I want a cheap zigbee leak sensor with a thin wire tail sensor. Does anyone know if I can solder cheap speaker wire to an aqara sensor, I presume on the underside there are two metal probes but as I don't have one I can't be sure.
The sensor I'm thinking of is
or can anyone recommend an alternative that is available in the UK?
I want one so I can get an alert when the water container in a dehumidifier needs emptying.
I have 6 of those exact Aqara sensors and they work great with the C-5 Hubitat. I can't speak to newer hub versions.
They are a huge pain in the butt to add. Sometimes you have to try a dozen times before it properly adds, but beyond that one issue I have had no problems at all with them.
