Aqara Integration
Hi Guys, we're all aware of the issues regards Aqara devices. out of curiosity if you have an Aware hub, is there an integration like the Hue Bridge Integration? Appreciated in advance :slight_smile:
Not for any recent Aqara/Mijia hub. If you use Home Assistant and zigbee2mqtt, you can integrate Aqara devices into Hubitat using Home Assistant Device Bridge. Be aware that you will have to use Aqara compatible repeaters for these devices to work stably with zigbee2mqtt.
I'm using ZHA in Home Assistant with some Aqara devices. Seems to work fine as well.
