Mid morning after adding M1P-2 back. See it has a GroovyRuntimeException and two warning events after it. will see how long it stays on:
2025-03-11 10:43:25.402 AMinfoM1P-2 illuminance is 122 lx (delayed)
dev:2662025-03-11 10:43:24.442 AMinfoM1P-2 Motion is active 9s
dev:2662025-03-11 10:43:21.408 AMinfoM1P-2 Motion is active 6s
dev:2662025-03-11 10:43:20.317 AMinfoM1P-2 illuminance is 119 lx (delayed)
dev:2662025-03-11 10:43:18.348 AMinfoM1P-2 Motion is active 3s
dev:2662025-03-11 10:43:15.380 AMinfoM1P-2 Detected motion
dev:2662025-03-11 10:43:15.314 AMinfoM1P-2 illuminance is 121 lx
dev:2662025-03-11 10:43:08.136 AMinfoM1P-2 Motion reset to inactive after 30 s.
dev:2662025-03-11 10:42:38.145 AMinfoM1P-2 Detected motion
dev:2662025-03-11 10:42:38.118 AMinfoM1P-2 illuminance is 119 lx
dev:2662025-03-11 10:42:33.017 AMinfoM1P-2 LED is Enabled (1)
dev:2662025-03-11 10:42:33.004 AMinfoM1P-2 illuminance is 142 lx
dev:2662025-03-11 10:42:32.994 AMinfoM1P-2 Battery level is 99 %
dev:2662025-03-11 10:42:27.981 AMinfoM1P-2 (parse attr 5) device lumi.motion.ac02 button was pressed
dev:2662025-03-11 10:42:26.586 AMinfoM1P-2 Debug logging is false; Description text logging is true
dev:2662025-03-11 10:42:26.584 AMinfoM1P-2 Updating Aqara P1 Motion Sensor RTCGQ14LM model lumi.motion.ac02 manufacturer LUMI (driver version 1.7.3 2025/01/16 11:46 PM)
dev:1402025-03-11 10:42:21.015 AMwarnEvent interval INCORRECT, recovery mode (Normal) ACTIVE! If this is shown every hour for the same device and doesn't go away after three times, the device has probably fallen off and require a quick press of the reset button or possibly even re-pairing. It MAY also return within 24 hours, so patience MIGHT pay off.
dev:1402025-03-11 10:42:21.013 AMwarnOne or several EXPECTED checkin events have been missed! Something MIGHT be wrong with the mesh for this device. Minutes since last checkin: 521313 (maximum expected 140)
dev:2662025-03-11 10:42:08.129 AMerrorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#minus. Cannot resolve which method to invoke for [null] due to overlapping prototypes between: [class java.lang.Character] [class java.lang.Number] on line 1164 (method parse)
dev:2662025-03-11 10:42:02.600 AMinfoM1P-2 (parse attr 5) device lumi.motion.ac02 button was pressed
dev:2662025-03-11 10:42:02.598 AMinfoM1P-2 (parse) device model is LUMI
dev:2662025-03-11 10:42:02.374 AMinfoM1P-2 healthStatus changed to online
dev:2662025-03-11 10:42:02.255 AMinfoM1P-2 configure...fullInit = false (driver version 1.7.3 2025/01/16 11:46 PM)
sys:12025-03-11 10:42:01.250 AMinfoFound previously joined Zigbee device M1P-2
sys:12025-03-11 10:41:58.939 AMinfoZigbee Discovery Running
