I just retired my Samsung Smart things mesh network and installed a TP-Link Deco mesh system.
One of the repeater routers is more centrally located in my set-up.
Can I attach the HUBITAT to the repeater router, or should I attach it to the router that receives the modem input?
Thanks inn advance.
RickR
I assume you mean attaching it with ethernet. It should work fine plugged into one of the mesh nodes.
Mine has been attached to both the primary router and various access points on a mesh system and I've not had any issues with either.
