AQARA stability
These issues arise from Aqara devices not being either zigbee 3.0 or ZHA1.2 compliant.
It isn't possible to do this. You have at least 3 choices:
  1. Make sure that ALL zigbee routers in your Hubitat zigbee mesh are Aqara compliant.
  2. Get an older Mijia bridge; pair the sensors to this bridge and then integrate it with Hubitat with a MiConnector setup.
  3. Setup a secondary zigbee mesh using a different coordinator (eg. HASS or zigbee2mqtt) and then import the sensors to Hubitat as virtual devices from that coordinator.
