 10 bucks a piece (after discount/cashback offers). Had them for over a year now no issues. Plus they double up as USB charger as well
OzSmartThingsBlack Friday | Oz Smart Things Smart Home Automation
Fibaro - 10% off some, buy 5 get 1 free on others
Broadlink - Buy a Broadlink RM4 Mini, get a Broadlink RM Temperature Sensor free
Shelly - Buy 10 get 2 free.
I now have enough Aeotec Nano Dimmers and Nano Switches to do nearly every switch in the house.
The ST MP sensors are rock solid compared to my xiaomi ones . With the secondary benefit of being able to detect glass breakage. Totally worthwhile spend to replace all the problematic ones.
I have found the same. I replaced 16 of my contact/temp sensors with the ST ones. All seems to be OK. My problem Xiaomi motion and temp/humidity sensors are still dropping off regularly. What cost-effective, Zigbee replacements would people recommend?
But they were the cheapest (and smallest) at the time. In fact I'm actually going to keep using the xiaomi magnets because the ST ones are too large and strong.
