I have an Aqara M3 hub that I have been messing around with just for fun. I was able to pair a few Aqara Zigbee sensors to the M3 hub. I then paired the M3 Hub (as a Matter Bridge) with Apple Home using Matter (Note: Do NOT use Apple HomeKit to pair the M3 Hub with Apple Home. Otherwise, the devices will not be sharable with Hubitat via Matter.) Once the sensors appeared in Apple Home, I was able to share the Aqara Matter Bridge with Hubitat using @kkossev's Matter Advanced Bridge driver. The sensors then appeared in Hubitat and have been working fine.
