Hey all - I am attempting to add a Aqara Wireless Miniswitch T-1 Zigbee device to my hub. It successfully pairs and is recognized as a device. However, when I press the phyiscal button, nothing happens. Nothing is logged. It's as if the device is not communicating with the hub even though it's on the network.
I did not install any custom driver as I understand that this device should be supported natively. I also did not use any Aquara hub or app.
When adding the device both as a recognized compatible device or as a manual generic device, Hubitat at first recognizes it as an Aqara Water Sensor, and I have to change the device type.
If I test the buttons virtually, everything works as expected. An event is logged and a test rule that I created fires. But if I click the button on the device, nothing happens. Help?
Thanks. I updated to version 2.4.3.133, factory reset and removed the device, and re-added it. The results are the same - first recognized as a water sensor, then after updating the device type and reconfiguring, nothing is logged on button press.
Thanks - I repaired the device without removing it as suggested, and then I hit the Configure button again. Still no communication from the device when button pressed. Here's the Device Details screenshot below.
Dumb question - when I change the device type to Aqara Zigbee Mini Switch, that adds the correct native driver, right? Or is there something else to do?
Enable the Debug logging option on the Preferences tab and try pairing again without deleting, very close to your hub. Anything in the live logs?
Don’t click on the Configure button, it is useless with Zigbee sleepy devices. These Aqara buttons accept configuration commands only in a very short time frame that follows the pairing process.
This Aqara Wireless Mini Switch T1 (a.k.a. WXKG13LM, Zigbee model lumi.remote.b1acn02) differs from the same shape buttons supported in HE inbuilt and custom drivers.
Supported Aqara buttons are Aqara model WXKG11LM (lumi.sensor_switch.aq2 & lumi.remote.b1acn01) and Aqara WXKG12LM (lumi.sensor_switch.aq3 & umi.sensor_swith). All three of these models look the same, so it isn't easy to distinguish them.
