ARGH! After 2.5.0.123 update, I cannot figure out where the original driver for my Tuya IoT Platform Saddle Heat Pump is! And Temp is wrong!
So, here's my issue: I have two Saddle (window) heat pumps. They run fine from the Tuya IoT platform (cloud) driver. They're (right now) reporting temps ... but those temps are WAY WRONG.
In the main device (Saddle Heat Pump) using "Tuya IoT platform (Cloud), the logs say things like:
[dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.671 PM debug SADDLE AC Lanai status [code:temp_set_f, value:78] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.669 PM debug SADDLE AC Lanai status [code:temp_current_f, value:71] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.668 PM info SADDLE AC Lanai fault is ok
or
[dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.650 PM debug SADDLE AC Garage status [code:switch_horizontal, value:false] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.649 PM info SADDLE AC Lanai switch is on [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.648 PM debug SADDLE AC Garage status [code:switch_vertical, value:false] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.647 PM debug SADDLE AC Garage status [code:temp_set_f, value:80] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.647 PM debug SADDLE AC Lanai status [code:switch, value:true] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.647 PM debug SADDLE AC Garage status [code:temp_current_f, value:78] [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.646 PM debug SADDLE AC Lanai workMode [dev:685](http://hubitat-c8pro.local./device/list#)2026-04-26 05:05:55.646 PM info SADDLE AC Garage fault is ok
You SEE that the driver is reporting Fahrenheit, but here's a screenshot of what my main page is showing for each device:
and
So, it's not doing something right.
Before this OS update, everything was fine...but after, I cannot even FIND where the darned driver is!
Please...someone help!
Thx
Jann
Hardware: C-8 pro
Make sure you have the following setting enabled to be able to see custom Apps and Drivers code
So, Gonna paste my Drivers, Apps, Libraries, and Bundles section. Can ANYONE tell me what is providing Tuya IoT cloud now? Cos I used to know where it was...but it's not there anymore.
I have "Advanced/developer" options checked as the first graphic shows:
Drivers:
Apps:
![Screenshot 2026-04-26 at 5.51.02 PM|690x224
(upload://rssqAchVKHGrKjpaQWwRk2iCzW1.png)
Libraries:
Bundles:
I'm a programmer. I'm not new to Hubitat...but this one driver seems to be gone!
TiA!
Jann
Remove the filter β€˜Val’ in the list of your Drivers.
OMGOMGOMGOMG! THANK YOU! I put that there when searching on iPhone and didn't remove it!
I see where it is now! THANK YOU!
I'm so sorry!
Jann
I think we have all done that once or twice.
Could have been worse.... I have accidentally double tapped the spacebar..... :man_facepalming:
