Did you get a battery report at some point?
It was, as that is where I got all of mine from. But supply seems to have dried up and I can't see them on Amazon anymore. Still available from Aqara site though.
I can share the driver code that mostly works (community modified curtain driver) if that would help identify any differences?
Not with your driver. Do with veeceeoh driver.
@mike.maxwell A quick press on the button elicits an FF01 with voltage of 170C -> 3.095v, but doesn’t set a current state.
Also not seeing the error lately.
This must be a completely different firmware than the unit I have, mine reports battery on the 01 tag, now I understand why I've avoided these for so long...
The payload is one byte short for either encoding type 41, or 42
poking around some more
Are there plans to add support for the Aqara WXKG11LM Mini Pushbutton?
Ok I
- Used veeceeoh driver. Worked
- Switched to Device and cleared everything
- Switched to your driver, Configured, turned on debug
- Closed/Open with magnet Got state
- Quick press. GOT 100% battery
- Looked in log, got same error.
Maybee that’s why veeceeoh driver searches for the 0x21 in the FF01 payload and uses the next two bytes?
Can’t trust length.
can you post the logs when you got the battery report?, maybe I can just ignore that bad payload...
Looks Like I wrote the driver for it, but forgot to add it to the build.
What's the old saying? Oh yeah, no good deed goes unpunished. ![]()
That does sound like a very intentional/specific work-around...
LOL. We will catch it next round! Thanks.
Hi, aqara built in driver works fine with E1 switch. Any chance to have the decoupled mode working with built in driver ? Best.
no idea what this is...
Logs were getting very big and confusing so I cleaned them up and (of course) now I can NOT replicate.
However, here’s a response from a button press.
[trace][raw:37D801000076050042166C756D692E73656E736F725F6D61676E65742E61713201FF421D0121170C0328260421A83305213C00062402000000000A210000641001, dni:37D8, endpoint:01, cluster:0000, size:76, attrId:0005, encoding:42, command:0A, value:lumi.sensor_magnet.aq2, clusterInt:0, attrInt:5, additionalAttrs:[[value:! (&!¨3!<�$
!d, encoding:42, attrId:FF01, consumedBytes:32, attrInt:65281]]]
It appears that in this case the FF01 is buried in the additionalAttrs
In the failure it WAS the base attrid
battery comes in on cluster 0, I tag decoded the frame you sent after adding the missing byte at the end, the battery tag isn't in that frame, so i'm feeling like I can completely ignore this specific frame in the driver.
I'm going to guess it's smart-bulb mode.
Sounds like he means bulb mode? As on Zooz and Inovelli. @amaduhi - is that what you're referring to, set the switch to bulb mode so that you can use it w/smart bulbs?
" * Versatile Control Options:Offers both wired and wireless control, catering to diverse smart home setups."
Yes smart bulb mode or wireless mode.
